Original Xbox Clock Capacitor replacement?
    Hello all whom read this.
    I am wanting to replace the clock capacitors in two original Xbox consoles I have and I am wondering if I have tracked down the right type of capacitor to install.
    This is one from a localish supplier I am looking at getting RS cap
    Re: Original Xbox Clock Capacitor replacement?
    yes, 1000hour lifespan - divide that by the number of hours a day you will run it.
    just leave the cap out - nothing uses the clock anyway.
      Thanks for that, but I have no idea how long I will have the xbox on, they have been sitting around for a few years now and this might be the forth time I have fired them up for a test.
        Like a shit incandescent light bulb!
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
          not really, a bulb wont leak and trash your equipment.
          there is a buck convertor on the other side of the board - if the cap leaks through the through-hole plating the board can burn-up!
            It's called a clock supercapacitor rated at 1F 250V. The one you have listed will work as the ones I have in stock have the same values. Ensure you clean the corrosion around that area though.
