Roku 2 dead after storm, burned resistor
  • sansonet
    • Nov 2013
    • 245
    • US
    I have two roku 2 players, one was used, another one was not plugged in at all. This night I heard lighting hit really close to house and in the morning Internet modem and roku player was dead. Roku was connected via Ethernet cord, both devices was plugged in surge protected outlet. I opened bad Roku and found what looks like burned resistor, its next to Ethernet port marked R99. I checked that resistor on good player - it shows 0.1 omh. Attached pics are of both good and bad boards.
    I need ID of what it might be to replace it, also what are chances something else was burned and what I should test, I could use good one for reference.
  • medi777
    • Sep 2013
    • 18
    • Albania
    Re: Roku 2 dead after storm, burned resistor
    you have to find the schematic
    • sansonet
      • Nov 2013
      • 245
      • US
      I doubt I can find one, so there no way to test this component on good player to find out what it is?
      • gabiz_ro
        • Mar 2011
        • 171
        • Romania
        R99 connect RJ45 metal case to GND
        Can work fine without too.
        So problem is elsewhere.
        • sansonet
          • Nov 2013
          • 245
          • US
          Apparently it were surge was located, probably got trough Ethernet port, should I test components that are near by?
          • gabiz_ro
            • Mar 2011
            • 171
            • Romania
            First check if all voltage are present.If not identify where is the problem.
            But after strike lighting hard to believe will survive.
            • sansonet
              • Nov 2013
              • 245
              • US
              I will see what I can test later today, but when I disconnected it this morning, it was off (no status light or video) but unit felt pretty warm to touch - apparently it was getting power.
                • 31301
                probably smoked the SMSC ethernet controller.
                • sansonet
                  • Nov 2013
                  • 245
                  • US
                  Can it by bypassed to use wifi only? I also wonder how lighting got it, that Roku and modem both are plugged in UPS backup system which have surge protection, unless surge went trough DSL phone cable to Ethernet. But VOIP phone adapter plugged in modem have no problems, PC works fine too.
                  Will it be safer to use WiFi connection for Roku from now on? I always preferred wired, but now I not sure if it is safe to use.
                  I might check inside modem, but its not really important because provider will be replacing it.
                  • Sparkey55
                    • Jan 2010
                    • 1523
                    you are lucky. A direct lightning strike would have burned your house down. That was close induced EMP. High frequency/High voltage strike. That is why I ground everything in my home. Your PC is grounded through the safety ground third wire power cord (hopefully). Most of these modems, routers and streamers are not grounded at all.
                    • sansonet
                      • Nov 2013
                      • 245
                      • US
                      I just looked around, is this where it happened? This is transformer near my house, I still wonder why Back-UPS not protected those devices. How do you ground yours?
                      Also, should I contact power company to check on it? They just installed that new transformer couple month ago.
                      • Sparkey55
                        • Jan 2010
                        • 1523
                        At this time I use #6 gauge copper wire connecting all my electronic equipment to a 6 foot copper clad grounding rod in the ground and that is bonded to the power utilities ground rod.
                        • sansonet
                          • Nov 2013
                          • 245
                          • US
                          I opened modem just to see what was fried there - couple resistors burned near one of ports. Im not planning repair it, but want figure out from which end surge was. System set up like this - modem and Roku plugged in Back-UPS with surge protection, Ethernet cable from modem plugged in Roku, from Roku AV signal trought RCA cord plugged in RF modulator and from there it sending signal via coaxial cable to several TV's around house. RF modulator not burned too - it lights up, but not sending any signal. I didnt mentioned it earlier because they are cheap enough and I have couple more laying around anyway. The same coaxial cable runs to barn outside to TV in there as well, buried in ground. Can surge come from that end? And can it possibly travel from modulator AV cable to Roku and then via Ethernet cable to modem? It still not explains why power line transformer looks burned too, unless there was two strikes my yard. I heard two of them pretty much loud, one was stronger than other, couple min apart. Just want make sure I can prevent something like this future. BTW, TV's that connected to that coaxial working fine.
                          This is pic of modem board
                          • Sparkey55
                            • Jan 2010
                            • 1523
                            There should be a direct ground wire connection from the shield of the coax cable to earth ground on the outdoor service entrance and this ground wire should connect to the power companies grounding system via ground rod.
                            Remember lightning wants to find a good ground. It will travel THROUGH ALL the wiring to find a ground and this is what does the most damage. DO NOT make your ground connections from equipment in a Point-to-Point fashion, (like a big chain). Make ONE ground point with ground wires terminating at each device. The shorter the better.
                            • CapLeaker
                              Leaking Member
                              • 8352
                              Yeah possible... Does that barn have it's own grounding system, or is it's grounding system connected to the grounding system to house?
                              • mikey5791
                                Need help to replace burned resistor in 350w atx psu
                                by mikey5791
                                Hi to all forum members,
                                Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                                The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                                Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                                Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                                12-26-2024, 04:55 AM
                              • bobbintb
                                TCL Roku 55S403TCAA dead after storm
                                by bobbintb
                                I have a TCL Roku 55S403TCAA. It quit working after a storm. Other electronics quit working as well so I am pretty sure the storm had something to do with it. Anyway, I took a look at it, no obvious damage, blown components, scorch marks, etc. I am looking at the power board first, 40-L141H4-PWG1CG. I've repaired bad caps and blown components but nothing more extensive beyond that. I am trying to troubleshoot it, but I can't even find the fuse on this board. There are markings on the PCB saying "replace fuse as marking" however. I attached a photo of the board. I am also testing the...
                                11-19-2023, 05:02 PM
                              • Andreasbest
                                Lenovo P50 dead with burned motherboard
                                by Andreasbest
                                Hello.
                                I received a P50 in very good shape that is dead and smelled burned board when on power supply.
                                I strip it and found a heavily burned area, there should be some cap but now are smoke.
                                Not sure where the one copper trace stops and starts the next, they seem mixed probably due to heat, this is my main problem as i'm not sure where should i solder what, so any help is appreciated.
                                Schematics & boardview here
                                Pictures os the affected area attached below.
                                Not sure if it can be saved but i'll give it a try.
                                Thank you in advance!...
                                03-26-2024, 06:22 AM
                              • jinu_j
                                by jinu_j
                                Hi
                                05-03-2025, 10:51 PM
                              • quic307
                                Hp 17-ab burned IC vRAM and dead vga chipset
                                by quic307
                                Hello team,
                                I have one HP 17-AB with motherboard DAG37DMBAD0 REV D. The motherboard has problem with burned IC vRAM and dead vga chipset.
                                When I opened it, I get 5-4 blinging error and after 3 times opens and works.
                                I want to use the notebook with cpu only and to deactive the vga.
                                Does anyone knows how to by pass the error?
                                I attached schem and photos.
                                MOD Edit - Link to Schematic https://www.badcaps.net/forum/showthread.php?t=83938
                                Reminder: rules and organization of this section https://www.badcaps.net/forum/sh...
                                09-26-2023, 02:21 AM
