DC Ceiling Fan Motor Controller / receiver
  • 265chemic
    • Jan 2020
    • 19
    Hi All,
    I'm having a problem with a DC ceiling fan controller (from a Mercator Trinidad fan). This operates via a remote. The light works fine, as does re-pairing the remote (an audible beep is emitted). The fan function itself however does not. This leads me to believe the issue is more than likely with the DC power control part of the circuit. I have another known good controller for comparison.
    When it first started having issues - and this might be key to forming a theory from someone more experienced than I - it initially wouldn't work until after the AC isolator wall switch was on for some time - sometimes even taking a few hours from pressing a fan speed button on the remote until the fan actually started turning.
    I suspected capacitor issues originally, due to it having some lag time before it would work. Here are some pics - visually all seems okay.
    Electrolytic caps;
    - The big 68uf 450v cap tested ok. Had .29ohm esr and .7% vloss.
    - 100uf 16v tested ok, .49ohm esr and 4.1% vloss
    - 100uf 35v tested ok, .07ohm esr and 1.4% vloss
    - 47uf 35v tested ok
    Film caps;
    - cx2 - .1uf film cap tested at 70.3nf .40 esr
    - cx1 - same as above, 89.1nf .29 esr
    Interestingly, I swapped these over and the fan had not worked even being on for hours like it did before, even after swapping them back.
    *The whole input bank (inductors(?)+film caps) in circuit from the AC input wires (brown/blue) to the bridge rectifier measures 164uf (vs 154uf on the good fan control )) - 8.4/7.4 esr respectively, so I'm not sure that even though the film caps are >10% outside spec that this would fix it, particularly as the bad one has a higher capacitance reading.
    Diodes;
    - Tested all surface mount diodes okay, however. D7 was open both ways.
    - D7 is S1J. removed from circuit - tested ok - reinstalled.
    Bridge Rectifier;
    - bridge rectifier is KBP08. Tested 240vac in, 318vdc out.
    Test Points;
    Tp0+tp1 = 15vdc (correct supply voltage for PCM as per PDF below)
    Tp0+tp2 = 3.5vdc
    Tp0+tp3 = 320vdc (correct DC bus voltage)
    Tp0+tp4 = continuity, GND(?)
    Tp0+tp5 = .5vdc ***Noted that this on the good controller is 3.5vdc - this is the only difference I've measured.
    Tp0+tp6 = .5vdc
    Tp0+tp7= 15vdc (when light is 'off' only, activates light relay)
    Has irsm836-025ma dc power control module https://cdn.badcaps-static.com/pdfs/...33a5dc8694.pdf
    Tp5 and Tp6 correspond to pins 5 and 6 on the dc power control module, and the description from the datasheet is;
    5 | /FLT | Fault Output Pin
    6 | Itrip | Over-Current Protection Pin
    Focussing on pin 5, and the description for fault in the datasheet "Once the fault condition occurs, the FAULT pin is internally pulled to VSS and the fault clear timer is activated. "
    VSS is described as " 9, 39 | VSS, COM | Ground for Gate Drive IC and Low Side Gate Drive Return "
    Should I be interpreting that as it's been pulled to ground (hence the .5v reading vs the 3v on the good controller) therefore it's detecting a fault?
    I've hit a bit of a wall here - any suggestions that may help me out?
    Also - for the DC motor feed wires (U/V/W) I get 2v out of U/V/W +gnd and 26v from tp3(dc bus voltage)+U/V/W.
    Re: DC Ceiling Fan Motor Controller / receiver
    I cannot see any pictures.
    please use that attachment to upload the pictures instead.
    • 265chemic
      • Jan 2020
      • 19
      Thanks - Apologies - I've tried hosting them differently this time;
      • 265chemic
        • Jan 2020
        • 19
        • will62
          • Dec 2016
          • 229
          • usa
          You mentioned that it would work if the switch was left on for a long time. Possibly a cap going bad, or heat build-up and thermal expansion remaking a bad connection. Have you tried hitting the board with hot air?
