Need help FORD FIESTA 2002 car which theft light is flashing
  • Esse
    • Apr 2014
    • 317
    • TOGO
    i have FORD FIESTA 2002 car which theft light is flashing and the car cannot start
    any help to solve this
  • Curious.George
    • Nov 2011
    • 2305
    • Unknown
    Re: Need help
    Assuming YOU aren't the THIEF, you should contact your local dealer (who will undoubtedly verify that you are the legal owner before sorting this out for you -- for a fee!)
    • petehall347
      • Jan 2015
      • 4450
      Re: Need help
      be sure you have correct key with chip . unlock door then lock door then unlock door and try to start car .
      • Spork Schivago
        • Mar 2012
        • 4734
        • United States of America
        Re: Need help
        Did the battery die? I guess that can put certain cars in theft mode.
        -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
          • 31296
          Re: Need help
          more likely the imobiliser has lost it's eeprom data - it needs to be re-coded to the key.
          *very* common on mercedes for some reason.
          • STKR123
            Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
            by STKR123
            As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
            I wonder if re-flashing the BIOS might be of any use here.
            As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
            There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
            11-03-2024, 06:58 AM
          • learnmore
            Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
            by learnmore
            Hello Community!
            CASE DETAILS
            Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
            13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
            Tried inserting firmware on USB and left it in for a few hours, but no change
            03-03-2024, 09:49 AM
          • SluggerB
            Help with 2002 Ford Ranger blower motor
            by SluggerB
            So I picked up this little truck, and the blower motor does not work correctly. There are 4 settings, Low, Med-Low,Med-High, and Max. The issue is Low, Med-Low, and Med-High ALL act like Low. Max works like Max.
            So research tells me it is the resistor block for the blower motor. So I change that. Still works the exact same. More research tells me the plug going into the Resistor block often gets corroded and faulty, so I change that. Still works the exact same. More research says sometime the switch in the cab goes faulty. I replace that. STILL WORKS THE SAME.
            From...
            11-10-2022, 04:58 PM
          • H34TO
            ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
            by H34TO
            Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
            06-17-2025, 07:17 AM
          • HTR-Informatique
            Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
            by HTR-Informatique
            YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
            I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
            On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
            I also changed the screen because the PC fell and the screen was broken.
            I changed the battery with a new and original battery.
            I also had corrosion/oxidation on the...
            02-09-2025, 06:51 AM
