150 Watt UV LED LIGHT
  • freakytiki4u
    Coolest Member
    • Aug 2009
    • 130
    Anyone know what the part in blue is and where I might get one? This 150 watt LED light stopped working after only about 6 months so I took it apart and visually all I can that may be bad is that part circled in red. It appears to be encased in resin but I can get to it and solder on a new one. Any help in identifying the part and where I might get a new one would be very appreciated.
  • R_J
    • 9558
    Re: 150 Watt UV LED LIGHT
    That is a bourns MOV (digikey: MOV-07D241K-ND) It should check open as it is likely across the ac line input. If it checks shorted it would have blown the fuse as well. It can be removed to test the unit as it is for spike protection
    • diif
      • Feb 2014
      • 6978
      • England
      It's a varistor, the brown stuff is just flux as it had to be soldered after the smd work.
      • freakytiki4u
        Coolest Member
        • Aug 2009
        • 130
        Thank you for the replies. I will check the fuse. It probably popped.
        • freakytiki4u
          Coolest Member
          • Aug 2009
          • 130
          So they fuse isn't bad and the power cord is not bad but I don't get 120Volts to the fuse. This stuff is all surface mount so I'm not sure how to proceed from here (or sure if I even can). Any suggestions?
            • 31094
            what voltage do you get across the varister?
            remember it's all clearcoated so you have to poke the meter probes through it.
            • freakytiki4u
              Coolest Member
              • Aug 2009
              • 130
              I get nothing at all at the fuse. I scraped the gel stuff off so I get bare metal but no voltage at all, which seems weird to me. I have not tried the Varister because I don't even get voltage at the fuse just before it.
              Last edited by freakytiki4u; 12-25-2021, 11:49 AM. Reason: I was talking about the wrong part
              • freakytiki4u
                Coolest Member
                • Aug 2009
                • 130
                I just tested the Varister and there is 120 volts there on the left leg, nothing on the right leg.
                  • 31094
                  one leg should be neutral - the other is live.
                  try the bridge rectifier DB1
                  • redwire
                    • 3910
                    Note it looks like Hot/Line (black) first connects to the MOV and then the bridge rectifier IC. It looks like Neutral (white) has the fuse in series? That would cause confusion.
                    Instead of working on it powered up, I would instead take some ohmmeter readings with power off. See if the mains cord has continuity to the bridge rectifier.
                    P.S. what are you doing with so much UV? Everybody glows nowadays lol.
                    • freakytiki4u
                      Coolest Member
                      • Aug 2009
                      • 130
                      I will check the BR in a bit, have family arriving for Christmas. As to what I need that much glow power for, lol I think you're going to love this! I built an 8 foot tall and 4 foot wide glow in the dark sasquatch out of resin and glow powder (see attached pic). I have video on my youtube channel called "Green Man Productions" that you can watch if you are so motivated. Let me know what ya think of my Sasquatch.
                      • R_J
                        • 9558
                        That is because the mov is connected across the ac line. so you should have 120vac ACROSS the mov, If you do not, I suspect the fuse is in the neutral line (white wire), check if the fuse is open. If you have 120VAC ACROSS the MOV, then check across the bridge rectifier (S) to (S) for 120vAC,
                          • 31094
                          i'm disapointed,
                          i thought you where growing weed or building a security post to detect vaxed zombies!
                          • freakytiki4u
                            Coolest Member
                            • Aug 2009
                            • 130
                            LMAO too funny!
                            • redwire
                              • 3910
                              There's an open-circuit somewhere on this LED board, 96 LED's and 20-24 IC's you would expect a bit of life. That 6A fuse would only pop if a short happened.
                              Soldering looks poor on one edge of all U16-20, somebody retouched the other side though. Not sure how the strings are configured or the IC part number.
                              I went on a fixup date with a woman that told me at night time she is visited by what looks to be glowing on your front lawn. The things they did to her!
                              • freakytiki4u
                                Coolest Member
                                • Aug 2009
                                • 130
                                I think I know her lol
                                  • Jul 2011
                                  • 6046
                                  I was wondering the same thing
                                    • Jul 2011
                                    • 6046
                                    Really cool
                                      Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                                      by sam_sam_sam
                                      I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                                      The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                                      Now...
                                      06-09-2024, 10:57 AM
                                      LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                                      This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-07-2024, 03:40 AM
                                      LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
                                      This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-06-2024, 09:10 PM
                                      09-06-2024, 08:40 PM
                                    • serious_electron
                                      Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                                      by serious_electron
                                      Hello Everyone!
                                      I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                                      06-28-2025, 02:57 PM
