Vtech Phone repair CS6238-4 cordless phone
  • philm001
    • Jul 2018
    I am having an issue with a VTECH CS6238-4 cordless phone. The In Use LED is constantly blinking.
    I received this through a garage sale. The wireless phones are all dead and need charged. But, I am unable to do anything since the In Use led is blinking. The phones "charge" then turn on and says that the phone is unable to detect the base station because it has no power or is in use. The phones then turn off. This cycle repeats.
    I was wondering if anyone has had an issue like this before and if anyone knows of a solution? Thank you.
  • philm001
    • Jul 2018
    Re: Vtech Phone repair CS6238-4 cordless phone
    Anyone?
    • R_J
      • Jun 2012
      • 9588
      I found this for a different model It might work on this one?
      To manually deregister each handset:
      Step 1: Press MENU/SELECT. Display reads: Directory;
      Scroll to "SETTINGS" on the 6419 model
      Step 2: Enter *7890#. Display reads:
      “>Test Base”
      “Test Handset”
      Step 3: Scroll to “>Test Handset”, then press MENU/SELECT. Display reads: “>SW Version”.
      Step 4: Scroll to “>Next Page…”, then press MENU/SELECT.
      Step 5: Display reads: “LCD TEST” on top line. Scroll to “>Register Clear”, then press MENU/SELECT.
      Step 6: Display reads: “Reg Clear?”, then press MENU/SELECT. Press and hold OFF until “Out of range OR No pwr at base” is displayed.
      Step 7: Unplug the battery; wait a few seconds, then reconnect.
      Step 8: The registration instructions will appear on the display
      • SluggerB
        Help with trying to fix phone that is not charging (Pics inside)
        by SluggerB
        I have two TCL A30 phones.
        Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
        New Phone: Works fine, bought as a donor board to try and repair Old Phone
        My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
        08-12-2024, 08:11 AM
      • keeney123
        new OS on a Sonim XP5s phone
        by keeney123
        To you programmers out there I want to know if it is possible to put a new OS on the Sonim XP5s phone? I only need this phone to make calls, receive calls, have a list of contacts and be able to call voice mail.
        I bought this phone new Sep.2021 as an unlock phone from a third-party seller. The phone worked fine until Jan 2022. I then had intermittent problems with the sound setting resetting itself. One of the settings, outdoor, would go to silent all by itself. When in silent mode it does not indicate a call has come in. I missed very important phone calls. All the other setting in sound...
        05-13-2022, 07:19 PM
      • spleenharvester
        Cordless Dremel 8220 rotary tool power fault
        by spleenharvester
        Hi all
        I bought this Dremel several years ago (8220 + 880 2.0Ah battery). After about a dozen light uses it developed a power fault. I asked Toolstation to start a warranty claim for me and they just refunded me in full without asking for it back instead. Would be nice to fix it instead of consigning to the dustbin.
        It is complete luck of the drawer whether it powers on or not. Sometimes it will be completely dead, no lights no response. Switching power on and off repeatedly and/or removing and reinserting the battery will eventually make it spring to life. After that...
        04-13-2025, 02:10 PM
      • CapLeaker
        Poly VVX-250 VOIP POE problem not booting fix
        by CapLeaker
        I've got a bunch of Poly VVX-250 VOIP phones that work fine as kind as long as they are plugged into the wall wart. Recently I got around to install a couple of TP-Link 5 port POE switches that are added to the existing plain Jane 24 port unmanaged switch. Great!!! Finally I am able to ditch the wall warts from these phones making more space on the desk, plus I am gaining some badly needed power outlets. So I thought.
        Plugged in the first VVX-250 into the POE switch, booted up no problem. Plugged in the other Poly phones and they start to boot anywhere from 5 to 15 seconds,...
        11-25-2023, 10:46 AM
      • mikey5791
        Help with Samsung Galaxy J7 Prime phone
        by mikey5791
        Got this smart phone free from a guy who dropped it hard until the lcd display cracked with no seen display.
        Opened it and found the display ribbon cable partly damaged. I charged the phone full in 2 hours time, the led red light turns to green indicate full charge.
        Then i use a usb cable connect the phone to laptop but it only showed as media player with firmware version. Too bad there is no option to check folder.
        Does anyone know any method to check if the phone is working good? Looking forward for any advice and help possible.
        If tested the...
        09-15-2021, 07:54 PM
