Speed controller for golf trolley
  • redriddick
    • 93
    • Ireland
    Hi guys,
    Strange one here. I have a few speed controllers off some electric golf trolleys. They are not working and usually give trouble. New ones are about 80 euro so I said I might give it a go to see about fixing em. I will upload photos later.
    Any help will be much appreciated
    • 31094
    Re: Speed controller for golf trolley
    sounds fun.
    what are the motors like? single phase brushed, or 3/5phase brushless??
    • redriddick
      • 93
      • Ireland
      They are 12v. These are walk behind trolleys.
        • 31094
        damn, i though you meant little electric cars.
        so it's a motorised bag?
        golfers are lazy bastards!
        • redwire
          • 3910
          They look like this.
          • CapLeaker
            Leaking Member
            • 8223
            HAHAHAHA!!!! motorized bag!!! made my day!
              • 31094
              but it is - that's the joke!
              • redriddick
                • 93
                • Ireland
                Brilliant. That's the ones above alright. Sorry to burst your bubble stj
                  • 31094
                  btw, it looks like shit - i'll explain.
                  the center wheel is too narrow to put any weight on it on grass - it will sink down.
                  the outer wheels are better, but no real tread on them - ok if your pushing but not if they are driven!
                  • redriddick
                    • 93
                    • Ireland
                    They work quite well actually. If the ground is very muddy you can get spiked wheels
                    • CapLeaker
                      Leaking Member
                      • 8223
                      hardcore off-road version with diff locker... lol
                      • petehall347
                        • Jan 2015
                        • 4427
                        • United Kingdom
                        https://circuitglobe.com/resistance-box.html
                          • Jul 2011
                          • 6046
                          Can you post a picture of both sides of the controller board and the motor
                          • redriddick
                            • 93
                            • Ireland
                            Pics of one of em attached
                              • 31094
                              start by removing all the flux & shit from water ingress,
                              then remove and check the relay.
                              btw, the red & blue are touching - it should have used a connector there - cheap shit.
                              • redriddick
                                • 93
                                • Ireland
                                Here is another one, which is in better condition.
                                • redwire
                                  • 3910
                                  I'd check the two power mosfet's for shorts. The third TO-220 part seems to be a dual diode. Look for 5V at regulator U3 which powers U4 MCU, to see if the logic/MCU has power. I think the relay is part of a half H-bridge for direction?
                                    • 31094
                                    i still suspect the relay - when mosfets short they usually explode.
                                    • redriddick
                                      • 93
                                      • Ireland
                                      Tested mosfets and I think they are ok but I really need a new multimeter.......
                                      • redriddick
                                        • 93
                                        • Ireland
                                        Will test the relay tonight .....runs to Google how to test a relay
                                        • tomark
                                          Golf trolley charger Model G60 A2A power supply schematic
                                          by tomark
                                          Hi everyone
                                          I am just beginning, has anyone got Model G60 A2A power supply schematic.
                                          It's for charging golf trolley, input 100-240V50/60 Hz 1.0A output 13.8 v 3.3A.
                                          Please. If possible.
                                          10-29-2023, 06:58 AM
                                        • master3112
                                          ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
                                          by master3112
                                          I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
                                          When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
                                          10-29-2024, 09:32 PM
                                        • ronnygracias
                                          Help with freemotion incline trainer with controller comm error
                                          by ronnygracias
                                          The treadmill was working fine, one day the belt snapped and after checking the unit I also noticed that the display is now showing the Controller comm error. So I opened it up and the treadmill had two boards. One is a power supply board and the other is the motor controller. I noticed there was a mouse nest, so I took power supply board out, cleaned it up, replaced the big capacitor and that did nothing. Then I took apart the motor controller and cleaned that up, and when I plugged it in, it started right up. I thought I fixed it. But when the belt arrived, I installed it and tried to power...
                                          11-04-2024, 01:32 PM
                                          Tankless hot water heater controller board not powering up when power is applied
                                          by sam_sam_sam
                                          I recently bought a used tankless hot water heater and the controller board is completely dead no power up when power is applied the display board works however the main controller board does not work correctly at all the fuse is good
                                          I bought a used replacement controller board that also had issues that I was able to fix and now the tankless water heater works correctly now
                                          However I would like to know if I could figure what happened to this controller board if possible
                                          Tomorrow I will take some better pictures of both side of both boards
                                          The...
                                          12-09-2022, 09:14 PM
                                          Modifing a Battery Spot Welder because of Controller Issues
                                          by sam_sam_sam
                                          I keep having the same exact issue with these battery spot welder controller boards
                                          They either do one of two things
                                          One the controller does not send the signal for the transformer fire which is a very common problem with this controllers micro controller failure
                                          Or
                                          The controller has some malfunction which means that it does not cycle the pluses more than once or none at all and should do it any where from 1 pluse to 20 pluses because you can not change the setting does not respond to its input micro controller failure
                                          This...
                                          10-12-2019, 08:51 AM
