GORDAK 952 Rework soldering station problems
  • SuperAman
    • Dec 2018
    • 119
    I have a Gordak 952 soldering rework station that was emitting a burning smell when using it. At first it was quite small but over time it became worse. I decided to open and look and to my surprise 2 large resistors had been overheating and their covering had completely burned off. Because of this, I am unable to see their value. But today a friend of mine had almost the same model Gordak fail and I can see the color bands on his, but when trying to determine the value I am unable to. Can someone tell me the value? Seems these resistors heat up and burn the area of the board around them. The bands look to be black-black-brown-black or gray?
  • SuperAman
    • Dec 2018
    • 119
    Re: GORDAK 952 Rework soldering station problems
    • SuperAman
      • Dec 2018
      • 119
      • peste
        • Dec 2016
        • 12611
        • ROMANIA
        Originally posted by SuperAman
        that will help
          • 30979
          Originally posted by peste
          that will help
          that's terrible, do you have a higher res version?
          • peste
            • Dec 2016
            • 12611
            • ROMANIA
            I have it like this ... I hope it helps ..
            • SuperAman
              • Dec 2018
              • 119
              This is much better!!!
                • 30979
                decent
                • redwire
                  • 3906
                  From other pictures of the Gordak 952 board, the two resistors are each 300R 3W, in parallel- to make a 150R 6W resistor. I can't find them on the posted schematics. I think they feed the connector with two green wires. Whatever that is, it needs to be fixed, it is drawing too much current.
                  ugh cryllic
                  https://forum.cxem.net/index.php?/to...B8-gordak-952/
                    • 30979
                    is it the 2 18k resistors in parallel with the (mains powered) pump?
                    • redwire
                      • 3906
                      OP must have had the pump on full blast, for a long time then? It must be, I have seen 15k-18k 3W there. A 18k dissipates 3.2W at 240VAC.
                        • 30979
                        but in parallel to the pump?
                        what function unless it's to provide a non-inductive load for the triac?
                        • SuperAman
                          • Dec 2018
                          • 119
                          So I should replace with 2 18K resistors of similar type?
                            • 30979
                            you should get a picture of the underside so we can see the tracks to be sure what they actually connect with.
                            and follow those green wires to see what they do.
                            • SuperAman
                              • Dec 2018
                              • 119
                                • 30979
                                o.k. they are across the green wires - so where do they go??
                                btw, desolder the resistors and meter them - they may still be good.
                                and resolder the 3pin thing on the right that shows signs of getting hot.
                                • SuperAman
                                  • Dec 2018
                                  • 119
                                  Sorry for late reply, with COVID and all there hasn't been much work and I didn't need the rework for a while. It has now stopped working. I noticed before it stopped working that the lights would come on for a split second and turn off when I plug it in, even though the switches are off. Then after a couple of days of that for some reason the light would be on all the time even though the unit was powered off, but plugged in. Now when I turn it on, the temperature shoots up to like 300°C and instantly shoots back down to 000°C and remains there. No heat comes out, only cold air. I believe these devices have a resistor in the nozzle head, the hose might have gone bad?
                                  • SuperAman
                                    • Dec 2018
                                    • 119
                                    I've removed and measured the two burned resistors R39 & R40 and they are measuring 18.54 - 18.58K ohms. Says on schematic they should be 18K so I assume they are fine. I suspect it might be one of the 5 big transistors T4 specifically.
                                      • 30979
                                      because of the heat, it may just need some resoldering
                                      • SuperAman
                                        • Dec 2018
                                        • 119
                                        I will check for cold solder joints. I will try to replace the hose and nozzle assembly with a new one to determine if this is problem with the board or hose. I will also change the pump from another device incase the heating element has gone bad but I doubt that. I really want to fix this because this model is the original 2 board Gordak and is more than 10 years old hasn't been used at all maybe a couple times a week. The new ones are so much lighter and have only 1 board inside, and they are crap, they fail within 6 months to a year of normal usage like 5-10 mins a day.
