PS3 Super Slim PSU
    • Jul 2011
    • 6033
    Re: PS3 Super Slim PSU
    I would also recommend change all three capacitors next to that ic chip “FS117”
    • rtstorm
      • Feb 2012
      • 971
      • Croatia
      I check those caps and they are ok, i replace most of them. Is it normal that +5VSB_RETURN is shorted to gnd? I check and it is shorted on mainboard and psu. I disconect it and test separate. And now i discovered when mainboard is not connected with psu i got +5 on +5VSB and +5v on ACIN_DET. So is the priblem with mainboard?
      ...the quieter you become the more you are able to hear...
        • 30979
        RETURN is an old name for neutral or ground.
        so that's o.k.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8120
          You did pretty good so far. You discovered that the psu is loaded down by a short on the main board. The psu is fine. From here on it probably gets a little ugly.
            • 30979
            does the slim have the damned nec-tokin prodalizer ceramic caps on it??
            • rtstorm
              • Feb 2012
              • 971
              • Croatia
              #26
              I think, here is the picture of mainboard.
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8120
                So, as soon as you plug this board in, your stby voltage disappears, correct?
                • rtstorm
                  • Feb 2012
                  • 971
                  • Croatia
                  #28
                  When i diconect 4-pin connector and plug in PSU in wallet i get 5.5V on +5VSB, and 5V on ACIN_DET. ACDC_STBY is 0V. When i plug in the 4-pin to mainboard i lose those 5V on both (+5VSB and ACIN_DET)
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8120
                    Yeah, there is a short on the main board all right. Do you have tools like a constant voltage, constant current power supply, DMM, hot air etc?
                    Try to measure with your DMM in Ohms setting between 5vsb and 5vsb Return on the main board.
                    • rtstorm
                      • Feb 2012
                      • 971
                      • Croatia
                      #30
                      Yes i have it all exept osciloscope
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8120
                        If you got a lab psu, you could feed the main board 5v, one or 2 amps and try to feel with you fingers if something gets hot. You also can douse parts of the main board with IPA and see if it evaporates or bubbles in a specific section. Could be anything from IC’s to a shorted smd multilayer cap.
                        • rtstorm
                          • Feb 2012
                          • 971
                          • Croatia
                          #32
                          Ok so i connect 5V to the +5VSB and ACIN_DET and i got red light on the on/off switch. I hear some wining sound from board, and i notice that WiFI module is getting hot.
                          The marking on this is :
                          384FF0C6C3D7
                          Rev 1.1
                          AW-GM381-2-12040-0BH
                          • CapLeaker
                            Leaking Member
                            • Dec 2014
                            • 8120
                            How much is the current draw?
                            A whiny something shouldn’t be with the ps3 off. At least I do t think so. Maybe remove the wifi module and plug the ps3 psu in.
                            • CapLeaker
                              Leaking Member
                              • Dec 2014
                              • 8120
                              Watch this: https://youtu.be/eEJ9zCgbg4k
                              • rtstorm
                                • Feb 2012
                                • 971
                                • Croatia
                                #35
                                I already watch that video before. It draw 0.3A, but at first it drop my voltage to 2.3V and then come up to 5.5V. i will try to remove it and then check
                                • CapLeaker
                                  Leaking Member
                                  • Dec 2014
                                  • 8120
                                  Umm something is off if the main board is working on your bench power supply only drawing 0.3A. I mean you load tested the ps3 psu at 0.5A, right?
                                  • rtstorm
                                    • Feb 2012
                                    • 971
                                    • Croatia
                                    #37
                                    Sorry, dis not understand you. What do you mean by load the tested ps3 psu az 0.5A?
                                    I noticed that at first Amps jump to 1.9A then go down to 0.3-0.5amp.
                                    • rtstorm
                                      • Feb 2012
                                      • 971
                                      • Croatia
                                      #38
                                      I remove the WiFi little board and i got working But it will only work when i short +5VSB and ACIN_DET. I test the console and it boot up and run normaly (just no WiFI). Do you have any idea why it wont work without jumping wire those 2 pins?
                                        • 30979
                                        probably needs the wifi for the initial self-test
                                        a lot of other consoles wont boot without the module either
                                        • rtstorm
                                          • Feb 2012
                                          • 971
                                          • Croatia
                                          #40
                                          Yes it could be. My controller does not work so i assume that this chip is for Bluetooh also . I thought that i could use console with LAN cable but obviously i need to replace it
                                          • Destroyer-Br
                                            [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                                            by Destroyer-Br
                                            I'm working on an Acer Nitro 5 unit with the following specs:
                                            • Motherboard: LA-J871P Rev: 1B
                                            • Model: Acer AN515-55-59MT
                                            • S/N: NHQ7JAL00403906A973400
                                            • SNID: 03902728734
                                            Initial Issue
                                            The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                                            After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                                            04-17-2025, 08:18 PM
                                            SHUTTLE XPC slim DX30 XPC slim J3355 Specification for Upgrade or Repair
                                            This specification for the SHUTTLE XPC slim DX30 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC slim DX30 boardview and XPC slim DX30 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for SHUTTLE...
                                            09-12-2024, 03:30 PM
                                            HP Slim Desktop S01-aF0009nf Slim Desktop J5005 Specification for Upgrade or Repair
                                            This specification for the HP Slim Desktop S01-aF0009nf can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-aF0009nf boardview and Slim Desktop S01-aF0009nf schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-12-2024, 03:28 PM
                                            HP Slim Desktop S01-af1132a Slim Desktop i3-10100 Specification for Upgrade or Repair
                                            This specification for the HP Slim Desktop S01-af1132a can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-af1132a boardview and Slim Desktop S01-af1132a schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            HP Slim Desktop S01-aF0011ns Slim Desktop J4005 Specification for Upgrade or Repair
                                            This specification for the HP Slim Desktop S01-aF0011ns can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-aF0011ns boardview and Slim Desktop S01-aF0011ns schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
