PS4 Wi-Fi chip bad joint
  • sautzer
    • Feb 2020
    • 14
    • Italia
    First off, English isn't my primary language so I don't know all the technical terminology. So I ended up owning this PS4 slim that had a problem pairing controller. Once opened, I removed the WiFi chip and some joint ended up like in photo (I don't know the technical terms, if you could tell me how it's called I'll appreciate). How can I fix this?
    • 31025
    Re: PS4 Wi-Fi chip bad joint
    oh shit!
    you need to rebuild the pads - watch some luis rossmann video's on utube.
    • ngth82
      • Jul 2015
      • 541
      "Cratered BGA Pad" is something you can look up on Google for some info. I second looking at Luis Rossmann on YouTube on repairs.
      -Thomas
      I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.
      • sautzer
        • Feb 2020
        • 14
        • Italia
        Thanks you guys! Really appreciate your support, hopefully the next reply will be for telling you I succeed
        • sautzer
          • Feb 2020
          • 14
          • Italia
          Sorry guys, I've seen many videos from Louis but didn't found one with a similar problem to mine, could you link one please?
          • ngth82
            • Jul 2015
            • 541
            The general idea would be to:
            1) Identify where the electrical net would go to.
            2) Identify where you can jumper something to that BGA ball.
            In your case: The red box looks like it's a signal pad that is connected to the via immediately to the left. You can scrape off the green solder mask from the via and add a 'jumper' wire (really thin wire -- 32 AWG (8 mil) or smaller wire for the red box.
            The purple boxes appear to be connected to GND. You may be able to scrape off the green solder mask around it and get a copper foil sheet and tack it down "outside" of the BGA region.
            -Thomas
            • sautzer
              • Feb 2020
              • 14
              • Italia
              So I kind of resolved, now the PS4 turn on and update (with the non working module it just couldn't giving me an error) but I haven't an official controller, just a nacon, and can't get past the screen where it says to press the PS button
                • 31025
                make sure the usb cable is connected to the first port
                • sautzer
                  • Feb 2020
                  • 14
                  • Italia
                  So guys I think I messed up badly. I had the occasion to try an original DS4 but nothing, the PS4 was stucked. After some soldering and desolring the WiFi module the PS4 doesn't turn on. I've tested the PSU and it's fine, how could I try to locate the error? I've checked for missing component next to the area where I applied the hot gun but nothing is missing
                  • sautzer
                    • Feb 2020
                    • 14
                    • Italia
                    So found the problem, I dissoldered a little resistor, could someone tell me what resistor is it?
                    • ngth82
                      • Jul 2015
                      • 541
                      It's likely just a pull up or pull down resistor. Can you identify if one of the pads is connected to a power rail or ground? If so, a pull up, or a pull down resistor is likely - in which case, start with a 10kOhm resistor.
                      Other questions:
                      - What's the board model number? (alternatively, what's the PS4 model number?)
                      - What's on the primary side in that general area?
                      -Thomas
                      • sautzer
                        • Feb 2020
                        • 14
                        • Italia
                        Other questions:
                        So none of the pad is connected to ground (I tried to see if there's continuity with the brown pad on the board, I'm a noob sorry). Also the PS4 is a SLIM CUH-2016A B01Y, motherboad SAD-001 1-981-279-21. On the primary side there's the NOR chip and the southbridge
                        On another forum they says that is a 22 Ohms.
                        • sautzer
                          • Feb 2020
                          • 14
                          • Italia
                          Here's a closer look at my motherboard
                          • ngth82
                            • Jul 2015
                            • 541
                            If it's not connected to GND or VCC, then it's probably a series resistor - 10 to 33 Ohm seems reasonable.
                            I compared your top and bottom pictures and traced where it goes. Looks like a 5-6 mil wide microstrip trace from the IC (top side), to a through hole via to the bottom side, the (missing) resistor, then a via to an internal layer (no microstrip trace on the top side).
                            There's no datasheet for that IC either... but with the pics you provided, its a series resistor for the signal to snub out any over/undershoot caused by the driver on that IC. If you don't have a small value resistor, you can bridge it to begin with. Power it on and see if it works for testing.
                            -Thomas
                            • sautzer
                              • Feb 2020
                              • 14
                              • Italia
                              So I did like that but putting a disc won't power it up (I'm a noob and in the process I broke the power button and it's flex cable, tried to repair it but didn't worked but if I move it, the PS4 turn on led on the power button randomly)
                              • sautzer
                                • Feb 2020
                                • 14
                                • Italia
                                If I put to ground the lef, they power on, so I think that the powerboard is still functional
                                • sautzer
                                  • Feb 2020
                                  • 14
                                  • Italia
                                  Well I dissoldered the bridge I made where it was the resistor and this trick still works
                                  • DynaxSC
                                    ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                                    by DynaxSC
                                    Hi
                                    I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                                    08-04-2025, 12:20 PM
                                  • corrize
                                    Asus Zenbook UX433F UX433FA wifi up and down and chip hot
                                    by corrize
                                    Hello, on this laptop, the wifi can be up and stop working. I noticed it never works without battery, except long time after I remove the DC jack, and it stop to works (Bluetooth too). It diseapper to window and still 2 exclamation points in the device list.
                                    The wifi chip is hot when the laptop is on.
                                    I made a bios update but the same.
                                    That could be a thermal issue, I measured 2 caps shorted (0 Ohms) beside the chip (+3V_WLAN according the bordview), but not since (so I have doubt what I saw). After, I measured 50 Ohms when battery plugged and K Ohms...
                                    05-15-2023, 04:05 PM
                                    by SMDFlea
                                    Bad...
                                    09-02-2021, 04:40 PM
                                  • Arshad alam4659
                                    Macbook air a2337 wifi/Bt chip short
                                    by Arshad alam4659
                                    Macbook air a2337 part no 820-02016 wifi/bt chip is burned mark can I replace this chip will work I have same donor board...
                                    02-09-2025, 08:23 AM
                                  • BMCappelletti
                                    Asus Chromebox CN62 - wrong chip put on BIOS reader
                                    by BMCappelletti
                                    Long story short:
                                    - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                                    - gave the computer to his son a couple years later
                                    - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                                    - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                                    (seems like the story was not that short)
                                    He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                                    01-08-2025, 07:27 PM
