Xbox one controler does not turn on.
  • Drassh
    • Apr 2017
    • 43
    • Mexico
    I have a Xbox one controller model 1537 that does not turn on at all when I press the home button or to sync. It was tested with a usb power cable and with batteries but with no luck. So I proceeded to disassemble the controller to find out it has gotten wet by some kind of sticky substance. As a usual, with a deep cleaning using isopropanol alcohol to get the sticky stuff off then reassemble with no luck. The next step is to check to make sure all the individual components are getting the required voltage but this is were I need some assistance.
    All and any suggestions will be taken into account plus very appreciated.
    • 31300
    Re: Xbox one controler does not turn on.
    uploading foto's would help
    • Drassh
      • Apr 2017
      • 43
      • Mexico
      here you go as requested via dropbox. Let me know if the link works cause its hard to tell on Windows 10 S
      https://www.dropbox.com/sh/iady6hpnm5bofu7/AACdBAJBGdpmi8eSqBOiFcvma?dl=0
        • 31300
        upload by [go advanced] + [manage attachments]
        linking to temporary sites is bad because in future people reading this wont find them!
        • Drassh
          • Apr 2017
          • 43
          • Mexico
          Ok, here goes. Top and bottom views of the boards.
            • Jul 2011
            • 6070
            Start where the battery is and work towards the microcomputer or micro controller and see if get power to that point
            This means hit the power button to try to power ON unit when you try to getting these readings
            I would also look this hole board over with a magnifying glass at all of the soldiering joints to see if you crack or dull joints
            Look at these places at the battery and switches very closely for cracks and dull joints
            I have this problem with remote controls for our crane at work
            And we go from there
            • Drassh
              • Apr 2017
              • 43
              • Mexico
              ok will do. ill post the findings tomorrow.
              • Drassh
                • Apr 2017
                • 43
                • Mexico
                Just a side question due to having a bit of trouble mapping out the traces. Is there a program that i can draw on to map the traces manualy and if possible, to use a picture in the background to do so?
                  • 31300
                  dont think so.
                    • Jul 2011
                    • 6070
                    This where a volt meter comes in handy
                    Set your meter to ohms and where you think a trace end check it
                    or
                    if you can find where the trace ends just start probing around until you fine where you have connection
                    I have do a lot of times with double sided boards it dose take awhile to do
                    Now if it not a double side and you do not have large ground plans and you have a bright light on one side of the board and look through the other side of the board now some time you can do this with double sided boards ***** if the traces are not to close to each other and no ground planes
                    I have done this a few times doing repairs this way ***** some time it is not something that is very easy to do
                    I hope this helps
                    • Drassh
                      • Apr 2017
                      • 43
                      • Mexico
                      ok, so i was going to do what sam_sam_sam but i connected just the top pcb where the usb charging is located to the computer and saw that the lcd tries to turn on. I then proceed to go for the meter and with the pcb in hand i felt a burn from one of the components. Now, I have this usb device that mesures how much power a device is using in order to get charge. With this i check a normal working control to get .07 amps. Now the damaged controller is connected and shoots to .5 amps. 0.0 With it connected, a buddy feels around the board and notes that a few components around L3 are warm and U3 is "scorching" hot. with that in mind, we check various components around that area to find C22 and C23 in short but when we removed these components, they were fine but the short continued. We proceed to remove U3 as well but the short is still there.
                      ----Still checking as I write this to let others know how its going so far.----
                      • Drassh
                        • Apr 2017
                        • 43
                        • Mexico
                        update 1: My buddy found a thread on a modding site that has a detailed layout of the control, rechargeable battery, and the headset adapter that can be used as some what of an incomplete schematic. Using this to troubleshoot further.
                        http://www.acidmods.com/forum/index.php?topic=43204.0
                          • Jul 2011
                          • 6070
                          You need to find where the short problem is that will be important to know so you can repair it
                          • Drassh
                            • Apr 2017
                            • 43
                            • Mexico
                            Found it! Turns out its a bad capacitor marked C33 that was causing the shortage. Now, this raises a doubt due to the fact of some missing information. What value does this capacitor have in order to replace it properly?
                              • Jul 2011
                              • 6070
                              Where is the cap located at on the board power supply rail or some where else on the board
                              • Drassh
                                • Apr 2017
                                • 43
                                • Mexico
                                It is located on the power supply rail, bottomside of the board. Use the 3rd picture that was uploaded above as reference if you don't have a controller on hand. And thanks sam_sam_sam for bearing with me.
                                  • Jul 2011
                                  • 6070
                                  The value is not real important but use a 250pf something small like that and see if the unit works with a value like that
                                  • Drassh
                                    • Apr 2017
                                    • 43
                                    • Mexico
                                    Got it, and the controller is working now. ^.^ Thanks
                                    • F0ZZYB3ATZ
                                      • Nov 2017
                                      • 3
                                      • United Kingdom
                                      What's the value of c6?
                                      • gabri2211
                                        Xbox Series X Console Won't Turn On - Broken Nexus Connector on Mainboard
                                        by gabri2211
                                        Inside the console there is a small circuit board (see photo) that contains the main power switch, the one on the front.
                                        This circuit board connects to a 10-pin flat cable called NEXUS that terminates on the motherboard.
                                        This NEXUS connector broke.
                                        Can anyone tell me, while waiting for a replacement, if it's possible to turn on the Xbox by disconnecting this circuit board and making some modifications (like adding a small power button) on the motherboard?
                                        The Xbox has a power supply that provides 12 volts on all outputs, so the power...
                                        07-28-2025, 07:13 PM
                                      • Satdude
                                        Xbox 360E won't turn on after voltage regulator shorted
                                        by Satdude
                                        Hello, I have a Xbox 360E Stingray where the 3.3VSTB regulator shorted and put 5V on the rail. I think the RAM and eMMC are on this rail. After replacing the regulátor, I get proper 3.3V but the console won't even turn on. Seems the eMMC is dead, I get power to it just fine but JRunner doesn't even detect the console when I hook up my PicoFlasher. Does a dead eMMC/NAND cause the console to not even turn on? Also does this with the eMMC removed, planning to downgrade it to 16MB NAND but want to know if it's a useless effort to save this motherboard. Thanks
                                        08-28-2024, 03:55 PM
                                      • pajdek
                                        Lenovo Y700-17ISK turn on and off
                                        by pajdek
                                        Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                        09-20-2023, 02:49 AM
                                        HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
                                        This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                                        09-12-2024, 02:00 PM
                                      • RdeveLabs
                                        MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                        by RdeveLabs
                                        To all the members here...
                                        Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                        So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                        05-05-2025, 04:59 AM
