Yaesu FT1000MP mk.5 receive issue.
  • steviewonder
    • Dec 2013
    • 183
    • england
    Hoping some knowledgeable persons may know the fix for this problem.
    It's the 200W version. Originally,the receive was totally deaf,with a s/c rectifier type diode,along with a cooked pin diode.,a FAIRLY common problem it seems.
    Now it receives fine,but the signal can drop after pushing and releasing the PTT switch,sometimes down to nothing at all.It will stay like that,until PTT is pressed again,and rx comes back to life.
    There is the odd mention of this on google,but no answers.
    There must be a cure,any help greatly appreciated!
    • 31265
    Re: Yaesu FT1000MP mk.5 receive issue.
    does it use a relay?
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8344
      RX/TX relay RL6451 bad if it is doing that on all the bands (Tuner Main Unit). It's a sealed unit, so just replace it. Download the service manual and read page 4-1.
      If it is only doing that on one or two bands, its one of the low pass filter relays (2 per band) on the LPF board.
      Also test antenna A vs antenna B.
      • steviewonder
        • Dec 2013
        • 183
        • england
        Thanks for the replies,
        Yes it does indeed use a RX/TX relay. I did carefully remove it's housing,and a little Servisol didn't improve things.A little waggle of the contacts made no difference at all,as that's what I was thinking too.It seems to be fine on other bands,just 27mhz seems to be the problem.Must go and check...All the other pin diodes are fine.It does make sense though,as when it goes deaf,it stays the same even upon power on/off.So will replace RL6451.
        Back soon ! , And many thanks !
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8344
          if it is only doing it on one or 2 bands, its the one or 2 of the low pass filter relays on the corresponding band.
          • steviewonder
            • Dec 2013
            • 183
            • england
            In this radio,the RX/TXrelay is RL1001 on the RF board.Today i replaced the relay,and it's just the same.It seems to become less of a noticeable signal drop,the lower down you go in the bands,at 9Mhz it seems fine, and gets more noticeable from say,22-27.5 mhz.As the signals vary on keying/unkeying,I would not have thought low pass filter relays,as those aren't energised/de-energised on key up,I would have thought. I did see a post,after hours of trawling,and found a chap with the identical problem.
            He thought that it worked fine for a day or two after replacing the RX/tx relay,and ended up sending it to Yaesu,where he said they did a modification,but didn't know/explain what that was...It's a interesting one,for sure !
            • steviewonder
              • Dec 2013
              • 183
              • england
              Well, I "thought" RL1001 was the RX/TX relay.Completely barking up the wrong tree......You were quite right capleaker..Found RL6451,and it is indeed faulty.Wonder why it's a reed type? I could only find a service supplement,rather than the full service manual,so followed,pretty much,what the guy was saying about his Yaesu...Big Mistake !.
              I must have had a "off" day.
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8344
                sh*t happens to everyone... glad you found the problem!
                There are full service manuals available for this rig to download on the internet. The other day I found two. I ended up using the larger in size one.
                • rounin
                  MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                  by rounin
                  I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                  🛠 Original Issue
                  The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                  ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                  04-19-2025, 01:18 AM
                • ugamazing
                  Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                  by ugamazing
                  I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                  We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                  12-17-2024, 07:05 PM
                • shahnld
                  Lenovo legion 5 pro startup issue
                  by shahnld
                  Good day Experts
                  I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                  A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                  And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                  08-24-2025, 12:31 PM
                • ahmarzo
                  Acer laptop battery draining issue
                  by ahmarzo
                  Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                  Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                  08-02-2025, 06:39 AM
                • elmark
                  HP 15-cw1002ua strange keyboard issue
                  by elmark
                  HP Pavilion 15-CW1002UA
                  S/N 5CD0251CBC
                  P/N 7KE54EA
                  Hello guys!
                  I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                  It powers on OK and has no other issues except the following:
                  • CAPS LOCK does not work at all
                  • Fn button toggles Flight Mode
                  • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                  • (with SHIFT pressed: 't%' and 'y^' respectively)
                  I initially thought it was a keyboard malfunction (internal short, etc.),
                  but when I press and hold...
                  06-27-2025, 01:10 AM
