Ps4 slim Hdmi encoder keeps resetting itself
  • liquidzorch
    • Oct 2016
    • 135
    • mexico
    Hello. I have a ps4 slim here that has and issue with the image coming uo on the screen for a split second, then black for a few seconds, ten back on for a split second. The hdmi plug is good, and I have replaced the encoder ic twice.
    There is no obvious damage to board, it had never been opened, and the ps4 was never even moved by the client, so he wasn´t disconnecting and connecting different hdmi cables.
    Using my oscilloscope I do not see any loss of voltages to the encoder ic, nor the 5v to hdmi hot plug detect. The only thing I could see is that the ic sends(or recieves) some digital signal on two lines going to hdmi (im guessing a handshake with tv) then it reboots itself and I see another "handshake".
    This all happens like clock work, it takes the exact same time every time to reboot and show something on screen. And I have not found any voltages dropping near the ic.
    I am guessing maybe an "enable pin" voltage drop, but I cant find any datasheet for these encoders. So I don´t know where to be looking. I have also found clock signal from southbridge, but that seems good.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8214
    Re: Ps4 slim Hdmi encoder keeps resetting itself
    did you try a different tv or a different resolution setting?
    • liquidzorch
      • Oct 2016
      • 135
      • mexico
      Yes, and yes. I rebooted into safe mode, and in between flashes, I was able to select change resolution, and tried 720 and 1080p. Neither work.
      • SistMaticZ
        • Jul 2019
        • 72
        • Morocco
        i would check related power supply to the ic
        • liquidzorch
          • Oct 2016
          • 135
          • mexico
          I don´t know the exact location of it´s power supply. But I have checked the two or three capacitors near the ic, which indicate the power supply line, and neiter have any power drops on my oscilloscope. I wish I had a datasheet.
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8214
            can you post some straight shot, high resolution pictures?
            • SistMaticZ
              • Jul 2019
              • 72
              • Morocco
              you need to rule out those caps with a dissipation factor meter if those are electrolytics.
              Also make sure to reflow or replace that hdmi signal ic . those are BGAs they need special soldering methods.
              • liquidzorch
                • Oct 2016
                • 135
                • mexico
                The caps are not electrolytic. And I have replaced the hdmi ic twice on this board. All three have had the same issue. I have replced them on tens of baords and never had an issue. So I can rule out it being the ic.
                • SistMaticZ
                  • Jul 2019
                  • 72
                  • Morocco
                  Okay .
                  Why did you conclude that it is a hdmi
                  encoder resetting problem.
                  GPU/APU or Vram can give this sort of display resetting problems not necessarly hdmi.
                  • liquidzorch
                    • Oct 2016
                    • 135
                    • mexico
                    Okay .
                    Thats what I was starting to think, a cgpu problem. I just wanted to be sure before discarding this repair or trying a cgpu reball. The weird thing is, is that there are no artifacts on screen or anything (during the second it has an image). And there is data flowing on the ddc lines, each time it
                    the image resets, which tells me the encoder is talking to the tv each time the image goes blank and restores. That´s why I thought it might be an encoder or communication issue.
                    • SistMaticZ
                      • Jul 2019
                      • 72
                      • Morocco
                      If it was an encoder issue there wont be any image encoded thus displayed in the on period.
                      Just try a reflow on the APU and Vram section. No need for risks with a full reball.
                      If these doesnt work then its a power supply issue in one of the sections.
                      • An-klamm
                        Ps4 slim WLOD not HDMI encoder IC
                        by An-klamm
                        Hello!
                        I bought 3x PS4 slim in the hope that I can repair all three so I can sell two and have one for free.
                        All three had the error that no picture is outputed but the LED lights up white.
                        I have already replaced the HDMI encoder IC and one PS4 is working straight away.
                        It seems to be a different error with the others.
                        I have measured everything that I can measure in the installed state. There are 5V, 5.1V, 2.4V, 3.6V, 1V, 2V. I can't see any differences between the working PS4 and the defective ones.
                        I have measured the HDMI port and all PINs have approximately...
                        03-30-2024, 03:57 AM
                        SHUTTLE XPC slim DX30 XPC slim J3355 Specification for Upgrade or Repair
                        This specification for the SHUTTLE XPC slim DX30 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC slim DX30 boardview and XPC slim DX30 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for SHUTTLE...
                        09-12-2024, 03:30 PM
                        HP Slim Desktop S01-aF0009nf Slim Desktop J5005 Specification for Upgrade or Repair
                        This specification for the HP Slim Desktop S01-aF0009nf can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-aF0009nf boardview and Slim Desktop S01-aF0009nf schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                        09-12-2024, 03:28 PM
                        HP Slim Desktop S01-aF0017ns Slim Desktop S01 3250U Specification for Upgrade or Repair
                        This specification for the HP Slim Desktop S01-aF0017ns can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-aF0017ns boardview and Slim Desktop S01-aF0017ns schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                        SHUTTLE XPC slim DH 110 XPC slim i3-6100 Specification for Upgrade or Repair
                        This specification for the SHUTTLE XPC slim DH 110 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC slim DH 110 boardview and XPC slim DH 110 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