          • R_J
            • 9535
            Have you tried swapping the 68uf 450v between the boards.
            • CapLeaker
              Leaking Member
              • 8146
              change out U2.
              • 265chemic
                • Jan 2020
                • 19
                Thanks - I haven't tried hot air yet, though I do have a heat gun so will give it a go next time I pull it down. The controller is currently working again in the fan (after being left on for some time) but next time the switch is flipped we're back to non responsive ill bet.
                • 265chemic
                  • Jan 2020
                  • 19
                  Thankyou - I haven't though the 'bad' board cap tested okay and had a good ESR. That would typically be something worth trying though would it, even if testing says okay?
                  • 265chemic
                    • Jan 2020
                    • 19
                    change out U2.
                    I've never swapped out an IC that size before, with the little pins and many contacts. What happens with the hidden contacts underneath? I assume there must be a method for doing so - what would be the typical way to tackle replacing something like that?
                    • R_J
                      • 9535
                      There should be a current sense resistor (0.5Ω) between ground and the VRU,V,W pins Is it ok? If the fan does eventually run I would think the ic is ok.
                      There are only 2 reasons for the Fault output being high, you say Vcc is ok, so an over current detect must be occuring
                        I wonder if the startup motor stalled is causing the over current to trip. I wonder what will happen if he spin the fan manually then turn on the fan.
                        • 265chemic
                          • Jan 2020
                          • 19
                          I will check that out next time I pull it down
                          I did try that - no difference observed
                          • redwire
                            • 3907
                            I'd measure ohms from the FAULT pin to VSS, to see if the big IC has failed. It's only supposed to assert FAULT as long as VSS is low, under 13.5V or motor overcurrent - but that one clears when motor current is normal.
                            These IC's usually blow up when they short so I'm wondering what went open-circuit to act as the fuse.
                            • 265chemic
                              • Jan 2020
                              • 19
                              I checked all 3 0.5ohm (R500) resistors between VRU,V,W and ground - they tested okay.
                              Thanks - I'll check this next as well.
                              • R_J
                                • 9535
                                You say you have another controller, does it run THIS fan properly? It looks like U4 is the driver ic (IRMCK171)? It could be that it is not providing the drive signals for the ipm. This ic operates at 3.3 volts so there must be a 3.3 volt regulator on the board, maybe U7?
                                Also what is the number on U3?
                                • 265chemic
                                  • Jan 2020
                                  • 19
                                  Yep, the 'good' board runs the 'bad' fan just fine. One of the first things I did to make sure it was isolated to the board.
                                  U4 is a IRMCF171 - https://www.infineon.com/dgdl/Infine...53567246602737
                                  I've included a better picture too.
                                  My next steps were;
                                  - Check between VR1/2/3 pins 12,13/14,15/20,21 to VSS - there should be a .5ohm resistor(s). Make sure this/these test okay. (Marked R500.) Tested - all ok. Are R22/R23/R24.
                                  - Check between pin 8 and VSS for a 1nF cap. Test. (possibly the biggest brown SMD cap near the bridge rectifier.) Is actually C17. Measures approx 1x2mm measured w. calipers. Removed from board and tested, seemed to get 85uf/.15esr initially, then stable @ 42.4uf/.15esr. This seems way too high.
                                  - Check between pin 8(RCin) and 34(VCC) for a 2M resistor. Test. (Expect Marked 205) is actually marked 684, is 680k and measures ok. Pin 8 goes to 34(VCC) via resistor and diode D2 upstream, and also after resistor branches off into into pin 1,3 of U3, which is st electronics 393 60413 - approx 5x4mm in size. Can't find exact data sheet but likely this - SO8 package (https://cdn.badcaps-static.com/pdfs/...e33e2ff658.pdf)
                                  Extra notes;
                                  - Pin 1,3 measure 15v, which is VCC supply.
