Original Sonoff 4CH Pro dump (bricked firmware)
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    Good day folks. A friend of mine told me his Sonoff 4CH light switch recently stopped working. It wouldn't respond to any commands and would appear as offline. Not having done any major work on these home automation devices before, we both concluded the firmware got corrupted, so we set about to find a way to reprogram it.
    It turns out these things have got a STM32 inside of it and an ESP32, so given the open-source nature of these components, there's a variety of different firmware and interfaces you can upload to them......in theory. Ideally, we wanted to use the original one it came with, but as it turns out this is not easy to get hold of: if you haven't made a backup of the original contents of the thing, you can't simply download the dump from somewhere (at least we were unable to).....
    The way you flash it to the device is also pretty difficult to pull off: you first connect it to the PC with a serial to USB adapter, which we have (a CH341). I can assume this works because if I open a terminal window, I DO get some info from the Sonoff when powering it on. Then, you have to pull a GPIO pin of the ESP to GND to go into download mode and then use a piece of software to actually flash it with the firmware you want - official or third party. I tried doing this with a "Tasmota" firmware which seems to be very common, just to check if I can do this AT ALL and it didn't work. Granted, I was in a bit of hurry and probably didn't dig deep enough, but now all it does is it has 3 of the 4 "CH" LEDs come on in red when you turn it on, so I assume it DID wipe the flash somehow but didn't write anything back to it....
    If someone happens to have one of these and are willing to share a backup of their original flash so I can try again, it would be greatly appreciated. My buddy really likes this device and he tailored his whole house around it, so he really needs it
    Wattevah...
    • 31161
    Re: Original Sonoff 4CH Pro dump (bricked firmware)
    that firmware is junk,
    99.9999% of people who buy sonof reflash it with tasmota before they even turn it on.
    https://github.com/arendst/Tasmota
    https://www.youtube.com/c/AndreasSpi...?query=tasmota
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      Could be
      The fact remains I was unable to flash even the Tasmota one.....I now know I needed to install Python for this to work, so it's not as easy as it seemed at first...
      Wattevah...
      • Ahari
        by Ahari
        I...
        08-13-2025, 06:12 AM
      • macabook
        by macabook
        🧩 Initial Issue
        07-24-2025, 02:17 PM
      • zoltor
        Canon G3430 has a lightning flash after the firmware
        by zoltor
        Good afternoon. The Canon G3430 is lit by lightning after the firmware, it does not respond to the buttons. I did not flash it, they brought it with traces of soldering, and all three chips. SPI - IC401 25Q128, IC402 25Q32, IC403 M24128. The SPI flash drives may have been confused in places. The QM8-0985 formatter. I've tried all the firmware available on the Internet, and the result is the same. I ask you to send dumps of chips, if someone has the same revision of the board, also tell me if the location of the SPI flash corresponds to the position numbers. Thank you very much in advance.
        09-17-2025, 12:40 AM
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
      • re-atari
        Anycubic Photon 5.5 3D printer 25Q32 flashrom dump needed
        by re-atari
        Hello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
        Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he...
        02-03-2025, 06:49 PM
