"Weird Device" : Nutone Door Bell LA60
Last edited by goontron; 12-14-2016, 08:56 PM. Reason: I really need to figure out why this KB is missing letters......Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
Follow the white rabbit. -
Re: "Weird Device" : Nutone Door Bell LA60
i have not removed the kaypad, though i have tried lifting d114 and keypad pin 2. i'll get some solder wick after work today and remove the keypad.Comment
removed the keypad, no change. i can still get the lights to come up by shorting where they keypad would, still getting 1 or 3 randomly on doing so.
z105-z108 are the only possible culprits, right?Comment
Z106 could be bad... it would be a long shot though.... Yeah, probably one of the two. At this point i would pull z106 then retest, if that failed install z106 and remove z108 and test. If that fails, well, it's probably z105, yeah. Simple logic like z107 rarely fail, and wouldn't hold z105 busy.Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
Follow the white rabbit.Comment
i was reading the input notes section and it mentioned binary data lines on a through e. does this mean on z105 pins pa0-pa4 are actually just a binary number, 5v being a 1 and 0v being a 0? and then pa-5 is the keystroke "trigger"?
Pa-0 (pin 20 of z105) has 3v on it... pa-1 through pa-5 have less than .3 on them. unknown if it is coming from z105 or z106. but seeing as how z105's pa-0 is probably just a digital read it wouldnt give a voltage ever, right?
now that i see this, it makes sense why i never saw the thing put up an even number on this display. that also explains in part why the chime test button does no work, since it can never send the value '14' (tone test) and would instead send '15' (tone select).
should i just break the trace temporarily to pa-0 and see then if it will chime?Last edited by jasonbay13; 12-15-2016, 09:40 PM.Comment
So here is the data sheet for that key decoder you should be able to figure it out from this http://pdf1.alldatasheet.com/datashe...LD/74C923.htmlComment
Partial success!!!
this time i cut the trace for pa0 and found the 3v is coming from z105, somehow? but when i pulled it to ground and hit test tone (by shorting where they keypress would be) it played the tone.
my idea is to put a high value resistor, such as 20k and see if that hold it low whilst z106 might be able to supply enough current to push it back up. not sure whats going on here whether z106 is supposed to be able to sink a small bit of current or only be able to source.Comment
while looking further into this, i find that it is pin 19 on z106 is dead. shorting key '0' and key '1' gives no change to pin 19, while pin 18 will go high and low (as it should).
are there any replacements for this encoder anywhere?Comment
http://www.jameco.com/shop/keyword=key-encoder-icComment
ship in 112 days? and i'm assuming theres shipping on that. so expensive. maybe i could rig a switch. kinda inconvenient, but it only gets used twice a year (the control part).Comment
Is that what Jamco Customer Care told you, 112 days?Comment
a lot of chinese stuff is either old/surplus stock from manufacturing, or it's stuff desoldered/pulled from unsold products.
it's actually very rarely fake.
i buy a lot of old memory from china - eproms etc, and they are all the real deal.Comment
It is definitely a Fairchild logo and part number. I had looked it up on the Fairchild site, but if you have had good experience buying from them then why not buy as it is cheap enough.Comment
by sam_sam_samI have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that...
Macbook A1398 - had repeating loop of startup chime with no actual boot. Just startup chime, then restart, start up chime, then restart, etc. I pulled the battery and cleared BIOS. It will now power up, fans on, CPU warming, but no startup chime and no boot. I reflashed the BIOS chip but the same thing happening. Where should I go from here?06-14-2023, 11:45 AM
by sam_sam_samI had a lot of trouble with the WiFi connection from my router inside of the house into a ( new ) metal garage I had to run a 150 ft cat6 patch cord so the WIFI connection would be strong enough for the WiFi connection on the garage door opener would work correctly ( my son has a work out area in the garage as well and he was having to put his phone near the door to be able to stream music ) ( so I was going to eventually put WiFi out there anyway )
This garage door opener WiFi is very touchy if you lose the power it does not remember the password for the router which is weird or... -
by maxlove70Hello, I'm searching Bios for Packard Bell iSTART 2356.
Asus for Packard Bell M2NS-NVM (Boston) 0206 BIOS - 6A69NA01
Manufacturer and model: Asus for Packard Bell M2NS-NVM (Boston)
Chipset: AMD 1100
Part number: 6A69NA01
BIOS ID: 03/05/2007-NF-MCP61-M2NS-NVM-00
BIOS Release date: 2007-03-05
BIOS Revision: 0206
Packard Bell Support for this PC is discontinued.
Please Help Me !!!!
Thanks.-
by sam_sam_samI was having issues with the controller not always responding to remote control signal having to hold button until garage door started to move
Now after replacing the two capacitors on the two 5 volt power supply rails
One is used for the up/down limit up/down force circuits
Second one is used for the radio receiver circuit
The main filtering capacitor ESR value was a little higher than a new one
https://www.northshorecommercialdoor...yABEgLxlvD_BwE
... - Loading...
