Post your worthless and/or pointless repairs
This is a sticky topic.
  • прямо
    • Sep 2022
    • 261
    • Indonesia
    #141
    My pointless and worthless repair is a 5V 3A switched mode power supply adaptor.
    What happened to it was a leaky main cap, and when I plugged, unplugged then quickly plugged back the adaptor, somehow that made the PWM chip blew itself up.
    The chip is OB2358AP. It cost about the same as a brand new adaptor, which is around $1.
    ​​​​​​I replaced the chip and the main leaky cap.
    It's been running fine since then.
    I also have another pointless and worthless repair.
    ​​​​​​A GTX 560 SE with missing components and ripped pads. Being an old DX11 card with only 1GB GDDR5, it has zero value, but I repaired it anyway.
    It's also running fine in one of my computers but I don't like the blower fan design, because it fails to cool down the VCORE mosfets. One of these days I will probably 3D print a shroud for it, that will allow me to mount a standard 90mm graphics card fan which I salvaged from a dead RTX.
      master hoarder
      • May 2008
      • 12175
      #142
      Good save!
      I don't think you can get a decent 5V 3 Amp power adapter like that for $1 new from the store.
      The one shown above is built very well - it has an input choke, proper fuse and thermistor, an and proper X2 and Y2 caps.
      All the cheapo adapters I can get new here (for more than $1, mind you) are gutless wonders with 1kV ceramic caps between primary and secondary, and a bunch of other cost-cutting measures.
      For someone as far behind as I am on the hardware curve, I'd say a GTX 560 (be it SE or not) is still a very decent video card.
      What's funny is I find GTX 460 and 560 cards can now be found on Ebay for very cheap... yet try looking for a high-end DX 9.0 card, and the prices jump back up, sometimes to absurd levels. Not sure what the retro PC crowd is smoking these days, but a GTX560 is perfectly capable of handling any XP games at high res without the cost of an arm and a leg.
      Also, many modern game requirements are stupid high nowadays for no reason. (Well, it's not for no reason... the reason is that coders / game devs are not willing to optimized anything for the PC, because it's expected that people that play games will always have good hardware. But Xbox and PS4/5, it's a different story.)
      The core appears to be running nice and cool, though - after all, 52C for GPU @ 100% load is not bad at all. I have the EVGA version on these cards (just regular GTX 560's) with the single fan in the middle, and those heatsinks designs suck even more. Sure my VRM MOSFETs might be getting cooled... but what good is that when the GPU core is running miserably hot?
      No thanks, I'll take a refference blower -style cooler any day. It also removes heat from the system (PC case) rather than just re-circulate hot air inside the case.
      BTW, you mentioned you fixed your card, but I see it's stuck in 1x PCI-E mode in GPU-Z. Is that because you're testing with an extension PCI-E cable (like those meant for mining rigs) or an error in GPU-Z? I have some dead/dying cards that also run only in 1x... or sometimes in 4x... but it's not due to bad ceramic caps near the PCI-E connector, I already checked. Most likely, it's a dying GPU in those cards.
      That said, if yours is connected directly to the motherboard's PCI-E 16x slot and still running in 1x only, check the other "non-damaged" ceramic caps to make sure they are not shorted.
      Whenever I see broken ceramic caps on a video card, I always assume it was not handled properly and thus any ceramic cap could be shorted. So for the ones on the PCI-E conn., I always check them all for short-circuit and proper capacitance. They should be either 100 nF or 220 nF.
      • прямо
        • Sep 2022
        • 261
        • Indonesia
        #143
        Originally posted by momaka
        Good save!
        I've seen better design from a $2 adapter believe it or not, and yeah, I bought this awhile back for $1. Price don't change for small power adapters like this.
        Yup, the core is cool and dandy but the mosfets aren't, they get very hot. I have two of these cards, with a reference blower and with a big fan in the middle. Both has the same core temp, but mosfets are not running hot on the one with the big fan.
        Correct. I took the screenshots with the card running on a 1X PCIe slot mining riser.
        And btw, a decent DX 9.0 card which is ATI HD 4870 1GB GDDR5 imho, cost about $3 but with a no display symptom, lol.
        If I do a retro gaming, I'd snatch that up and repair it.
        • прямо
          • Sep 2022
          • 261
          • Indonesia
          #144
          Card runs at X16 PCIe 2.0 on an old AM3 motherboard
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            Have not forgotten:
            Click image for larger version  Name:	pointless.jpg Views:	0 Size:	156.0 KB ID:	3525103
            Why did I bother... I'm currently using secondhand units from a thrift shop that will never have this problem.
              by momaka
              03-15-2023, 10:17 PM
            • lefetylorant
              Lenovo Thinkcentre tiny M90Q gen 1 - no 12V rail
              by lefetylorant
              Hello Everyone,
              Long story short, I got this unit for very cheap.
              I've started to experiment with it's BIOS, as I did before successfully with an M900. However my very bad quality SOIC clip broken while dumping of the biosof and it must have damaged something on the panel, because it does not turn on, and does exactly nothing when powered. The maximum voltage that could have affected something is the 3.3 or 5v from the IC clip, because the unit was not powered while the bios dumping was in progress.
              I've performed some measurements:
              - 20V rail perfectly...
              09-14-2023, 05:05 AM
            • Tdiamarelo
              Samsung Schematics for BN41-02156A
              by Tdiamarelo
              Hello folks, after 2 years of parenting its time to go back to repairs.
              I have a Samsung UE48H6200AW whit BN41-02156A Motherboard and i have the service manual for this device, but no schematics.
              I have a 5V rail issue, only delivers 1.6V and i need the schematics for this motherboard. Searched the usual places and got no result.
              Does any of you happens to have one or could help me figure this one?
              I think my buck regulator has gone bad (IC204 - Z3015PI), i get 3V on the ACC pin that only has a capacitor to ground.
              I compared to the second 5V...
              04-13-2023, 04:53 AM
            • javieromex
              HP Omen 15 DAG3DBMB8D0 strange 3V power rail
              by javieromex
              Hello
              I have this behavior on the 3V rail (PL101 capacitors side) (See attached image and Boardview).
              -I thought it was the 3V IC and I changed it and it's still the same.(PU101)
              -I injected 3V into the 3V coil and the PCH got hot (very slightly, 170mA). I removed US4 and the 3V power rail stabilized (3.3V stable) so I changed the PCH but it's still the same after replacing PCH. (Also replaced US4)
              -The enable of the 3V rail (3VS5EN) is following that pattern to.
              -The 3V LDO (+3VPCU) is stable.
              -I measure...
              10-21-2023, 12:47 PM
              Delta DPS-300AB-24b 300 Watt ATX PSU recapping
              by momaka
              Figured I’d separate the recapping details of this PSU in a different thread so that the information can be easier to find. To be more specific, this thread is about recapping of the Delta DPS-300AB-24b, shown here. All details about the build quality of that PSU are posted there.
              Here is the PSU, just to see what we are dealing with:
              And here is a cap diagram:
              Let’s break it down what goes where…
              * 5VSB
              *** cap spot C952: Ltec LZG, 10V, 2200 uF, 10x30 mm before PI coil
              *** cap spot C953: Taicon PW, 10V, 680 uF,...
              04-24-2020, 07:31 PM
