Mirtone MA-401B Intercom Amplifier - repair/recap
  • redwire
    • 3906
    Mirtone MA-401B apartment intercom amplifer that would squeal/yelp/chirp when you pressed the Listen button. Now it just oscillates a steady tone when you press Listen and you can't hear anyone from the vestibule.
    Date code 1980 with 10 mostly Marcon electrolytics and 13 discrete transistors and a triac for the door solenoid. It has a 7812 for +12VDC power and 16VAC input. I found one open 22uF cap but replaced all of them, it is running 40 years 24/7.
    Capacitor list:
    1 of 470uF 35V
    3 of 47uF 16V
    1 of 22uF 16V
    4 of 10uF 35V
    1 of 0.47uF 50V
    If you have hum problems, "T2" is earth/chassis ground so you need an extra wire for that. "S2" is also shield GND for vestibule mic/speaker.
    There is still some hum but they used the wrong wire (not twisted pair or shielded) in the building.
    Mirtone company was renamed to Mircom, and the MA-485 is the 2nd generation replacement module.
  • CapLeaker
    Leaking Member
    • 8134
    Re: Mirtone MA-401B Intercom Amplifier - repair/recap
    Nice repair redwire. Here in the sticks I haven’t seen many of these, but I remember that they always had a little hum.
    • redwire
      • 3906
      This uses a 4-wire system so all stations are in parallel, cable just daisy-chained (3 of the 4 wires) through an entire building.
      I've repaired many apartment/condo intercoms and it's terrible when a suite has a stuck button (open door, listen, talk) you have to go to each unit to find it. Try that in a 30-suite building, tenants aren't home or you don't have permission to enter. Only the front vestibule Call button is a separate wire to each suite.
      One building had a guy do reno's and a nail hit the cable, the door solenoid was randomly going on and off. I disabled it and then the Post Office guy couldn't get in to deliver the mail. Took a month to find that nail.
      Including my other schematics for completeness. Mircom IS-401 station wiring, uses oddball speaker 07420043 15 ohms 1W I think 3" just use a 16 ohm part. The vestibule is a 45 ohm speaker though.
      Mircom/Mirtone looks like a Canadian company.
      • dantm
        • Mar 2009
        • 26
        redwire I see you've had a bunch of experience with Mircom systems...I have here a 9 unit apartment building with a Mircom panel, door striker, amplifier (MA-485A) and individual inside apartment units. Symptoms we have include: static on the audio (both ways), inability to hear anything (a few apartment units), intermittent door striker option = opening the door is 50-50. The door striker activation is the silent type and I feel the activation of the striker is not as strong (or loud) as it used to be years ago but I may be wrong.
        So far we replaced internal units after talking to Mircom and it improved audio in some cases but not all -- it did not solve all the issues...should we consider the amplifier next? And maybe debug the door striker with an external battery?
        Thanks!
        • redwire
          • 3906
          What you are describing, it's many problems that are not so related.
          I did see a building like yours and one owner was doing reno's and had damaged the cable. It daisy-chains from unit to unit. He drove a nail or screw through it which shorted the door striker intermittently it would just turn on all by itself or not work at all. Audio was lost for a few units. So consider that your cable got damaged, coinciding with when the problems showed up. Check for any contractor or owner doing recent work and put a drywall screw through the cable etc.
          I would Ohmmeter the cable between the (end) MA485 to another other end, at an apartment unit. Look for shorts/opens in the cable. Or try wiggle it a bit to get the problems changing.
          • dantm
            • Mar 2009
            • 26
            Any suggestion on how to ohm out ~100 ft distance? The leads are at most 2 ft and that's generous :-)
            Thank you!
            • redwire
              • 3906
              It's a multi-conductor cable and you are looking for both open-circuit and short-circuit between the conductors.
              You need to first find a known good (reference) conductor.
              At one end - person with multimeter on Ohms/Continuity on chosen wires (or if you can hear the beep, one person only at the other end).
              At other end - person who can short chosen two of the wires.
              Talking on radio/cell phone, chose a pair of colour codes and see if you can get loopback Ohms continuity reading. Once you have that, a known good conductor then just sweep through the other conductors to test them.
              If you are still lost for a known good ref. conductor, I have used metal pipe ground or PE earth-ground on nearby electrical outlets as the loopback conductor.
              Worst case use a long extension cord with a multimeter at one end and the jumper wire at the other end.
              Sometimes the intercom cable can have spare conductors (not that they aren't also damaged) but you could move a suite to using those.
              If there is a foil shield you can also use that as your common connection and test for shorts to the shield as well.
              I have also seen intercoms poorly maintained where they just have a nervous breakdown. One unit has bad pushbutton switch, another the speaker is toast etc. and that can throw you when troubleshooting as well.
              • MrCommunistGen
                Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
                by MrCommunistGen
                My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
                I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
                07-12-2021, 05:11 PM
              • jinu_j
                How to test Subwoofer Amplifier with only a multimeter
                by jinu_j
                Hi Folks
                Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
                Problem
                I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
                Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
                Any advice would be appreciated...
                08-29-2024, 02:05 AM
              • UserXP
                Mackie CR4 amplifier no sound
                by UserXP
                Hi, people.
                I've got an amplifier assembly from Mackie CR4 parts. It's just an amplifier, there was no speaker housing, so I used my set of CR4s to test it.
                Anyway, upon connecting everything and hooking the "new" amplifier to an audio source, the sound played clearly and strongly for the first ten seconds. I was happy it was working. Then the sound started to fade out during the playback until it was no more. After it had "dropped to zero", there were two very short intervals of sound playing at the normal volume, as if the amplifier was trying to...
                10-17-2020, 05:06 PM
                ASUS P5GC-MX motherboard recap
                by momaka
                Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                So here is what the motherboard looked like with its original caps:
                CPU VRM area up close…...
                01-27-2021, 11:59 PM
              • Francesc V.
                Rotel RSX-1056 amplifier. Troubleshoot a noisy channel
                by Francesc V.
                Hi:
                I've realized that one of the channels of this amplifier has no proper sound.
                This is the signal at the speakers output.
                As long as the audio coming in to the amplifier board (blue) looks ok although with some noise due to the wire, I think that there's nothing to look at the preamp section.
                Now, I could start looking at components to see whether I find the guilty one.......but I would rather prefer to ask for advice. Here there is the amp. schema. Which points would you check with the oscilloscope to gather...
                07-15-2025, 01:33 AM