                                  - Voltage across R25 measured 14.2v closest to R25 marking, 15.4 other side
                                  - Voltage across D2 Diode neg side 14.7v, 15.4 pos side
                                  - Also measured 14.7@ pin 34
                                  Image: https://photos.app.goo.gl/UATPg78AL8CNhF1F6
                                  • 265chemic
                                    • Jan 2020
                                    • 19
                                    After testing the cap I attempted to resolder it back - it escaped my tweezers, shooting off somewhere into the ether.
                                    That said, out of interest I reinstalled the controller and it worked after sitting switched on for 48 hours or so. Does this give any more certainty the cap was at fault? Is there a way I can find a replacement without having to measure one off the good board? From some research it sounds like the size plus voltage may be indicative of capacitance in general, is that right? It's from a 15v part of the circuit.
                                    • juergenb
                                      Nescafe Aeroccino, still fails with new Motor (red flashes only once)
                                      by juergenb
                                      i am asking for some Help.
                                      I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
                                      The Motor didn“t start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
                                      So i got a few of these from Banggood.
                                      I swapped the motor and now i have a new fault condition.
                                      In a working Frother you would press the start button, it will light red and work for a few minutes.
                                      If you press longer it will light blue and just mixup the milk.
                                      With the new Motor it just starts...
                                      03-23-2021, 11:24 AM
                                    • Per Hansson
                                      Motor run capacitor physical size vs voltage rating & measurements?
                                      by Per Hansson
                                      (TL;DR skip the first paragraph)
                                      I encountered my first dead motor run capacitor at a customer this week.
                                      For some fields I guess it is a very common occurrence but the usual way for industrial machines here is to use 3-phase motors.
                                      (Unless a servo motor makes more sense that is).
                                      But for some reason this 3-phase machine uses a 1-phase motor for its liquid coolant pump.
                                      The pump would run but sometimes trip the 10A breaker.
                                      I monitored it starting and stopping for over an hour until it finally stopped in a specific spot between its windings:
                                      Then it could...
                                      09-20-2020, 06:32 AM
                                    • mikey5791
                                      Help identify this motor
                                      by mikey5791
                                      Hi all forum members,
                                      Found this unknown motor discarded in a junk yard and took home for learning experience. By the look of it, I suspect it is taken out from a type of air blower probably running on ac power. I used digital multimeter on ohm/resistance scale and it doesn't read anything on those 2 black wires. So, this motor is not shorted and should be good to run.
                                      Correct me if i am wrong on the initial test.
                                      Can anyone kindly advice on how to test run this motor based on visible external two black wires. Fyi, i don't see any marking on the motor body nor smell anything...
                                      11-24-2023, 07:54 PM
                                    • wolf1976
                                      wireless receiver for 6 speeds fan control with remote control
                                      by wolf1976
                                      hi i have a receiver that is destroyed from the overvoltage i guess
                                      my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
                                      the motor fan has not label
                                      i have an other receiver operational
                                      In your opinion can i measure the voltage at the output ?
                                      what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
                                      thanks in advance...
                                      07-23-2025, 03:12 PM
                                    • 13mh13
                                      Aluminum SMD caps vs thru hole caps (reliability)
                                      by 13mh13
                                      The PCB motor for 1987 Technics SLP-120 CD player has slow spin-up issues. Similar to what another tech in the below video reported.
                                      https://i.postimg.cc/kGrR6BpZ/image.jpg
                                      I replaced the three bi-polar 47uF electros but that made no difference. The orig three bi-polar 47uF electros tested okay on my ESR M-tester.
                                      I have not tested/replaced those alum. SMD electro PCB caps.
                                      Are Al smd caps are more prone to failure (or degradation) than regular thru-hole electros?
                                      All the thru hole electros I removed / replaced on this CDP (and most...
                                      04-05-2024, 07:41 PM
