Plasma Cutter Giant Tools LGK-60 not working
This topic has been answered.
  • petehall347
    • Jan 2015
    • 4426
    • United Kingdom
    Re: Plasma Cutter Giant Tools LGK-60 not working
    sorry no idea .. i have a neighbour that fixes them but cant use them so he pays me to to do the work with the machines . . thinking about it there must be high voltages needed and be driven by certain frequencies ,
      • Jul 2011
      • 6039
      What is the part number of IC 1 in the photo that you have posted
      Do it have any optic sensor on any of the boards and have you checked them
      Have you checked if the IGBT module is getting the command power signal to turn on
      • CapLeaker
        Leaking Member
        • 8159
        Umm, no... the other way around. AC is converted to DC, then the DC is converted back to low voltage, high current AC. PWM is good to 500khz so I am guessing they run around 250khz.
        That is the control module or where everything is starting to happen. There is a small PSU, IC1 is a UC3843 PWM, then there is this massive gate driving circuit. I am thinking in order for the arc board to turn on, the inverter has to be running as well. I've checked what I could on this controller board, but didn't find anything that sticks out.
        On top of the inverter board to the far right are 2 connectors. The smaller one with the 2 red cables coming out go to the arc board and gets switched by the black relay. From there it goes through the transformer and through bunch of arc circuitry, that spark gap and the 2 output lugs XS1 and 2.
        I still haven't figured out how this controller board gets enabled or turned on.
          • Jul 2011
          • 6039
          [LIST]
          Do you think IC1 is working I seen this type of chip go bad in servo controller before if this chip does not cost much I would recommend replacing it
          What is the part number for the IC chip that has a ( #6 ) on it
          I thinking that this chip might be controlling the power on command if it is some type of micro controller
          Can you show this part of the circuit ( arc circuitry ) board if you can
          Also some do you get any type of arc at all when you push the button to weld
          • CapLeaker
            Leaking Member
            • 8159
            On the last pic that 16pin IC (I think it is a KA3525A For some reason it also could be 9535 or a 8535, hard to tell) is the PWM that drives a couple of predrivers (them 4 TO-220 packages). While there aren't any shorts, them two gate drivers measure a bit different on the 16pin IC (compared from one to the other).
            There is absolutely no arc at all, if I press the button, all that happens is I get air.
            • petehall347
              • Jan 2015
              • 4426
              • United Kingdom
              #26
              is there a sensor that checks air pressure before arc can happen ? just a thought like .
              • CapLeaker
                Leaking Member
                • 8159
                This one doesn't have that feature. It only has the air valve. There are also no extra little gimmicks in the wand that disables the machine, if the head is off or something like that.
                  • Jul 2011
                  • 6039
                  I would replace the PWM IC chip and see what happens did you check the ( 4 TO-220 devices to see they all the same exact reading
                  • CapLeaker
                    Leaking Member
                    • 8159
                    Well, I did put that thing back together and did more measurements. I have 345V DC going to the inverter board, so the PSU is O.K, but nothing coming out from the inverter when keyed up.
                    However there is just one plug that goes from the control board to the inverter board and the wires are red, black, green and green. If I unplug the control board from the inverter board, I measure a short of 8 ohms between the red and black wire at the inverter side.
                    The control board side measures 680 Ohms between red and black.
                    On the picture them red and black wires go to that little transformer underneath those 4 wires. O.k. maybe there should be AC on it and I got nothing.
                    Left of that little transformer there are 4 black and 4 red wires. Those come from the PSU and provide the 345VDC. That red side is going to BOTH lugs of that little transformer on the left side If I measure between that, I get 2 ohms resistance.
                    The black and red wire from the 4 pin port go to the right side of the transformer. That is where the 8 Ohms short comes from.
                    If I measure DC between either black and red to either of the green wires, I get 25.8VDC untriggered and 25.3VDC when I trigger that wand. I am pretty sure the inverter isn't getting keyed up. No output of the inverter, there wont be any sparks.
                    I've tried every AC / DC measurement combination available on the red, black, green, green wire to see if there is a some clear signal that triggers the inverter on and didn't find any. Bummer.
                    • CapLeaker
                      Leaking Member
                      • 8159
                      I am going to order replacements for all 3 IC's, on the control board and see whats happening...
                      The two green wires go to the PWM pre drivers, the black is GND and the red one goes also to that little vertical pcb on the control board.
                      • CapLeaker
                        Leaking Member
                        • 8159
                        Well guys and gals... The plasma cutter is FIXED! The last problem was that the control board didn't get the signal to turn on.
                        Besides the bad main filter capacitors, the trouble was actually on the arc board. The turn on signal was there for the air valve, but not for the controller board to turn on the inverter. I chased things around on the arc board and found 2 bad 22k resistors R6 and R15. R6 was way out and R15 was out of spec. Changed them out (look at the brown resistors) put it back together and I got 465V AC from the inverter, but no arc. Adjusted the spark gap FDQ to roughly 1.25 to 1.50mm and low and behold I've got the arc going in between them plates. Finally that case is closed and that stupid thing isn't smarter me.
