Like New Nautilus Exercise Bike has Dead Panel
http://www.badcaps.net/forum/showthread.php?t=24809 -
Re: Like New Nautilus Exercise Bike has Dead Panel
If the 4.99v was measured on the output pin it is likely ok if it is a TK111XXCS (or R50)
Or from EXAR, SPX5205 pdf
"A bar is added to indicate lead-free parts and can be mistaken as a “1” or an “I”."
If you can, it is best to follow the trace from a pin to nearby connected component to measure the voltage, or use a needle connected to your probeComment
Here's a pic of the back of the board, do I need to remove the panel?
I have you check the resistance between the cap and the output of that RG1 output pad to find out if that big IC where C20 is running on 3.3V from RG1 or not.Never stop learning
So, my lesson learned is (correct me if I'm wrong), if there is > 0 resistance between those two paths it means they are connected?Last edited by vestaviascott; 09-04-2018, 01:41 PM.Comment
Look up the spec sheet for that large IC to see what the max Vcc it can handle, it was fed by 7V so it may be damaged.Last edited by budm; 09-04-2018, 03:27 PM.Never stop learning
possible data sheets for the ic see r_j previous postLast edited by vinceroger69; 09-04-2018, 03:44 PM.Comment
"As your meter probes resistance" compared to what? I'm measuring the resistance between the output pin of the RG1 IC and the Capacitor, I'm not sure what other measurement I'm comparing that measurement resistance against in order to confirm a connection exists between the capacitor and the IC.
My (extremely) simple-minded understanding was that IF there was any resistance at all between these two components, then they are connected and that was what you wanted to test. However, it sounds like you are saying if, and only if, the resistance measured is the SAME as some other resistance measure then it means a connection exists.
Rather than simply blindly do these experiments, I'm really trying to understand the "WHY" of what I'm doing so that I can learn from the experience.Last edited by vestaviascott; 09-05-2018, 07:35 AM.Comment
Put your meter in 200 Ohms scale or the lowest scale it has then touch the two meter probes together to read the probe wires resistance, I.E. it may show 0.50 Ohms.
The lets say you checking the resistance of 0.47 Ohms resistor, the meter will not show 0.47 Ohm, it will show 0.97 Ohms, which means you need to subtract the probe wires resistance from the reading to get the resistor resistance, so 0.97 - 0.5 = 0.47 Ohms.
Do the experiment with a piece of copper wire by testing the resistance between point A (one end of the wire) and point B (another end of the wire) that is connected together by copper trace on the board or by a short piece of wire, it shows 0.5 Ohms, then you know that the connection between point A and point B is direct connection, then you can do visual inspection to see if that is true or not. BTW, always use the lowest Ohm scale for checking the connection between point A and point B
You can then replace a piece wire with resistor, I.E. 100 Ohms, so one end of the resistor is Point A, another end of the resistor is point B and see what you read on your meter, get the picture?
That output pin of BAD RG1 goes to may parts of the circuit, we already verify that it goes to positive pin of the C20 by checking the resistance and it shows < 1 Ohms using your meter in the lowest Ohm scale. I set my meter to manual mode at the lowest Ohms scale for this kind of test.Last edited by budm; 09-05-2018, 01:00 PM.Never stop learning
OK, confused again. Hopefully I haven't exhausted your patience yet with my continued probing for understanding...
A "resistance" of 0 means a perfect/ideal connection: "NO resistance".
An infinite resistance (often indicated by a "blanked" display or portion thereof) indicates perfect INSULATION -- no connection at all.
Trace the foils VISUALLY. I.e., you now KNOW that point A is connected (electrically) to point B. Now, put the meter on those two points -- you should see "close to" zero resistance. A signal would cheerfully flow from A to B as there is nothing IMPEDING its flow.
Now, find two points that you know are not directly connected. E.g., hold the probes in mid air, untouching, and see what meter says. A signal would have a helluva time getting from probe 1 to probe 2!
In reality, you will see something in-between these extremes for any two points on the circuit board. If you probe across R8 (near U1 in photo of post #62) you'll see something different than if you probe across R18 (same photo).
In these two cases (R8 & R18), you can see that there is a resistor between your probes. But, if you happened to probe between the left side of C7 and that feed-thru just to the southwest of R18, you'll get the same reading as if you had probed directly across R18. The point is, you may not be able to see R18 or even know that it exists when you probe two points in the circuit.
Hence my preference for newbies to visually trace conductors instead of relying on the meter -- which can be misleading!
For example, connect the probes on the two pins of C17 (tall black capacitor near the pair of ribbon cables). Watch the meter WHILE you are making the connection. Now, swap the probes and make the connection, again (while watching). Find an even bigger cap and try it again. Ditto with a small one.
If, for example, you put the probes on the power conductors entering the board, you will see the "net" resistance of the entire circuit board. Depending on the board, this can be very low -- yet, most often, you wouldn't consider it a "short".
Rather than simply blindly do these experiments, I'm really trying to understand the "WHY" of what I'm doing so that I can learn from the experience.Comment
by KYBOSHI came across a 50inch TU8000 that wouldnt start up properly (blinking stand-by light, backlights would cycle on and off).
When i opened it up and removed the power to the mainboard the backlights powered up and everything looked uniform.
When reconnected the mainboard but disconnected the flex cable to the panel i heard the TV startup with the intro sound.
Later I checked for shorts on the panel PCB boards but could not find anything.
When I took a look with the FLIR i noticed the 2 resistors...08-10-2024, 08:39 AM -
by NSkyLabTV Model: Vizio D43f-J04
Main Board: TPD.MT5583.PB751 (60103-00876)
T-Con: BOE_CC430LV2D_43001 V1.0
Panel: BOEI430WU1
The video of the defect is here: https://photos.app.goo.gl/fzfvmUqGXW3c1Nrg9
This is a dumpster find, don't know if it was hit, there are no visible cracks...
I though there may be something wrong with the panel voltages.
Those I managed to find on the T-Con board. Does it seem normal?
12V: 12.27v
VCC33: 3.28v
1.2V: 1.25v
VGL: -5.87v
AVDD: 16v
HAVDD: 7.47v
VCOM: 7.0v... -
by howardc6449UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on... -
by triplefourTV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
tcon is built into mainboard.
Only one cable goes to panel boards.
there is a cable from one panel board to the other that links them.
cost cutting measure that results in us having harder time to diagnose.
removing the link to the second panel board allows TV to stay on with stable backlight but no image.
used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board.... -
I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....01-13-2024, 01:57 PM - Loading...
