playstation 5 digital firmware dump
  • JRD5962
    • Sep 2026
    • España
    #321
    Hi there, I'm new to the forum. Thanks for all the BIOS contributions—they're very useful.
    On another note, has anyone encountered an issue with a console (model EDM-031 CFI-1216A) where it powers on perfectly with a white light but produces no image?
    I've replaced the HDMI port twice, swapped the HDMI encoder, and even reballed the southbridge just in case that was the issue, but nothing worked... What I find strange is that when turning the console on, it doesn't make the typical startup beep; it just turns on silently. It does enter Safe Mode, but it never actually outputs an image. Has anyone else experienced this?
    Thanks.
    • sehrud
      • May 2018
      this is not working
      • taydn29
        • Oct 2026
        • türkiye
        #323
        When I first plug in my PS5, it emits three beeps, indicating an error. I suspect this issue is related to the BIOS; could you please share a BIOS file?
        • wefixit14
          • Sep 2025
          #324
          hey guys i just tried to change the bios from my ps5 edm 010 cfi-1016a as the disc drive is not the correct one and i am unable to do software updates on it!
          I have taken the bios chip off and put into my scanner and programmer to be able to read it, back it up then erase it and write new bios (digital) to it. I tried a series of bios's and none worked the ps5 just does nothing when plugged in, no power no light. I then tries to put back the original bios which the file size is 32768kb, after trying to write this back to the ic the neoprogrammer and asnprogrammer give me an error "buffer size not equal to ic" this is confusing as the bios I took off was the same one i am trying to put back on and it does not work at all. any help will be much appreciated. Please let me know what i did wrong and how can i fix this. also if anyone has a bios for an edm 010 100889021 digital please let me know or email me at wefixitrepairservices@gmail.com
          i am unable to add the original bios here
          • Giacometti
            • Apr 2025
            • Congo-Brazzaville
            #325
            Besoin d'un propre pour EDM-030 1216A PS5
            • DOAT-Steve
              • Mar 2024
              #326
              Hi All,
              Does anyone have the BIOS/NOR for
              PS5 Disk to Digital
              CFI-1016A
              EDM-010
              Southbridge: 61GG
              WiFI: J20H100
              Thanks, Steve
              • weisian
                VSX-1021 - Update Error 1, DSP replaced, potentially need working firmware dump
                by weisian
                I have a VSX-1021 that dropped the UE22 error on me and is no longer was working. I've then done the following:
                1. Tried updating the firmware with a firmware I found online but it hangs at 20% and ultimately shows "Update Error 1". I didn't check prior to attempting the firmware upgrade but the firmware after shows "***" for the DSP numbers. This was before I looked online that pushing an update through with a bad DSP chip could corrupt the firmware.
                2. Tried reflowing the original DSP chip (D810K013BZKB4000) but firmware version remains "***"...
                03-12-2026, 05:54 AM
              • CapLeaker
                Andonstar ADSM302 digital microscope firmware dump
                by CapLeaker
                Seeing there is a need for the Andonstar ADSM 302 firmware dump from the Winbond 25q32 chip on the backside of the main board, I dumped mine. Confirmed working before and after dumping.
                Enjoy!...
                09-22-2026, 06:24 AM
              • Ahari
                by Ahari
                I...
                08-13-2025, 06:12 AM
              • FluxCapacitorish
                Aiwa TV-49UF30H (VM6901 / LC490EGY) stuck in bootloop, need install.img firmware dump
                by FluxCapacitorish
                I’m working on an Aiwa TV-49UF30H that is currently stuck in a bootloop. I’ve done a full teardown and diagnostics and wanted to see if anyone has a firmware dump or matching install.img.
                Symptoms:
                • Without USB: power LED flashes, TV immediately shuts off (bootloop)
                • With USB (install.img): green LED + grey screen (appears to enter recovery mode but does not proceed)
                What I’ve confirmed:
                • Main chipset: VM6901
                • Storage: eMMC (Kioxia THGBMNG5, integrated MCP under heatsink)
                • No SPI flash present on board
                • USB recovery bootloader is working and detects
                04-06-2026, 03:04 AM
              • beebuzzin
                LG 34UM64-P SPI flash dump\firmware needed
                by beebuzzin
                Hello! I am new to this site but I'll explain my issue.
                I have an LG 34UM64-P that will not boot and just bootloops with the power button flashing white every second. From my research, its likely a corrupt firmware. So I could use a verified working dump to reflash my monitor's BIOS. I have searched as much as I could and heard this place might have a copy.
                I have a CH341A and have dumped a copy of my corrupt BIOS. Any suggestions are appreciated!
                Chassis #:
                9H1M003K-0005 (with serial/barcode identifier G0971072YJ / 64360402)...
                10-16-2026, 11:37 PM
