Xbox One X - HDD issues
  • Sadistic Taste
    • Mar 2014
    • 72
    Anyone here have experience with the Xbox one x consoles, with the corrupt saves issue? Sometimes games freeze, and also some start up errors like E102/E105.
    Appears to be failing HDD, however, replacing with a brand new hard drive doesn't seem to resolve the issue. Works for a days or two.
    I've seen many reports online, but no solutions that work.
    • 31094
    Re: Xbox One X - HDD issues
    so what does it say in the logs?
    i know the xbox shit writes a lot of plaintext log files to the drive.
    • petehall347
      • Jan 2015
      • 4427
      is it sat on a carpet ? might be getting too hot
        HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
        This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
        09-12-2024, 02:00 PM
      • unlogic
        Xbox One Controller (1708) battery powered issue
        by unlogic
        I have a strange issue with a 1708 controller when powered by battery. Wired it works fine, but on battery the light only starts flashing when you press and hold the X button. Once you let go it turns off. I've tried the same batteries on different controllers, and also fresh batteries, to no avail.
        Nothing seems off on the board on inspection. Any pointers as to where I might start looking or how to troubleshoot this?
        I've traced the battery line to around Q7 and Q6, and everything seems in order up to that point.
        I did a search already and haven't found...
        11-03-2023, 03:43 PM
      • rounin
        MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
        by rounin
        I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
        🛠 Original Issue
        The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
        ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
        04-19-2025, 01:18 AM
      • ugamazing
        Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
        by ugamazing
        I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
        We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
        12-17-2024, 07:05 PM
      • BigOof
        Marantz SR5007 popping on volume change and mute in Direct Mode
        by BigOof
        I bought a used Marantz SR5007 and it's giving me some issues that I can't seem to really place. It functions well in most settings, ARC mostly works, it has no issues driving my speakers in any of the digital input modes, but I'm having issues running analog inputs in direct or pure direct mode. For some reason in this mode there's distortion for every volume increment I give it, but once the volume is stable it has no issues. Muting creates a loud pop, switching to another source also causes a pop and so does turning off the amp in that mode. Again, no issue in the digital modes....
        12-12-2024, 06:15 AM
