Fluke 289 multimeter not working
  • Pauldg1
    • Apr 2021
    • 11
    • Netherlands
    Re: Fluke 289 multimeter not working
    Thanks,
    I will check Q22 and power supply voltages.
    And I will try to access debug console
    with ExtraPuTTY (if MCU is working).
    • Pauldg1
      • Apr 2021
      • 11
      • Netherlands
      I have checked some voltages on the board.
      I noticed that the 5V after U17 (5V LDO) is present only for 18,6msec after startup.
      See attachement with plot of output U17 after turning on multimeter.
      After startup the enable pin of U17 is made low for only 18,6msec by the MCU M340F. So most of the time the 5V is 0,7V instead of 5V (TP3).
      The 32kHz is present on xtal near M430F. Another board voltage is 3,046V, for example on C42.
      I don't see debug information on TX of J5. Should it present when turning on multimeter?
      Hope this info help to explain why 5V enable pin is turned off by M340F.
      • MMH3
        Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
        by MMH3
        i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
        Never ever i experienced problems with that.
        Now i have one 5050sff machine, where this jumper isnt working at all.
        I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
        The history of the machine is that i used it in my office...
        03-23-2025, 09:28 PM
      • DynaxSC
        GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
        by DynaxSC
        I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
        There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
        The board is generally working now, all PCIe ports are working, Windows installs normally.
        However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
        The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
        03-10-2025, 12:27 PM
      • obelix24
        Macbook Air 2020 (a2179) - touch id not working
        by obelix24
        Hi i have one Macbook Air 2020 where touch ID is not working (it's not scanning fingerprints). Touch ID was working before, there is no error message during scanning fingerprint it's just not scanning on screen you can see only fingerprint but there are no red updates as when it's working. Power button is working fine.
        I've checked boardview and also schematics but i'm not able to find anything related to TouchID ... i have similar issue on a2338 where there was problem with PP3V0_TOUCHID​ and after replacing UT610 it was working but here i'm not able to find anything related to...
        02-09-2025, 12:57 PM
      • tmhobadcap
        Multimeter LCD Display not working
        by tmhobadcap
        I have a Sanwa CD-720C multimeter. Recently, it is not working. There is no display when it is turn on. But when I use the continuity test, it still can produce sound when the two leads are touching each other. Therefore, I suspect it is just the display not working. I have checked that the fuse is okay. What will be the possible cause? Can it be fixed?...
        05-16-2021, 08:36 PM
      • hopkok
        Lenovo Legion 16ITHg6 NM-D721, keyboard not working, LEDs too
        by hopkok
        Hi masters, I need your help.
        I am working on Lenovo Legion 16ITHg6
        Motherboard number NM-D721, no BV, no schematic but I am attaching very closes ones.
        INPORTANT: My motherboard version is with IT8258 IC, that is controlling keyboard and RGB LEDs.
        My problem is on UI142, +3VALW_AG is not stable, floating from 0V to 3,3V.
        AGKB_PWR_EN_N signal is floating too (that is why+3VALW_AG not stable).
        Power LED is not working as well, power button working well.
        UI26 ??? is there any firmware too? Powered by +3VALW_AG.
        Motherboard...
        05-04-2025, 09:35 AM
