Ps3 Fat 60 gb RED LIGHT
  • lordgeny
    • Apr 2016
    • 223
    • Italia
    Hi guys i already checked the hard drive and its ok ..
    its gpu failure =?
    https://youtu.be/yTjMAt4szrE
    • 31003
    Re: Ps3 Fat 60 gb RED LIGHT
    very rare,
    usually it's the prodalizer capacitors or the psu module.
    • lordgeny
      • Apr 2016
      • 223
      • Italia
      Nec tokin?
        • 31003
        yes
        • lordgeny
          • Apr 2016
          • 223
          • Italia
          i replaced all nec tokin with 470uf caps , first time was working , but only with one xclamp not fully screwed up. Second time no more boot and after full short on 12v , now i removed every caps and solder just want to make from scratch . Short is gone .
          I scratched in the center for convenience but it is gnd anyway.
          • lordgeny
            • Apr 2016
            • 223
            • Italia
            i found one of the caps is in short / beeping and 0.000 in 2k scale.... whats the problem.... i buyed from aliexpress can be rubbish ?
              • 31003
              what caps? tantalum?
              could be shit, but i never had a bad one.
              maybe reversed? too much heat from soldering?
              can you link what you purchased.
              • lordgeny
                • Apr 2016
                • 223
                • Italia
                https://a.aliexpress.com/_vSbfvh
                can i post the value of pad ex nec tokin cpu side and mosfet side ?
                just to check is everithing are ok
                  • 31003
                  not sure what you mean?
                  • lordgeny
                    • Apr 2016
                    • 223
                    • Italia
                    i have this value , are ok ?
                      • 31003
                      no idea.
                      try asking here:
                      https://www.psx-place.com/forums/#pl...ion-3-forums.5
                      • Technomancer
                        • Nov 2021
                        • 20
                        The correct way to diagnose PS3 YLOD (it briefly flashes yellow before going red) is with the syscon diagnostic method using a USB to TTL converter, soldering a few wires to specific test points on the board, and using a wonderful script someone wrote to connect to the syscon and get it to spit out error code.
                        This guy's video is a little long but between the video and the items he has in the description, it should get you everything you need to get the syscon to spit out the error code for you. Once you get the codes, you can go here to see what the actual problem with your PS3 is: https://www.psdevwiki.com/ps3/Syscon_Error_Codes
                        Long gone are the days of just replacing the NEC Tokin caps and hoping that was the cause of your YLOD
                          Laptop computer that went completely dead no boot no power light no hard drive light
                          by sam_sam_sam
                          See pictures for type of laptop computer
                          I checked switching power supply brick 19.2 volts multi meter only
                          No booting without switching power supply connected
                          Checked switching power supply with an (28 volt ) incandescent light bulb it lights then hooked up the switching power supply again now the laptop and boots like normal
                          What the heck is going on here...
                          04-04-2025, 04:58 AM
                        • freakaftr8
                          Asus a15 FA507RE-A15.R73050T failure
                          by freakaftr8
                          So this laptop seems to have some kind of failure. I bought it second hand and originally the previous owner said that they went to turn it on and it was presented with a quick flash of the power light the keyboard lit up and then the keyboard shut off and the power light went off as well but the battery indicator was white and after about 5 to 7 Seconds flashes orange really quick then shuts off and goes back to White. If the power button is pressed again the keyboard lights up really quick and then repeats. When I got it I could press the power button multiple times the keyboard light would...
                          03-28-2024, 10:58 PM
                        • federalhouse
                          **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                          by federalhouse
                          I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                          **Background:**
                          I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                          **What I've Tried So Far:**
                          1. I accessed
                          08-01-2024, 07:03 PM
                          LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                          This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          09-07-2024, 03:40 AM
                          LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
                          This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          09-06-2024, 09:10 PM
