Honda Civic speedometer cluster - "inverted gas gauge"
  • lti
    • May 2011
    • 2555
    This seems like a common problem, so I thought I would post it here. This cluster also had one flickering segment in the speedometer display. There are three LCDs in this cluster, and there were cracked solder joints for the fuel gauge (image 1) and speedometer (image 2) LCDs. The temperature gauge LCD (image 3) looked okay, but I resoldered all three LCDs. There is conformal coating over most of the solder joints on this board, so that should be removed first. It does melt with heat, but melting through it with the soldering iron isn't the best idea.
    This car hasn't been driven enough to know if it's fixed yet. I'll see what happens later. Those solder joints were definitely one problem, even if they weren't the only problem.
    By the way, the instructions here are wrong. Only the bottom screw is accessible by removing that trim panel (at least on a 2010 model).
  • tehmatix
    Component identification D3950 Suzuki GSX-R1000 K7/K8 cluster gauge
    by tehmatix
    Anyone have knowledge about this component D3950 ( I suppose to be BD3950) , an application note or equivalent.
    Thank you
    03-04-2024, 04:10 AM
  • ranchhandbumper
    1992 Toyota Truck Speedometer
    by ranchhandbumper
    I am working on a 1992 Toyota pickup that has an electric speedometer. It is an analog needle speedometer and is driven by electricity.There is no cable. The transmission has a reed switch that sends a 12 volt pulse to the speedo 4 times per tire rotation.
    According to GPS, the speedo is showing speed progressively slower below 50mph and progressively faster above 50mph. This also affects the odometer.
    I've included a photo of the findings. The "control" is information I found on the net that correlates expected MPH based on a given hertz.
    I removed...
    11-12-2022, 08:12 PM
  • ojmc
    Hisense 65H6570G - Color inverted after replacing LED backlight
    by ojmc
    Background:
    • Hisense 65H6570G stopped working and I root caused to a burnt out LED in the backlight. (For anyone interested the power light pattern when the backlight has gone is 1) two long flashes, 2) a very short third flash, then 3) back to solid red )
    • I replaced all 6 of the backlight LED strips with these replacements: amazon
    • The TV worked again perfectly for ~2 weeks.
    • After that 2 weeks the colors became "inverted". The TV powers on and shows the boot screen in correct colors initially (aqua hisense logo on black background, pic on the left) but a few seconds after boot
    10-17-2024, 02:29 PM
  • j879
    Samsung QLED QN75Q8FNBFXZA inverted/negative color
    by j879
    hi guys,
    My 5 years old SAMSUNG QLED got color inverted somehow. I have tried reset, replace mainboard as well as the driver board without luck. The issue must be on the circuit on panel skinny board or so. For this model I could not find the dedicate T-con board so AS15 replacement is not applicable..
    I have upload the pictures
    Maybe I should measure the gamma voltage but I couldn't find the right place.
    Any idea would be appreciated....
    07-12-2024, 12:23 PM
  • porfyriadhs
    Vestel tv inverted colours
    by porfyriadhs
    Hello I have changed the Main board of a vestel tv with same board but colors are inverted can someone explain me why?...
    06-04-2024, 02:39 AM
