xbox series x components behind hdmi tvs diode
  • burnsj2
    • Nov 2020
    anyone know where I would get some tvs diodes - (the tiny black components behind the series x hdmi port)
    I need 2 of these tiny feckers but can't find anywhere online, or anyone know if any other console has them I could take them off or if any other component could go in its place, from what I read they are just there for protection but I don't want to turn it on without them..
    part number on schematics is
    sm m1015860-001
    • 31115
    Re: xbox series x components behind hdmi tvs diode
    wouldnt they be on most hdmi or dvi outputs?
    maybe look at old graphics cards
    • budwich
      ESD Diode on HDMI output of Yamaha a1050 RCVR
      by budwich
      I lost one of the two hdmi outputs on a yamaha rx-a1050 receiver. Of course, it is the hdmi1 which has the arc capability which was useful. The second output hdmi works OK.
      I got an hdmi breakout board which gave me access to the "little guys" in the hdmi. I did some gross DC voltage measurements to ground and found that the Data1 pair (4 and 6) had a lower voltage than the working hdmi.... 1.1v versus 2.9. All others pins seem to be OK. Further when plugged into a display, there is no video but a message on the screen which I assume is the display's status for the...
      09-11-2023, 12:21 PM
    • SuperAman
      PS5 HDMI port diode reading?
      by SuperAman
      I did an hdmi port repair for a PS5 and I lost the small diode z71 SOD923 on the back of the port. I did a trace repair for pin 19 of the port as well. Without the diode I get no display at all. I tried replacing the diode twice but after I get flux on it the marking comes off so I can't tell if I have it on the right orientation. When I measure I get a reading of 1(open) and 923 in diode mode. Is 923 a normal reading for these and also which side should the reading be with regards to the arrow on the board?...
      02-03-2024, 10:16 PM
    • TMTGTR
      An Xbox One PSU Odyssey
      by TMTGTR
      Firstly I am not a tech. You guys may see mistakes or oversights in my methods so don't be bashful and feel free to post corrections/opinions.
      =>Background:
      I bought my son a used Xbox One original model: A12-220N1A Rev: 02 with original PSU & 2 controllers 7 years ago. I “modded” the unit placing a 4.5” 12V exhaust fan with a 9v wall wart adapter on top of the vent/fan of the unit. And plugged the Xbox PSU into a Tripplite LTR-600 voltage regulator. Also connected to the Tripplite are a 275w computer tower, an Xbox 360 PSU and a Westinghouse 52” LED TV. ...
      06-17-2022, 05:40 PM
    • irepair559
      Ps4 1215a hdmi diode readings good everything good but no pic??
      by irepair559
      PS4 1215A HDMI DIODE READINGS GOOD EVERYTHING GOOD BUT NO PIC? everything is good! what else can it be? if hdmi diode values are good that means encoder and filters are good right? idk what else it can be guys...
      01-05-2023, 12:32 AM
    • aliougm
      Marantz SR4003 AVR HDMI board issue, seeking for help
      by aliougm
      I have problem with my AVR(Marantz SR4003) HDMI board issue. I connect to my TV but screen color distorted,see attached picture.
      Connection as below:
      Set-top box HDMI output >AVR 3 HDMI input/one HDMI output>HDTV HDMI port
      If I bypassed AVR then HDTV screen color be good.
      I take out HDMI board from AVR and check services manual the schematic shown the HDMI signals path:
      3 HDMI input port > SIL9185 chip(HDMI switch) > SIL9033 chip(HDMI receiver) > SIL9030 chip(HDMI transmitter) > HDMI output port
      I replaced all...
      04-30-2022, 12:21 PM
