Fubotv Apk will install but won't open?
  • ivtec
    • Dec 2008
    • 1967
    Hi guys i installed fubotv apk on my Android tv boxes but it won't open and i 'm stuck at -allow location access (orientation change to portrait-cannot click allow location access)
    it seems to me it's the only apk i can't open,is there any thing i can do to over come this permissions issue?thanks
    • 31003
    Re: Fubotv Apk will install but won't open?
    sounds like it's for a phone, unless you hack the binary or contact the authors your probably screwed.
    why is it 17meg????
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      There are apps to force a lock on screen orintation. I have to use it on my Androidx86 machines.
      Follow the white rabbit.
      • ivtec
        • Dec 2008
        • 1967
        goonstron can you please give a good and trustwood link for the app,
        i'm not interested on fubotv, but my son has it and i'm trying to figure out how to install fubotv apk on his Android Tv boxes, if i can open on mine than i will do the same on his.thanks
        Now that i red you reply more closely,i notice we are not on same page,it's not screen orientation,but opening an Android APK APP of fubotv, that requires location permissions.
        • ivtec
          • Dec 2008
          • 1967
          why is it 17meg????
          stj;i'm not screwed cause i only signed up with fubotv for a 7 day free trial,it's weird ,i can play any apk app out there and none fails to give me location permission,besides i have Iptv services for 15 bucks that give me a gazillion channels from all over the world with much better resolution and better streams then fubotv,which i tried 2 sport channels fox sports 1 and 2 and it was not stable at all,which for 50 bucks a month for few channels is a put off,
          • ivtec
            • Dec 2008
            • 1967
            I email fubotv about this issue and they answer this way.
            Thank you for reaching out to us! The Android app is still in beta and does not support every Android device as of yet, as we improve the app and its functionality you should see availability increase across more devices. Apologies for any inconvenience.
            If you'd like to cancel your subscription, you can follow the instructions here from our Help Center.
            Please let me know if you have any trouble completing this cancellation on your end. I can certainly assist you with this on my end, but would need to do so through a manager and may take a few extra days to process.
            Just curious, was there anything wrong with the service? A league or competition that you couldn't find? Technical issues you may have had? We would love to make fuboTV right for you!
            • TrumanHW
              MacOS: R|W Programmers like CH341x BINs..?
              by TrumanHW
              For years I tried figuring out how to R|W BINs from my CH341x programmer.
              From FTDI's pkg, Apps specifically claiming they work, I failed for ~8 years.
              I'd expect many here figured it out (easily), but in case not ...
              It's one of the few forms of "how-to" remuneration I can GIVE BACK.
              This group is both GENEROUS & literally BRILLIANT / GENIUS!!!
              This may be the easiest means to copy-paste:
              Code:
              SERIAL -to- USB - CH341 ROM (MacOS):
              Install xcode:				xcode-select --install
              Relocate
              04-08-2022, 02:33 PM
            • japlytic
              DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
              by japlytic
              In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
              Tried (only with keyboard/mouse connected):
              • BIOS + database update
              • Using latest Windows 11 image built with official image creation tool
              • Previous setup version for Windows 11 installer
              • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
              • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
              • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
              06-19-2025, 04:59 PM
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
            • reformatt
              Create MEAnalyzer executable from Github Python Scripts
              by reformatt
              Each new release of ME Analyzer only has the scripts but no executable file. It's handy for me to just run the exe in Windows, so came up with the following guide for those that might want it. Didn't see anywhere else how to do it, apologies if it is documented somewhere and I've just missed it.
              ME Analyzer – create Windows executable from Python script from GitHub
              1. Install Python 3.xx from https://www.python.org/downloads/ – select to add Python to PATH during installation. Current version is Python V3.11.
              2. Open an elevated Windows Command Prompt...
              02-06-2023, 07:33 AM
            • 24gsm
              MacBook Pro A1708 install macos fail
              by 24gsm
              hi to all
              i have MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
              after enter to recovery and format hdd 1to .
              after try to install macos online . its frezz at loading install in boot and i waiting few hour but nothing i ty install by boot using flash disk but same issu
              can help please
              Serial Number: FVFXP0U0HV2J
              Config Code: HV2J
              Find My Mac: OFF
              04-16-2025, 03:57 AM
