baby monitor charging issues
  • armands0212@gmail.com
    • Oct 2021
    • 28
    • Latvia
    hi all.i have a problem with baby monitor board.basically it has voltage regulatir blown it was LD1117AG 50 so i changed it to AMS1117 5.O regulator and it working just fine but dont charge battery.voltage is going in to batterys charging points but when i put battery in than dont.
    so is voltage regulator could be wrong or some other component might be faulty?
    • 31084
    Re: baby monitor charging issues
    what is printed on the 5pin device - U12??
      • Oct 2021
      • 28
      • Latvia
      its - B27rK
        • Oct 2021
        • 28
        • Latvia
        B27rK
        • twonk9098
          Leovo Thinkbook 14 G2 ITL - Charging issues
          by twonk9098
          I have 2 x Lenovo Thinkbook G2 ITL laptops. They seems to be identical specs, both 11th gen, 1135G7 cpu, both 12gb ram and both 256gb M.2 ssd.
          I have ensured both have the same latest bios and ec firmware.
          One of them works totally fine however the other has charging issues.
          I have compared both motherboards in diode mode and cannot find much of a difference anywhere.
          I have swapped the motherboards over to the other casings and the issue transfers.
          It's behaviour is it will connect at 20v on USB-C and always start to charge....
          04-07-2025, 05:17 PM
        • Thomasraud
          Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
          by Thomasraud
          i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
          QUOTED
          -It works on charger (without battery connected-only charger)
          -It works on battery (without charger connected-only battery)
          -& it also works when plugged in battery & charger, but it's not charging the battery
          //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
          and..
          QUOTE
          The IC cannot maintain the input current level
          06-28-2022, 06:47 PM
        • Jesus Coder
          Issues Reviving Old Dell 2408WFPb Monitor
          by Jesus Coder
          I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
          06-25-2023, 02:33 PM
        • Aimbit
          A few Gen 3 iPads with differing charging issues (A1403, A1430, A1416) & iPad Air 2 (A1566)
          by Aimbit
          I purchased some broken iPads (non-charging), trying to repair something a little trickier than retro consoles... I have all the necessary tools.
          A1430 - Draws 930mA consistent, screen is black with red/empty battery icon, no charging symbol.
          A1403 and A1416 - Draw 930mA, wait 3 seconds, dip to 0, repeat.
          A1566 - Similar to the previous issue, it draws some power for a few seconds, then resets my ammeter, and repeats. Waiting for my lightning port tester to come to check the tristar.
          Seeing as these are old, and likely have been dead for ages, is a battery...
          05-23-2024, 06:36 PM
        • Scoff
          HP Probook 470 G4 - Power and Charging Problem
          by Scoff
          Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
          Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
          07-03-2023, 09:28 AM
