Electrical heater controler
  • tomalamix
    • Nov 2020
    • 32
    • Portugal
    Hy guys!
    Today Im posting a few photos from my electrical heater controller.
    The thing is that it turn on just right but as soon as the backlit comes in when I press the UP / DOWN temperature buttons the displays fades at such a point that the display fades completely progressively in 1-2 secons, its noticeable the display fading away, then the backlit stays really weak and the power LED goes out.
    Everything comes back to normal after a 10 seconds that is the time the backlit should remain ON while i change the temperature setting.
    Besides this, as long as I don't touch the temperature setting it works, I can see the temperature in the display (because the backlit is not turned ON).
    Below I attach a picture of the PCB from where you can see several capacitors, all JACKCON
    I've took one out, the 4.7uF 100V that is near the small yellow transformer (that feeds the backlit among other things) and it reads 4900nF , 10ohm for ESR and Vloss 4.5%.
    The value seems OK but im not sure about the ESR and the Vloss, I'm not a electronics expert but i would like to repair this unit, so i think I can count with your expertise by looking at the PCB photos and giving me some inputs, all are valid.
    I have several other electrical heaters becoming like this one: when the backlit kicks in the displays fades completely.
    • Jul 2011
    • 6037
    Re: Electrical heater controler
    Originally posted by tomalamix
    Hy guys!
    I would say that if 4.7uf at 50 volts has a value of 10 that is way to high now if it at 100 volts or more this value might be still a little bit high the best thing is if these capacitors are not brand name capacitors replace them for good measure ( I would highly recommend that you replace this capacitor first and see if you still have this issue )
    **** Use caution doing this *****
    Here is something you might try if you can find the power supply rails for the heater controller portion ( this will probably be a voltage around 5 volts or so it might be a little bit higher than this ) of the circuit and can power it up from there and just operate the the controller with out the heater element and see if you have the same exact issue that will help you narrow down what part of the circuit is giving you this issue
    But my guess is that there is an issue with the switching power supply portion of the circuit board and this is why when you put the heater on the power supply rails are draining down completely or nearly that way and this might be because of a bad capacitor on the switching power supply regulator or something is wrong with the controller part that turns on the heater element
    I have one question for you and that is this what device turns on the heater element is it a relay or some type of ic device of some type
    I hope this helps you figure out what going on with this device
    • tomalamix
      • Nov 2020
      • 32
      • Portugal
      Hy sam_sam_sam!
      Thank you for your input.
      I dont have a power supply to put 5V inside the controller rail and at this moment, but i can explore that
      About the heating element, its clearly a relay, it's covered with that hot glue that you can see in the picture, but that one is working properly, it turns off the heating element when the temperature reaches the desired temperature and turns on when the temperature is dropping too much.
      The appliance works 100% IF i dont touch the buttons that makes the back lit come on, if i do that it seems the power is all drained out to the back lit and can't hold the back lit on nor the display - it remains like that for 10-15 seconds (its the time that the back lit should stay on)
      thank you
        • Jul 2011
        • 6037
        Then the most likely issue is that capacitor that you checked by the switching power supply transformer because if you look closely at where this capacitor is it should be very close to an ic chip that is some type switching power regulator or a off line switching device
        One thing you can try is disconnect the back light and see if does the same exact thing if dose then you have a switching power supply issue if does work correctly with out the back light then you could have an issue with the back light or still have a switching power supply issue
        • CapLeaker
          Leaking Member
          • 8135
          Can we see some high res pictures?
          • R_J
            • 9535
            180 x 83 pixels is too small to be usefull
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              ^^I uploaded the originals to the OP.
              • tomalamix
                • Nov 2020
                • 32
                • Portugal
                Sorry, i thought i did uploaded those correctly. I have the controller disassembled, if you need some closer picture to some area please tell me.
                Meanwhile I'm going to try changing that capacitor 4.7uF 50V that is reading 4900nF, 10ohm for ESR and Vloss 4.5%. Unfortunately will be a JACKCON again, my local eletronics store doesnt have another brand. Later and if the problem is solved I'll go for Panasonic or Rubycon.
                If you guys see anything else worth to test please tell me, I'm getting used to test my new ESR02 Pro
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  Sometimes supplies like these use a capacitive dropper: then the value of the yellow X class capacitors is very important (that it has not degraded in capacitance value).
                  I'm not sure if this is such a device, I do see a small transformer so maybe not, but won't hurt to chuck (as long as it is discharged lol)
                  • tomalamix
                    • Nov 2020
                    • 32
                    • Portugal
                    Ok, Im going to remove both just now and will write the result right away:
                    Ok, both rated for 275V, one is 0.47uF, while testing gives me 259.7nF with 3.8ohm ESR. Almost half the capacitance it should have.
                    The other is a 0.15uF and reports 1005pF, no ESR value (strange...). The reading is wayyyy too low. Should i do some other testing to be sure? I've disconnected only one leg of the capacitors, discharged both and done the testing.
                    • CapLeaker
                      Leaking Member
                      • 8135
                      I'd change the 275V 0.47uF and the 4.7uF 50V and see what happens.
                      • tomalamix
                        • Nov 2020
                        • 32
                        • Portugal
                        Ok, i'll go for those two, but what about the 0.15uF that reports 1005pF ? It's not worth to swap too? Am I doing something wrong? Sorry for the silly question..
                        • Per Hansson
                          • Jul 2005
                          • 5895
                          • Sweden
                          Yes you should change them both, and when you get the new ones test them on the meter:
                          Because it needs to be properly calibrated to be able to show values this low with confidence, so it will be a good test for the meter too
                          • tomalamix
                            • Nov 2020
                            • 32
                            • Portugal
                            Ok, i've tested the ESR02. The new capacitor 4.7uF 50V is reading 4800nF, 4ohm for ESR and Vloss 3.5%. It's not perfect but better than the previous.
