Hello, small ps3 when powered up will shut down and there will be no red lights, if i unplug it and plug again it will do the same, you will see the fan running and everything will go off , please help
Ps3 shuttingdown
Re: Ps3 shuttingdown
Hispeck -
Can you post the model number of the PS3? It should start with CUH-****. or SCPH-****.
I think you mean the PS3 Slim based on the description. I would highly suspect it's a board issue, not the power supply. I've rarely seen bad power supplies in the consoles i've worked on. Most PS3 failures are Red Light of Death, or Green Light of Death issues. Those can be fixed temporarily, but you're better off just getting a used one off of Craigslist.
-Thomas-Thomas
I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.Comment
by EvazXHello everyone,
I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
However, after some time, the replacement motherboard...08-25-2025, 06:09 PM -
by odie34I am a hobbyist (not a professional) so please be gentle...
I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,... -
by hendekyHi,
I have a problem with my laptop. I just short circuit the eDP cable by an accident. Then i try to open it. i press the power button it was powered the rgb keyboard but after a few seconds and it just shut down. When i opened it up and unplug everything from motherboard i can't see any physical damage from ICs, capacitors and MOSFETs. I found a broken fuse FG3. But it just powers up LCD Display. I try to power it on with DC Adapter and feel some heat from an IC. IC is repeatedly power on and off. I tracked the schematic and i found some MOSFET and main 5V/3.3V controller. After that i... -
by berriferousSet was manufactured in 2012. I'm trying to diagnose where the problem is. I am assuming it is over-currenting after heating up? Display looks fine until it decides to shutdown. If I keep turning it on, it will eventually refuse to power up and requires unplugging to get it to respond again.
I originally thought there would be some easily detected bad electrolytic capacitors, but I don't see the telltale signs. There might be some very minimal bulging on one of the x buffer board. BN96-22092A (LJ92-01852A).
If I unplug the power feed to the X/Y board (LJ92-01854B), the... -
by thstuffA) TV initially dead
B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
C) Was able to perform a Reset from Settings menu and completed out of box configuration.
D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical... - Loading...
