Nintendo Switch Parts
  • steven91919191
    • May 2020
    • 15
    • United Kingdom
    I have a Nintendo Switch here that i will be replacing the LCD Driver IC on but both diodes in this area are bad so i need to replace these. I can't find the rating on these anywhere online (to buy or just to get the information).
    Does anyone know the ratings and/or sizes of these two diodes that's right next to the LCD driver and group of caps?
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Nintendo Switch Parts
    If you dont get any help finding the parts maybe ask also on this forum
    https://www.facebook.com/groups/console.repair.legion/
    • steven91919191
      • May 2020
      • 15
      • United Kingdom
      Thank you so much, I will
      • Dvsr
        On M-Audio AV40 active studio speaker's two zener diodes get really hot.
        by Dvsr
        Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
        I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
        After replacing the caps I started testing out the speaker. It seemed...
        09-10-2025, 10:20 AM
        Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
        This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
        09-06-2024, 05:30 AM
      • caspian
        What Zener Diodes on a Linear Power Supply
        by caspian
        Dear members,
        I have a linear variable power supply with unknown brand name that I used for voltage injection.
        Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
        In addition, I discovered that its zener diodes are defective.
        I can replace the burned transistors.
        But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
        Therefore, I cannot replace the zener diodes.
        I do not want to test the zener diodes in a test circuit to discover their model or value.
        no schematics are available...
        05-26-2025, 12:38 PM
      • Tomylee
        No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
        by Tomylee
        Sorry for the person who’s going to read all this !
        I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
        While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
        During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
        07-11-2025, 11:52 AM
      • estabilito
        Nintendo Switch Oled dead
        by estabilito
        Hello, i bought dead nintendo switch oled.
        after plugging charger with amp meter device shows 5v and 0,0 or 0,02 amperage draw.
        I inspected motherboard and someone tried to reflow or replace m92t36 and didn't do it well, i resoldered it proper and find that usb-c fuse was blown too(replaced it).
        After this device started to draw 15v and something around 0,48 but only for few seconds after this returned to 0A draw.
        I tried to plug motherboard without battery - shows 15 0A and when charger was pluged i put battery back in then console started to charging battery but stuck...
        05-07-2024, 03:48 PM
