Repair Synology DS118 - fsbl fail - RAM already changed
  • DriversScrew
    • Dec 2021
    • 24
    I've got a DS118 (Board Model name: HDR11L1) stuck at the very first stage of boot with console output:
    Code:
    C1:80000000
    C2
    C3h
    hwsetting size: 000006DC
    C4
    f
    5-5verify fsbl fail
    0000003BC7
    C1:80000000
    C2
    ?uu3-1
    I found this similar issue on the web and changed both RAM BGAs on my board but without any change.
    I successfully tested the synology RAM swapped to a standard SODIMM module.
    The cpu and mem voltages seem to be generated by a 32-qfn marked W27N 2227. Is there a real name/datasheet for it?
    Any help for fault finding is gratefully accepted...
    • 31084
    Re: Repair Synology DS118 - fsbl fail - RAM already changed
    fsbl??
    bootloader?
    try reflashing the boot chip
    • DriversScrew
      • Dec 2021
      • 24
      Shouldn't there then be an error like
      Code:
      SF: Detected MX25U6435F with page size 256 Bytes, erase size 64 KiB, total 8 MiB
      *** Warning - bad CRC, using default environment
      SF: 3014656 bytes @ 0x90000 Read: OK
      SF: 4587520 bytes @ 0x370000 Read: OK
      ## Booting kernel from Legacy Image at 08000000 ...
        Image Name:  Linux-3.10.102
        Image Type:  ARM Linux Kernel Image (uncompressed)
        Data Size:  2410000 Bytes = 2.3 MiB
        Load Address: 00008000
        Entry Point: 00008000
        Verifying Checksum ... Bad Data CRC
      if it is flash related?
      As far as I understand, my system halts already before this.
        • 31084
        there are several loaders that load each other.
        the cpu has one that loads the serial flash into ram and runs it,
        then the one from the serial flash loads the actual o.s. - if it's linux then it may load another bootloader such as GRUB.
        • DriversScrew
          • Dec 2021
          • 24
          In my case only RTD1296 cpu commands are available. The console is connected via USB-TTL converter to the board.
          So the fault must be in a very early stage. fsbl = "first stage boot loader"???
          Edit: I managed to read the flash contents with a programmer. How to check if flash content/bin is valid?
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8212
            first look if the flash itself is getting bad... copy the content of the flash then FF it.
            • DriversScrew
              • Dec 2021
              • 24
              No problem with erasing, flashing and verifying the content.
              The flash chip itself (MX25L6433F) seems to be fine.
              I wonder how I could measure the voltages of the RAM chips, if all are stable?
              There are two unpopulated RAM places in DS118. Maybe I can check with an oscilloscope there?
              I found the datasheet for RAM, but not for the "W27N 2227" device...
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8212
                Look at the data lines on the flash chip? If they are o.k. then the only option you have left is to program a known working file on there. Sure... check the voltage rails for AC on the caps.
                • edunotebook
                  • Apr 2022
                  • argentina
                  Hello, I am needing the bios bin file, since mine is corrupted and does not start
                  • DriversScrew
                    • Dec 2021
                    • 24
                    As far as I know it isn't possible to simply change the flash bin file. You have to adjust serial and checksum, maybe other parameters, too?
                    • DriversScrew
                      • Dec 2021
                      • 24
                      Changed the flash chip, copied the content of original flash over before, but without any change.
                      • validan92
                        • Jun 2019
                        Does anyone have by chance a bios for this model ? mine got messed up , and its stuck at blue light .
                        • Sus256
                          HISENSE 65E7KQ PRO - no boot
                          by Sus256
                          Hi all!
                          HISENSE 65E7KQ PRO
                          RSAG7.820.13512 - chassis
                          MT9618BAATAB - cpu
                          RSAG7.820.12059 - power
                          HD650Y3U77 - panel
                          KLM8G1GETF - emmc
                          Replaced emmc.
                          Terminal log
                          UART
                          AC_ON
                          E-B
                          FDE enabled
                          06-01-2025, 02:11 AM
                        • dragometin
                          Hitachi 40HYC42
                          by dragometin
                          TV Model: Hitachi 40HYC42
                          Power Supply: 17IPS71
                          MainBoard: 17MB95M
                          Panel: VES400UNDS-2D-NO3
                          When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                          I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                          Is there any variants on 17IPS71 power supply's?
                          UART output pins 10 and 12 on scart connector:
                          Code:
                          12:24:04.595
                          08-08-2024, 05:53 AM
                        • throwaway327
                          by throwaway327
                          Model No: RC72LA
                          Serial No: SBNVKD001014459
                          06-18-2025, 05:52 PM
                        • hinisa
                          Xiaomi router freezes at boot after re-capping
                          by hinisa
                          I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                          When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                          After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                          Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                          07-08-2023, 05:58 AM
                        • tarek5313
                          chromebook enrollment, not done by RCunlocker
                          by tarek5313
                          RCunlocker is very good tool but technology change over time and this tool is not updated for long time now
                          ok here is why and the solution
                          the why?
                          g00gle have changed how the machine ID is generated now so they can assign MDM policy to machine, its not S/N anymoe rather the "stable_device_secret"
                          the solution:
                          very simple, just to provoke that ID, usually i just flip the last two bytes of that ID, maybe someting else will do the trick? in theroy YES, but this is what works for me
                          HOW TO:
                          just fire any hex editor and find "stable_device_secret_DO_NOT_SHARE@"...
                          05-18-2023, 08:45 PM
