Hoverboard mosfet
  • edugimeno
    • May 2017
    • 581
    • Spain
    Hoverboard mosfet
    Hi There.
    I have a hoverboard with 2 shorted mosfets. They are HY1607P. As expected, my local provider has never heard of them and they don't have a replacement lookup book anymore, so I should build a list of several dozen alternative parts so they can check which one they have (last time I tried they had NONE in my list)
    At the same time I have ordered the same part number online from China, that was one month ago, and still awaiting for it.
    My PN has these specs: 68V, 80A, N-Channel, TO220, 6.8mOhm, Vgs=10V.
    Last one I repaired had a RU6888R mosfet with most of the specs like this other one
    Im wasting lots of time looking for other mosfets that match these specs but at the same time, and after having repaired lots of these hoverboard boards and having seen that 90% of them look like clones of each other inside, I am suspicious that there must be some generic-common-in-the-market mosfet models that match all these boards
    Does anyone have experience in finding good alternatives for these hoverboard mosfets?
    Thanks in advance!
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Hoverboard mosfet
    I use this site for finding alternatives. https://alltransistors.com/mosfet/
    • petehall347
      • Jan 2015
      • 4426
      i seem to remember you want to be changing all of them for a matching set .
      • edugimeno
        • May 2017
        • 581
        • Spain
        @Diif: Why didn't I know of this page??? Ok I filled several fields and got a list. I sent it to the shop over email to see if they can source one of them. Thanks
        @Petehall347, these boards have 3 pairs of transistors for each wheel, all faultu boards I've had came with both mosfets for one coil burned. The HIGH and the LOW side mosfets for the same coil, so I've always had to change them by pairs. TBH I don't see any point in changing other mosfet pairs for other coils that have not failed. I see them as prone to fail after swapping then as before swapping them
        Thanks both!
        • moss99
          • Oct 2013
          • 50
          Hi , what did you replace them with in the end ? , I an having the same issue .
          • edugimeno
            • May 2017
            • 581
            • Spain
            I can't remember now to be honest, but I think I ended realizing that NOT ALL THE SPECS in a mosfet have to match for this kind of application. So if I would have to do it now I would look for some common sold mosfets on ebay or amazon, and check that they match or exceed:
            -Max current
            -Max voltage
            -Same package
            -Same type (N or P)
            If you go the other way around (find a list online that tells you thousands of equivalent mosfets and then go to a shop to get them), you will find that among those dozens of PN's 99% are not common at all and you need to start over. Also if you happen to find one of them it may be very expensive.
            So just search for "N-mosfet TO220" for instance, or "P-mosfet D2PAK" on ebay or amazon and in the list of the cheapest or more popular results, check the specs for them and see if one of them is good for what you need. You will probably spend 1/10 of the money comparing to what you get trying to source the original or "table-equivalent" component
            Hope it helps
            • moss99
              • Oct 2013
              • 50
              Ok , thanks ..
              • stevetaylor
                • Sep 2015
                • 42
                • romania
                Originally posted by edugimeno
                Hi There.
                Thanks in advance!
                I would try the STP80NF10, SSF7509 or the irfz series from infienon.
                it must work
                • kotel studios
                  Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
                  by kotel studios
                  Finally got time to fix this board up.
                  At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
                  Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
                  04-22-2025, 05:08 AM
                • Jane
                  How do you test MOSFET in laptops ?
                  by Jane
                  I tried to use this method:
                  Testing an N-channel MOSFET:
                  Step 1: Discharge the Gate (turn off the MOSFET)
                  Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                  Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                  Step 2: Charge the Gate (turn on the MOSFET)
                  Now, place the red probe on the Gate (G) and the black probe on the
                  09-27-2024, 03:31 AM
                • AppleLover123
                  Asus X712EA 3 volts after the first mosfet
                  by AppleLover123
                  Hey guys,
                  i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                  I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                  Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                  I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                  Now i thought something...
                  12-15-2024, 07:49 AM
                • MicroSMD Lab
                  by MicroSMD Lab
                  I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                  01-10-2024, 06:36 AM
                • Scotchmist
                  Asus GA502D keeps blowing mosfet
                  by Scotchmist
                  I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
                  I have removed the mosfet and can run the laptop no problem
                  The MOSFET is FDPC5018SG
                  Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
                  08-24-2024, 02:23 PM