                            The new 0.15uF reports 145nF, no ESR value again and no Vloss. At least the capacitance is in the right range.
                            The 0.47uF testing gives me 480nF with 4.8ohm ESR, no Vloss value too.
                            Everything assembled and the unit worked properly!! But only for...20 seconds...
                            The back light was on, the power LED was on and I was changing the temperature setting with everything visible in the LCD, but all that stopped working in a few seconds and never came back again. Now I can't turn on the unit, no LED, noe LCD, no relay kicking in, nothing...
                            I've opened everything again but I can't see anything out of the place, i'm lost now..
                              • Jul 2011
                              • 6037
                              The 4.7uf@50 volt is still a little to high it would be better if was 1.something to maybe 2.something but this might be pushing it depending on what the circuit is requiring ( mind you this is a new capacitor for this value )
                              I do not have any 0.47uf you do have the voltage listed 4.8 might be a little high as well I have to look and see if I have any of this value
                              Have you found a switching power supply regulator on this board yet if you do list the part number for it so I can look up the data sheet for it
                              • CapLeaker
                                Leaking Member
                                • 8135
                                Can you upload new straight shot high resolution pictures? Maybe we can see something where the smoke came out.
                                Check for DC voltage at the bridge rectifier next to the 0.47uF cap. Recheck the other cap for proper orientation. Check for open or higher in value resistors than spec. Bad diodes… etc.
                                • tomalamix
                                  • Nov 2020
                                  • 32
                                  • Portugal
                                  Ok, i've uploaded the photos, I don't have any other camera then the phone so this is waht I can send. Searching around I can't see anything out of ordinary, nothing roasted, not even that typical smell is present.
                                  Some notes about the photos, I've rebuilt a track that i've destroyed near the polyester capacitor, but it was working before so the problem isn't there. Another thing is that the new polyester capacitor is 310instead of 275V if that matters.
                                  About the rectifier, I see there a BC B10S just after the polyester capacitor., is this a rectifier? This means something to you? Is the one near the right yellow capacitor.
                                  Ok, meanwhile I've been reading around and this BC B10S is a two in one diode, it rectifies the voltage from AC to DC, right? Instead of having two separated diodes doing that there is this BC B10S.
                                  Done some testing between the rectifier poles, the ESR02 gave be me a thing like: 2* >| (DIODE SYMBOL) \ 2 >| 3 >| 2 \ Uf= 2,23V 700mV
                                  On the other "channel" gave me 2* >| (DIODE SYMBOL) \ 2 >| 3 >| 2 \ Uf= 700mV 2,23V
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8701
                                    I don't know where the "BC B10S" you're working with is on your board.
                                    I can see a BR3 designator on the PCB and that's a bridge rectifier that should contain 4 diodes. Having 4 pins I'm not sure how you got it into a 3-pin avr transistor tester?
                                    Hmm...capacitor dropper psu...
                                    • R_J
                                      • 9535
                                      B10S must be the numbers on the bridge rectifier BR3, this bridge contains four (4) diodes.
                                      • tomalamix
                                        • Nov 2020
                                        • 32
                                        • Portugal
                                        Well, I've tested it, i've connected the 220V on the line of the PCB and measured the output on the B10S. There is 2.4V, i think its working properly.
                                        Meanwhile I've detected a pin without proper grounding, the wire that connects there is not conducting properly, I'm going to change this wire and test again everything, i'll keep you guys posted
                                        • sew333
                                          Apartment to buy with coal heating. Any sense to buy electrical heater and new pc?
                                          by sew333
                                          Hi guys. I have an question. Overall i am currently selling my house ( apartment with 1 room ) to buy some cheaper with 1 room too, and save cash for new pc in autumn 2024.
                                          So i choosed some cheaper apartment in smaller city,but there is coal heating. I dont wanna heat for coal.
                                          So i m thinking to buy electrical heater. And my question . Is this any sense to buy electrical heater when i will be using new pc with rtx 5090 and new intel ( when will be released ) ultra + Psu Seasonic 1600W?
                                          I expect that i will pay more for bills. But i wanna know this. Will using electrical...
                                          06-14-2024, 07:30 AM
                                        • edugimeno
                                          Vaillant 242 Gas Water heater. Shortcut in board anc compatibility with model 282
                                          by edugimeno
                                          Hi!!
                                          Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
                                          I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
                                          At a certain point, moving stuff around, I put all wires back in place and...
                                          03-24-2024, 02:31 PM
                                        • CapLeaker
                                          AcuRite 5 in 1 temperature sensor replacement repair
                                          by CapLeaker
                                          Got a new victim:
                                          AcuRite 5 in 1 Iris outdoor weather station not updating the temperature / humidity anymore. The original sensor is a SHT21. Also there are identical other sensor manufacturers. I chose the HTU21D to replace the original SHT21. Both have identical specs. I've had two failure modes with these sensors.
                                          A: outside temp stuck at -40? It's cold here at times in Canada, but not that cold!
                                          B: stuck at some temperature and maybe updating once in 12 hrs or so.
                                          Easy solution is to go to AcuRite website and purchase the sensor. Right?...
                                          04-15-2025, 01:32 PM
                                          Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                                          by sam_sam_sam
                                          I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                                          I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                                          12-16-2023, 08:39 PM
                                          Surface Mount Fuses Fundamentals Datasheet
                                          TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                          TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                          10-07-2024, 06:07 AM
