Nintendo 2DS Charging problem
+ More Options
Posts
  • WhiteWolfHellas
    • Jun 2019
    • 95
    • Greece
    Hello!
    I have a 2DS with broken charging port and a bad battery (wasn't even powering on). I replaced the battery from AliExpress and the charging port, and the system powered on properly, howerver the problem was with the charging. When i plugged in the charger, the charging LED lit Orange (solid) for about 4-5 secs, and then it started flashing orange. I'm using the original Nintendo charger. I used a working original battery and charger from another working 2DS but the problem was still there. Is there a motherboard issue? A chip that usually goes bad?
  • SistMaticZ
    • Jul 2019
    • 72
    • Morocco
    Re: Nintendo 2DS Charging problem
    check charging port connections to pcb.
    or check battery if its the real 2ds one.
    There could be something wrong with the "replacements"
    • WhiteWolfHellas
      • Jun 2019
      • 95
      • Greece
      I checked the pcb traces of the replaced usb jack and the voltage is normal (4.9v) from the charger. In case the battery from AliExpress was not working, I used a battery and charger from another working 2DS. The result was the same as with the battery from China. I don't know if the problem was there before I replaced them because it is a customer's console.
      • ngth82
        • Jul 2015
        • 541
        Do you have a known good battery that you can test with?
        -Thomas
        I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.
