Furnace Blower Fan Cycles On/Off During the off Cycle
  • Longbow
    • Jun 2011
    • 623
    Re: Furnace Blower Fan Cycles On/Off During the off Cycle
    Reality check, refer to the furnace manual posted on the first post. There are 2 styles of motors used on this furnace. One style of GMP uses a standard 3 speed motor. This series should be straightforward to troubleshoot, especially when we find out which speed is coming on during the intermittent operation.
    The GMP models ending with "E" actually have electronic, or "ECM" motors that have electronically controlled speed (infinite). That series will have a more complex control board and more expensive motor. So, once again it appears we are dealing with a standard 3 speed motor as per your description above?
    Next, flip through the .pdf you posted and determine which of the 12 GMP diagrams apply to your present furnace - that would certainly help. If in fact you have a 3-speed motor, the most common failures are going to be 1)motor capacitor and 2)loose solder connections on the pcb motor relay terminals. The order of troubleshooting steps matters.
    So, what kind of motor? Which diagram? What speed is intermittently coming on and off?
    Is it plugged in?
    • srhofmann
      • Aug 2016
      • 135
      • usa
      #42
      Longbow,
      It's not the cap and it's not loose solder connections on the relays. There's an underlying issue either with the sensor(s) circuits or the board, because he's getting blink codes.
      Once the blink code issue is resolved then we need to see what happens. He has a plain simple 3 speed blower motor and something is telling it to turn on when it should be off. The control board in a failure condition, either the board failing itself or something that causes blink codes, can call for the blower and/or inducer fans to turn on even with the thermostat in the off position.
      • capwizard
        • Jun 2016
        • 1991
        Thanks to everyone who participated this Thread.....YES ...I fixed it.....by changing the control PCB of which I thought is unlikely to be ......so far so good......I will need at least three days to test system to make sure furnace work flawless .......
        PS: when furnace lit up look like the Apollo 13 launch to the sky.
        PS: I use discard wires as a zip ties, the easy ways to recycle......
        • capwizard
          • Jun 2016
          • 1991
          Furnace's PCB , A EPROM/ROM-Based 8-bit CMOS Microcontroller, designed to start up furnace's sequences, it drives circuits, sensors and relays.
          PS: Why !! It is not work still in further investigation......
          PIC16C57C
          This powerful (100 nanosecond instruction execution) yet easy-to-program (only 33 single word instructions) CMOS OTP-based 8-bit microcontroller packs Microchip’s powerful PIC® architecture into a 28-pin package. Easily adapted for automotive, industrial, appliances and consumer entry-level product applications.
          https://cdn.badcaps-static.com/pdfs/...88d10b865b.pdf
          The 16 pins IC is ULN200x High-Voltage, High-Current Darlington Transistor Arrays. To drive relays.
          https://cdn.badcaps-static.com/pdfs/...2f9b2d5b4e.pdf
          • keeney123
            Lauren
            • Sep 2014
            • 2536
            PIC16C57C
            This powerful (100 nanosecond instruction execution) yet easy-to-program (only 33 single word instructions) CMOS OTP-based 8-bit microcontroller packs Microchip's powerful PIC® architecture into a 28-pin package. Easily adapted for automotive, industrial, appliances and consumer entry-level product applications.
            So what is the brand and model of the furnace? Do you have a wiring diagram for the furnace?
            • srhofmann
              • Aug 2016
              • 135
              • usa
              #46
              PIC16C57C
              What isn't working? The new board or the old board? And what are the symptoms?
              • capwizard
                • Jun 2016
                • 1991
                Goodman model NO. GMP075-4 :the blower motor runs erratically, especially at day time even took out the thermostats. But when I set up thermostat to heat, the burner works flawless. After changed new PCB it stops the problem.
                PS: I found an easy way to fix the problem, just ask the neighbors, About 200 peoples in the community use the same furnaces and use same systems.
                GMP075-4
                https://cdn.badcaps-static.com/pdfs/...e2ee1acf8b.pdf
                • vinceroger69
                  • Mar 2012
                  • 6714
                  #48
                  the main thing is you have sorted the issue out and another happy customer who should refer you to friends family etc so maybe even more work in the future.
                  • capwizard
                    • Jun 2016
                    • 1991
                    Sorry, I haven't had a HVAC licence. so I can fix mine or friends's only....and i'm too old for that......
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      #50
                      main thing is its working and another job completed.
                      • capwizard
                        • Jun 2016
                        • 1991
                          • 31086
                          probably a bad relay.
                          • petehall347
                            • Jan 2015
                            • 4427
                            • United Kingdom
                            #53
                            well done
                            • capwizard
                              • Jun 2016
                              • 1991
                              I almost forgot one thing. The roll out temperature switches.
