Autohelm 3000
  • llonen
    • Sep 2014
    • 495
    • hampshire
    Autohelm 3000
    So I have one of these on the bench for a customer, its the older analogue compass rose version. reported problem with drive motor output. a brief examination shows a defective medium power PNP power transistor which I am having trouble identifying I dont appear able to source the service manual or circuit diagram for this. Pictures below best current guess is they are a pair of BD438
    There are two BD 441
    and two of these query BD438
    Many thanks in advance
    I can produce higher res images if this will help
    • 30983
    Re: Autohelm 3000
    complement of BD441 is BD442
    • R_J
      • 9535
      Re: Autohelm 3000
      Not sure what you are after? both data sheets are available.
      onseni list BD441 and BD442 80v 4amp NPN & PNP
      • llonen
        • Sep 2014
        • 495
        • hampshire
        Re: Autohelm 3000
        I have both data sheets, what I am after is input on the device that I am having trouble identifying, Complementary types are BD437 and BD441 although that looks to be a 4 with a possible 3 followed by what appears to be an 8
        This is the data sheet I was working to which lists several options,
        • R_J
          • 9535
          Re: Autohelm 3000
          The bd438 is rated 45 volts, I would use the BD442 rated at 80 volts, likely about the same price. I would use the higher voltage ones of the npn and the pnp
          or the NPN I would use the BD441
            • 30983
            Re: Autohelm 3000
            i would make sure what they are driving is not binding too - incase it's causing extra load.
            • llonen
              • Sep 2014
              • 495
              • hampshire
              Re: Autohelm 3000
              I have the drive unit here on the bench for disassembly and overhaul, so on the matter of the errant device a is a BD441 and BD442 combo going to work here given that I am not entirely sure of the device (BD438 being my best guest) and general lack of service manual / or circuit diagrams being available. In the mean time I have gone ahead and ordered the parts, will have to go with best option when they turn up lol.
                • 30983
                Re: Autohelm 3000
                are they dead - the mystery parts i mean.
                • llonen
                  • Sep 2014
                  • 495
                  • hampshire
                  Re: Autohelm 3000
                  They certainly are, well one definitively is one of the junctions is open cct as measured off the board the other I am not quite so sure about was getting odd readings in cct it does seem serviceable when removed. I am not entirely sure though. If I get time I might obtain a cheap transistor tester and see what that makes of it as I currently test with a fluke in semiconductor mode.
                  • llonen
                    • Sep 2014
                    • 495
                    • hampshire
                    Re: Autohelm 3000
                    Thanking everyone for their input on this repair, so after tracing out the circuit diagram for the board and confirming that the devices were configured as complimentary pairing final device choice came down to bd 442 as per above recommendation and datasheet. Drive mechanism was stripped down was indecently tested on a current limited bench supply cleaned re greased assembled.
                    Complete system then tested on a current limited bench supply, and successful results.
                    Thank you again for your input.
                      • Jul 2011
                      • 6036
                      Re: Autohelm 3000
                      Very nice to hear that you got it running again
                      Good job
                        LENOVO 3000 J110 3000 J E6300 Specification for Upgrade or Repair
                        This specification for the LENOVO 3000 J110 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 3000 J110 boardview and 3000 J110 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO 3000 J110...
                        09-12-2024, 03:36 PM
                        ACER Predator Orion 3000 600 I9200 Predator Orion 3000 i5-8400 Specification for Upgrade or Repair
                        This specification for the ACER Predator Orion 3000 600 I9200 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Predator Orion 3000 600 I9200 boardview and Predator Orion 3000 600 I9200 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                        09-12-2024, 03:28 PM
                        ACER Predator Orion 3000 PO3-600 Predator Orion 3000 i5-8400 Specification for Upgrade or Repair
                        This specification for the ACER Predator Orion 3000 PO3-600 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Predator Orion 3000 PO3-600 boardview and Predator Orion 3000 PO3-600 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                        ACER Predator Orion 3000 PO3-620 Predator Orion 3000 i7-10700 Specification for Upgrade or Repair
                        This specification for the ACER Predator Orion 3000 PO3-620 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Predator Orion 3000 PO3-620 boardview and Predator Orion 3000 PO3-620 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                        Lenovo 3000 Series Schematic
                        Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                        3000 C100 laptop with Braille keyboard
                        Lenovo 3000 C
                        C100, C200 - 15-inch XGA screen
                        Lenovo 3000 N
                        N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                        N500 - 15.4 inch screen.
                        Lenovo 3000 V
                        V100, V200 - 12.1-inch WXGA models
                        Lenovo 3000 G
                        G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                        10-04-2024, 06:05 AM
