Original Xbox Clock Capacitor replacement?
  • can123
    • Oct 2013
    • 3
    Hello all whom read this.
    I am wanting to replace the clock capacitors in two original Xbox consoles I have and I am wondering if I have tracked down the right type of capacitor to install.
    This is one from a localish supplier I am looking at getting RS cap
    • 31086
    Re: Original Xbox Clock Capacitor replacement?
    yes, 1000hour lifespan - divide that by the number of hours a day you will run it.
    just leave the cap out - nothing uses the clock anyway.
    • can123
      • Oct 2013
      • 3
      Thanks for that, but I have no idea how long I will have the xbox on, they have been sitting around for a few years now and this might be the forth time I have fired them up for a test.
      • RJARRRPCGP
        • Jul 2004
        • 6304
        Like a shit incandescent light bulb!
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
          • 31086
          not really, a bulb wont leak and trash your equipment.
          there is a buck convertor on the other side of the board - if the cap leaks through the through-hole plating the board can burn-up!
          • ElectronicsOverhaul
            • Oct 2019
            • 8
            It's called a clock supercapacitor rated at 1F 250V. The one you have listed will work as the ones I have in stock have the same values. Ensure you clean the corrosion around that area though.
            • TMTGTR
              An Xbox One PSU Odyssey
              by TMTGTR
              Firstly I am not a tech. You guys may see mistakes or oversights in my methods so don't be bashful and feel free to post corrections/opinions.
              =>Background:
              I bought my son a used Xbox One original model: A12-220N1A Rev: 02 with original PSU & 2 controllers 7 years ago. I “modded” the unit placing a 4.5” 12V exhaust fan with a 9v wall wart adapter on top of the vent/fan of the unit. And plugged the Xbox PSU into a Tripplite LTR-600 voltage regulator. Also connected to the Tripplite are a 275w computer tower, an Xbox 360 PSU and a Westinghouse 52” LED TV. ...
              06-17-2022, 05:40 PM
            • artvandalai
              Where can I get compatible capacitor for replacement?
              by artvandalai
              Blew the capacitor on my analytical balance scale using the wrong power adapter. I need help finding a replacement compatible capacitor to buy. Will any 100uf 40v capacitor work as a replacement?
              12-28-2024, 10:15 AM
            • ohren
              Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
              by ohren
              Hello!
              I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
              Measured voltages with no load:
              After rectifier diodes
              12V: 6.17 V
              5V: 5.67 V
              Secondary transformer pins AC measurement (really don't know if this says anything)
              12V: 2-2.5 V
              5V: 1.04 V
              I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
              03-18-2023, 10:33 AM
            • tccyo22
              Xbox One Original missing 12v enable signal
              by tccyo22
              Hi there, I have an Xbox One original in which I have all the 1.8v, 3.3v and 5.0v standby power rails present, however my 12v rail is not turning on and the enable signal PSU_V12P0_EN from the SMC to turn the power supply on is missing. There is high resistance on this line so it's not shorted directly to ground which leaves me with not many options.
              Was looking at a schematic and see the enable is created by the SMC. I have 3.3v on SMC_RST_N_IN but I'm a little stuck on where to look next. Is it likely that the SMC has gone bad or am I missing something else (it's my first time with...
              08-14-2023, 06:06 AM
            • r2digital
              klipsch kda-500 amplifier suitable power supply capacitor replacement ?
              by r2digital
              I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
              04-18-2024, 03:50 PM
