xbox one s power on beep power off
  • Themi
    • May 2020
    • 79
    • Scotland
    Hi all
    I have an xbox one s which looks to have been water damaged and can't stay powered on. Powers on for a second with a light + beep then powers off.
    I've removed as much of the water damage as possible.
    I have 1.1v, 1.8v, 3.3v, 5v, 12v rails
    All 3 power fet rails are good and each fet tests ok, this includes the two behind the front panel connector.
    I've checked ports for damage leading to possible shorts.
    All large inductors + any small ones I can find for shorts but found none.
    I've tested all inductors + resistors under the sb for shorts and found none.
    Anyone have any ideas where I can go from here? I am pretty much out of ideas and starting to think my issue might be sb or apu related (erring towards apu)
    • 31051
    Re: xbox one s power on beep power off
    i was watching a long video yesterday that may help
    https://www.youtube.com/watch?v=jT2fFuvBy8o
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
    • Unspun01
      XBOX One no power, random.
      by Unspun01
      XBOX One original, not XBOX One S. Has problems turning on.
      Power supply is good. Touch panel is good. Both work in another xbox.
      HDMI and USB ports are fine.
      The last time this XBOX turned on, it had an ERROR 102 so I know it can turn on, and I know it may have a hard drive issue. But the power issue is driving me nuts.
      When power supply is plugged into xbox, there is no response from the XBOX. Cannot power on, or eject. No lights. no sounds, not even a fan twitch. Power supply LED remains orange.
      Voltages are measured all over...
      03-24-2020, 01:19 PM
      03-31-2024, 02:12 PM
    • flusher
      Apple MBP16" A2141 820-01700 PMIC power cycles no boot no shorts
      by flusher
      Bought myself a project thing. Apple MBP16" A2141 820-01700
      No shorts, no visible waterdamage.
      Dead. no history.
      All USBC ports do 20V and charging battery.
      If you plug battery/charger PPBUS is 12.6v and all power rails like RTC, 3v3, 5v etc are present. U7800 PMIC all voltages are present APART from PPVCCPRIMCORE_PRIM_REG (not sure if it has to be present at this stage?! resistance is 40 Ohm). SSD 2.5, 0.9, 1.8 are present on both wings. Charger meter shows 30ma or something like this on charged battery.
      But what PMIC does is that it power cycles(dropping to...
      02-21-2025, 03:12 PM