                              PS: To whom might find interesting, Roll out temperature switch, the temperature bending circular metal, letters on top are E3, some kinda temperature rating.
                              PS: I just trying to show, I still have some value for someone in this world.............
                              • capwizard
                                • Jun 2016
                                • 1991
                                Maybe Relay control circuit, on PCB has two Trs, as I tested they are Darlington Transistors, daytime maybe trigger the high gain Darlington Transistor to turn on because the dirt from water mark.
                                PS: cant find any information about this two Trs?
                                • capwizard
                                  • Jun 2016
                                  • 1991
                                  I forgot upload the pictures of Roll out temperature switch......................
                                  • Longbow
                                    • Jun 2011
                                    • 623
                                    Ok, the control board was faulty. A couple of comments. First has to do with 200 furnaces in your neighborhood. With a little more checking around the motor speed wires, you might have an idea about what part of the board failed. Then, you can drop a note to all 200 people who need the same repair. Second, you might stumble on a bad part on the board - maybe. Furnace control boards are hard to diagnose if it is subtle, since no schematics exist except in the factory. Also, many models of HVAC control boards were immediately updated once the manufacturer realized he did something stupid. It is wise to check out this possibility if you can.
                                    I agree that high gain darlingtons would not be my choice in a furnace. At over hfe 1000 a lot can happen when they warm up. Besides everything is vibrating its brains out on every blower cycle. If you find anything specific, let us know.
                                    Is it plugged in?
                                    • petehall347
                                      • Jan 2015
                                      • 4427
                                      • United Kingdom
                                      #58
                                      yes they could possibly turn on if tracking can occur .. are these just drivers for relays ? or some other job ?
                                      • capwizard
                                        • Jun 2016
                                        • 1991
                                        Roll out temperature switch is 350F and the temperature bending circular metal, letters on top are E3.
                                        So I decoded this (3) is for 300, (E) is for 50 .....so is 350F.....? and 280F will be marked H2, 250F will be E2 ?
                                        • capwizard
                                          • Jun 2016
                                          • 1991
                                          I am the Sherlock Holmes...........
                                          pic1 Put cooler condenser on the top of the furnace uses same blower fan, like you put an ice cube bag on your head!
                                          pic7 Water leaks everywhere!!
                                          • meraklinetx
                                            Asus Z97-a power cycle, no boot no cpu voltage
                                            by meraklinetx
                                            Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                                            05-10-2023, 06:08 AM
                                          • spice_disc
                                            Vizio TV M50-C1 reboot cycle and static on screen
                                            by spice_disc
                                            I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                                            The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                                            09-08-2024, 02:37 PM
                                          • nono34
                                            Hisense stuck in Colors cycle like test pattern.
                                            by nono34
                                            I accidentally changed the project ID in the service menu of my Vidaa Hisense 100U7KQ TV. When I turn on the TV, the screen displays an RGB color cycle (test mode???). I contacted Hisense, and they sent me a usb_MTK_9618.EU.bin file, but it doesn't work. I can see that the USB drive is being read, and it flashes for about 10 minutes (the screen remains in the color cycle during the firmware reading), then the TV turns off and restarts, but still in the color cycle mode.
                                            I want to mention that the 4GB USB is formatted in FAT32 MBR. I've also renamed the file to...
                                            10-24-2024, 04:31 PM
                                          • Yoda79
                                            Samsung ue55nu7021k Boot cycle
                                            by Yoda79
                                            Hi, wondering if anyone can help with a tv which seems to turn on but turn off soon after and continue to do this cycle over and over again.
                                            It turns on, no sound and then turns off and starts the whole cycle again. I've opened up the back and can see the backlights turning on. However when I disconnect the two straps connecting the left hard board (as you look on the back of the TV), the boot cycle stops and it does turn on and I can hear the boot up sound, however no video?
                                            Any thoughts, any help would be greatly appreciated.​...
                                            06-30-2024, 03:43 PM
                                          • applejuice95
                                            MacBook - 2021 A2485 - 16 inch - 820-02100-A - No Boot / No Power
                                            by applejuice95
                                            Hi there, currently working on 820-02100-A logic board - No boot Chime, no Power on. - Very Minor Liquid Exposure - All cleaned with IPA , did a partial ultrasonic as well . Clean and dry.
                                            MagSafe - Orange light cycles off then back on every 5-7 seconds
                                            USB-C Ports - All 3 get to 19.9V/20V - .5A then Cycle ever 5 seconds.
                                            All 4 CD3218 Chips have been checked at their LCD-CORE 3V5 and 1V5 lines at the local Capacitor, all are getting 1.5 and 3.5V But each have a different Voltage drop when the board cycles.. See below
                                            (PP1V5_UPC_LDO_CORE) - AT EACH CD321...
                                            02-13-2025, 09:45 AM