                        This fix is for those that have the air valve go, but no AC voltage coming out of the inverter board when keyed. So there will be absolutely no spark from the wand, acts like dead.
                        On the arc board the trigger goes to CN5 (blue and green wire). The turn on signal for the controller board is on CN4 (the one on the right to CN5) and has a red, blue, green wire.
                        Between that blue and green wire should be 5V DC going to the controller board when triggered.
                          • Jul 2011
                          • 6039
                          Good work
                          I am glad you finally figured out why it was not working
                          Save it from the land fill
                          • CapLeaker
                            Leaking Member
                            • 8159
                            yeah... had to wait for things to warm up around here. I didn't like working in the cold garage. Actually, once one figures a plasma cutter out how things work inside, it isn't that bad. Of course a schematic would have been helpful, but that's waaay to easy, hi.
                              • Jul 2011
                              • 6039
                              This is half the battle is understanding how it works and how the controls work
                              It would be easier
                              but most of the time there are no schematic
                              or
                              they are not complete only certain part
                              or
                              they are function block diagrams
                              • CapLeaker
                                Leaking Member
                                • 8159
                                BTW, I've heard back from that guy today. He was saying that this plasma cutter never worked so good like it does now. Made my evening!
                                  • Jul 2011
                                  • 6039
                                  Yes sir
                                  that is what is important
                                  I like that kind of feedback
                                  • RickYuke
                                    • Mar 2020
                                    Read with great interest your posts on this. I too have the same unit same problem, though the caps don't looked cooked like yours. My question you mentioned that the cutter was hooked up wrong, wondering what was meant by than, my unite is a 220V set-up. Thanks
                                    • CapLeaker
                                      Leaking Member
                                      • 8159
                                      Someone had put a different plug on the cable and was wired up wrong.
                                        • Jul 2011
                                        • 6039
                                        What the power in cable if so why was it marked to the way it suppose to be hook up
                                        If not the main power in
                                        What cable was hooked up wrong
                                        • CapLeaker
                                          Leaking Member
                                          • 8159
                                          The story I've got told was that someone had cut the plug of the power cord and put a different plug on it, randomly hooking up the 3 wires. However, this was corrected but the unit didn't work anymore and came to me. Surely there was a different plug on the cord.
                                          • capwizard
                                            Plasma TV to A Plasma Cutter.
                                            by capwizard
                                            I try to reuse Plasma TV IGBT parts for A Plasma Cutter and cut Plasma TV's metal cover!... I just need to cut through TV sheet metal. Budget is $10.00.............. Any help?
                                            How To Make a MINI Plasma Cutter! (easy)
                                            https://www.youtube.com/watch?v=yCUGh9F4lis
                                            How to Make Your own Plasma Cutter.
                                            http://www.instructables.com/id/How-...Plasma-Cutter/
                                            Opperation of Home Made Plasma Cutter
                                            https://www.youtube.com/watch?v=SuSqlZe9HYU
                                            Chinese 50 amp plasma cutter WOW!!!!
                                            https://www.youtube.com/watch?v=...
                                            02-14-2017, 09:51 AM
                                          • Hexram
                                            Tools - Order of purchase
                                            by Hexram
                                            Hey guys,
                                            I am new to the electronics repair game & have stumbled into some tools to get my workshop (garage) started.
                                            I managed to get my hands on a low budget multi-meter, soldering iron, de-soldering gun, oscilloscope and a variable voltage/amperage DC power supply.
                                            With this being a new hobby i am thinking of investing in some tools to make it a little easier.
                                            When i get paid next i was thinking of buying a Peak Atlas ESR 70 gold.
                                            I am after suggestions on what order to buy things because i don't have the money...
                                            04-24-2023, 04:03 AM
                                          • ArMaaN376
                                            Samsung PS51E550 Plasma TV
                                            by ArMaaN376
                                            I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                                            Opened TV cover & observed foll
                                            a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                                            b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                                            c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                                            How to confirm Y -Buffer board...
                                            06-19-2024, 04:05 AM
                                          • jm1234
                                            Panasonic plasma TX-P42ST50 - 6 blinks
                                            by jm1234
                                            anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                            It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                            I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                            I checked that board for any obvious faults...
                                            05-22-2024, 06:59 AM
                                          • KYBOSH
                                            Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                                            by KYBOSH
                                            Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                                            No picture but you hear the TV static (white noise) playing loud and clear.
                                            The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                                            But it seems they didn't get too far and just left it.
                                            When I first took a look I was amazed at how pristine the inside looked.
                                            Its as if the TV had been in a time capsule.
                                            Caps looked like they were just pulled off the self.
                                            Copper coils had no sign of corrosion on...
                                            02-01-2023, 11:10 PM
