PLEASE HELP! Whats the value of this smd resistor at ps4 pro motherboard(NVA-001)?
  • br6122
    • May 2020
    • Hk
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8122
    Re: PLEASE HELP! Whats the value of this smd resistor at ps4 pro motherboard(NVA-001)
    double posted?
    • br6122
      • May 2020
      • Hk
      double posted?
      Sorry,network problem
      How to delete the other one?
      Anyway, it is missing on my board, this is a reference photo for internet.
      • butuni
        • Mar 2021
        • Georgia
        I need to get 1 cap's value for this board . where I can find it?
        • jinu_j
          by jinu_j
          Hi
          05-03-2025, 10:51 PM
        • mikey5791
          by mikey5791
          Hi to all forum members,
          12-26-2024, 04:55 AM
        • MidnightRoller
          Can a resistor lose resistance after hot air?
          by MidnightRoller
          I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
          I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
          02-02-2022, 11:46 PM
        • artvandalai
          What resistor ohm will work better to repair this waterpik?
          by artvandalai
          The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
          01-05-2025, 04:10 PM
        • chth96
          Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
          by chth96
          I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
          Since then, This AC/DC adaptor have been out of order.
          But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
          After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
          And Is there any possibility that it will suddenly explode as well as to be out...
          12-03-2023, 04:40 AM
