sd sandisk 2gb delete does not work Tools?
  • samtron123
    • Dec 2012
    • 77
    • germany
    I try to erase my SD card does not work and in device manager and management have my SD card but not in the workplace
    many thanks
    • 31199
    Re: sd sandisk 2gb delete does not work Tools?
    did you try moving the write-protect switch a few times?
      Did you also try SD formatter?
      https://www.sdcard.org/downloads/index.html
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        Has anyone actually had success with the SD card formatter utility, versus just dumping all zeros to the device in, say, Linux?
        • goontron
          5000!
          • Dec 2011
          • 4108
          • US
          Ive had better luck zeroing with Linux. Otherwise, using SPI mode and zeroing it that way has worked as well
          Follow the white rabbit.
          • hollox123
            ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
            by hollox123
            Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
            1. Laptop keyboard doesn't work
            2. The backlight on the laptop keyboard doesn't work
            3. The x2 side LEDs (red) on the laptop don't work
            The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
            I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
            But I am strongly aiming that it is somehow a BIOS-related problem,...
            05-11-2025, 08:05 AM
          • resistor83
            lenovo 330s-15ikb, led num lock key always on and numbers don't work
            by resistor83
            hello everyone, I have a particular problem with this lenovo ideapad 330s-15ikb. I had to replace the motherboard due to liquid damage, after replacing it I noticed that some letters on the keyboard do not work. So I bought a new keyboard and now all the keys work except the numeric keypad area. In practice the num lock key LED always remains on and the numbers do not work. Has anything like this ever happened to you? I also tried changing the keyboard again but the same defect remains on the numeric keypad.
            I tried updating the bios but the problem remains
            https://s...
            05-29-2025, 08:06 AM
            DYMO Rhino 5200 Industrial Label Maker that the backlight does not work any ideas
            by sam_sam_sam
            I just bought a used one for a decent price for a used device it prints very nicely and clean and clearly so I am not going to complain about it but I would like to get it working again anyone have any suggestions on how to repair this back light
            If I can not get the controller to work properly then I will probably have an external power supply for the backlight because it is difficult to see the screen without out it
            One —>the LEDs might be bad
            Two —> the buck converter or regular might be bad
            Three —> the controller might not...
            08-08-2023, 05:12 PM
            Copy DMI info easily with Hex editing software and Macro script
            by SMDFlea
            Copying DMI information from an old bios to a new one is difficult for some members, often they have no experience with a hex editor,or some that have tried find it too hard.There is an option to make things easier for those members so that they don`t need to post their own bios backup for the DMI copying.
            Experienced bios modding members can help by posting in other threads the DMI offsets,macro script generated by the software and a download link to the software at softpedia mentioned in this guide,or post your macros in the comments here with a link to the bios request thread ....
            02-28-2023, 02:14 PM
          • Rhaverz
            My touchpad doesn't work, Asus laptop motherboard X455LJ REV 3.1
            by Rhaverz
            Good afternoon friends
            I have an Asus laptop motherboard X455LJ REV 3.1 that the touch pad does not work, I was trying to check if something was wrong at the drive level but I did all the necessary installations and the touchpad still does not work.
            I have a feeling that the error goes more to the board level because the touchpad is not recognized by the device manager and it is supposed that even if it does not work correctly it has to be detected.
            I even checked that the data bus made a connection between the touchpad and the motherboard and everything...
            03-30-2023, 03:56 PM
