Micronta Talking Alarm Clock Full Recap
  • jayjr1105
    • 281
    My grandfather had this Micronta VoxClock3 digital alarm clock that just had random digits displayed when you plugged it in and just overall acted crazy. Opened her up last night and found every single cap either completely open or ESR in the 50 ohm range. All caps replaced but waiting on a .47uf 50v cap to arrive as I didn't have any.
    Ryzen 3600x
    16GB Patriot 3600MHz
    MSI B450 Gaming Plus
    MSI Air Boost Vega 56
    Acer 32" 1440P Freesync
    Rosewill Capstone 750W
    Hakko FX-888D Station
    FX-8802 Iron
    MG Chem .8mm 63/37 RA 2.2%
    • 30991
    Re: Micronta Talking Alarm Clock Full Recap
    .47? use a polyester cap - 470n
    • jayjr1105
      • 281
      I don't have any of those lying around either. Need to invest in a polyester assortment.
      Ryzen 3600x
      FX-8802 Iron
        • 30991
        well even 1uf electrolytic caps are being phased out because film caps are small enough to replace them.
        what chips are in that clock?
        spo250? spo256? texas tms5110??
        • jayjr1105
          • 281
          My pic is out of focus, I'll check soon
          Ryzen 3600x
          FX-8802 Iron
          • jayjr1105
            • 281
            Here you go. Probably late 80's early 90's by the date codes on chips.
            Ryzen 3600x
            FX-8802 Iron
            • redwire
              • 3906
              It came out in 1986? https://www.radioshackcatalogs.com
                • 30991
                nice, i wonder if the sample rom has been dumped!
                • redwire
                  • 3906
                  TMS5110 speech synthesizer was in TI Speak & Spell, it used LPC linear-predictive coding. I think it had better speech quality than SPO256 allophones.
                  It looks like it could use a 1-bit or 4-bit databus to read ROMs. One IC must be the main MCU and another ROM.
                  TMS5110AN2L-1
                  MP1343
                  CM72010NL
                    • 30991
                    it uses a custom databus for the roms - there are replacement projects online.
                    • jayjr1105
                      • 281
                      Got the new .47 cap today and installed. Powered up without the daughter board even being re-soldered back in and it's working great! good crisp digits, no funny business. I'll post later on once I have it fully back together.
                      Ryzen 3600x
                      FX-8802 Iron
                      • jayjr1105
                        • 281
                        All done, working great.
                        Ryzen 3600x
                        FX-8802 Iron
                        • ChaosLegionnaire
                          HC Overclocker
                          • Jul 2012
                          • 3264
                          • Singapore
                          good fix! yet another happy old folk! this past year has been bad for them. good to fix their stuff for them and make them happy again! thats if u are fixing it for them to return it to them and not if u get to keep it if u fix it...
                            • 30991
                            i like the colour, that's done using red leds behind a purple filter isnt it?
                            • redwire
                              • 3906
                              I need a video or sound snip to hear what it sounds like
                              In the 80's many red LED displays were behind a purple filter. I think it works much better for contrast (compared to red).
                              edit: youtube versions are crap https://www.youtube.com/results?search_query=voxclock
                              • ClockChip
                                • Jul 2023
                                • 14
                                Am I right in thinking that failing caps is a relatively rare phenomenon with this particular clock? O, rather, is this a widely-known problem with the VC 3 and most owners simply choose to bin their clock rather than taking the time and trouble to repair it?
                                (I ask because I was quite surprised to find a mere single mention of this nearly forty-year-old clock on the forum. Perhaps my sense of surprise is misplaced?)
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8699
                                  Capacitors have limited lifetime and people tend to throw away clocks after they...get their cell phones?
                                  • jayjr1105
                                    • 281
                                    I have this clock back in my possession. My grandfather claims it still acts weird after some time. I'll take it apart and give it a closer inspection for cracked solder joints.
                                    Ryzen 3600x
                                    FX-8802 Iron
                                      • 30991
                                      not enough info,
                                      you should have asked if he meant the display or the speech
                                      • ClockChip
                                        • Jul 2023
                                        • 14
                                        Can you please ask your grandfather whether the clock kept accurate time until recently?
                                        I ask because, rather than using the 60 Hertz mains to maintain accuracy, this particular clock relies on the MCU frequency; I am not clear on why the manufacturer would do this (perhaps someone here knows?). However, I am informed this is not an accurate way to keep the clock synced when using the simple RC oscillator the clock was designed with.
                                        (I know of no one else who owns one of these, so I hope you will not mind my asking.)
                                        • shelby5041
                                          clock radio / radio lifespan?
                                          by shelby5041
                                          hi
                                          ive got a modern digital clock radio approx 15yrs old
                                          my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                                          since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                                          the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                                          it uses very little power just a few watts i would imagine that may have something...
                                          09-14-2024, 03:30 AM
                                        • Tom41
                                          Honeywell Accenta G3 tamper alarm
                                          by Tom41
                                          This house has a Honeywell Accenta G3 alarm system. If the main unit loses power for any reason, the external siren sounds - even if the alarm is not even armed! Entering the code to disarm it is not an option as the keypads are completely dead when the power is out.
                                          I presume this means the backup battery inside the box has failed, but I can't get in there and replace it without also setting off a tamper alarm! Is there any way to disable the tamper alarm so that electrical work can be carried out with the power off? Or a way to replace the backup battery without setting off the...
                                          08-31-2023, 04:00 AM
                                        • slybunda
                                          Alarm Siren issue
                                          by slybunda
                                          Apologies if this is in the wrong section but being a car alarm siren that makes noise i thought it be best to put it in the audio section.
                                          Had weird alarm issues where siren made a strange noise: https://www.youtube.com/watch?v=ZjsqndhionU
                                          took siren out of the car and checked it out and pics attached seem to be the source of the issue.
                                          shockingly the alarm still makes its normal sound if i trigger it manually so speaker seems to be intact.
                                          getting a replacement is gonna be next to impossible, its a Toad Ai606 which is no longer in production and cant see to find a replacement...
                                          02-04-2024, 11:01 AM
                                          ASUS P5GC-MX motherboard recap
                                          by momaka
                                          Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                                          This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                                          So here is what the motherboard looked like with its original caps:
                                          CPU VRM area up close…...
                                          01-27-2021, 11:59 PM
                                        • Ady2017
                                          Does anyone know about 16x2 LCD screens used in alarm keypads?
                                          by Ady2017
                                          I have got an old Gardtec GT595 alarm which has got a faulty keypad with a failed LCD screen. This was apparently a very common problem with these and many people have had to replace the whole alarm because of this problem. Somebody claims to be able to repair the keypads by replacing the screen and I have tried it myself by replacing the LCD with a commonly available HD44780 1602 16x2 Serial LCD screen but it is not working. I am sure it is a problem with a driver or simular which is not allowing the screen to talk to the rest of the electronics. Does anyone know what this original screen was...
                                          06-02-2025, 04:56 PM
