Hello friends, Today I have the aforementioned PS3 in my apartment. The symptoms, Plug the console in, turn the rear switch on, the red standby light comes on and almost instantaneously, it beeps 3 times in rapid succession, followed by infinite blinking. I can't get any response holding either the power or eject buttons. At this point I tried removing the HDD and replacing it with another, but no dice. I have also vacuumed out the back but alas, nothing. I was having quite some difficulty trying to pinpoint results online as well. Every variation of the wording points me to the YLOD in a google search.
PS3 CECHE01 3 Red beeps when plugged in
Tags: None
Re: PS3 CECHE01 3 Red beeps when plugged in
If anyone knows anything about PS3 repairs. I'm completely at wits' end. Every single thing I find is completely unrelated to my problem. I simply do not know where to turn anymore.Comment
hmm. I'm sure it's possible. The question is, how would I test that theory?Comment
I guess I should've specified. I do know my way around a Multimeter, although I don't have access to an Oscilloscope. I'm just unsure how to proceed with measuring a PS3 , specifically my model. I'm not sure what points should give what kind of readings. I'm sure since there is activity from the Power LED that I would receive some sort of reading.Comment
PS3 CECHE01... that looks like an older "fat" model (switch on the back also gives this away).
Anyways, first check voltage on the +5V line on the power supply. I suggest two tests: one with the power supply still in the PS3 and another with the power supply disconnected from the PS3.
When looking directly at the small connector (that normally has a 4-pin white short wire attached to it and the PS3 motherboard), the +5V line is the right-most pin, the two middle pins are ground, and the right-most pin is STBY (equivalent to an inverter PS_ON signal on an ATX PSU). You should get 5V on the +5V line, both while the PSU is connected to the PS3 and when it is not.
After this, we will test the 12V line.
By the way, can you tell me the model of your PS3's power supply? ZSSR539IA by any chance?Comment
So sorry for the super late response. I got caught up in a mountain of projects. All of the voltages seemed to read normal based on what my tester indicated. I will have to tear the console apart to see if this PSU matches the model you gave.Comment
That's a Sony power supply. I don't recall ever having or seeing problems with these. So the fault is likely on the PS3 motherboard then. Since the light stays red and you don't get a YLOD (Yellow Light Of Death) when you try to turn on the PS3, then check all of the little SMD fuses on the PS3 motherboard. If I remember correctly, they all have "F_____" marks near them. And the fuses usually had numbers or letters on top (to indicate the current rating).Comment
I'll be sure to give that a try. To clarify just so we're on the same page. I am unable to actually turn the console on. When i flip the back switch on to go into standby mode, it does the beeping automatically. I can't hit the power button up front.Comment
Then definitely check the fuses I mentioned. Some of them are related to stand-by power, others for main power. That fact that you hear a beeping means the power supply is providing standby power.
Also, what board do you have? I *may* have the schematics for it. Not sure how complete they are though, as they were given to me by a fellow tech. I never had to use them. They are also very large, IIRC (like a few hundred MB).Comment
I managed to find what i think are all of the fuses and circled them using my magnificent paint skills XD. I've attached photos of what I found. my question is, how do I measure these fuses. I've seen normal fuses that have clear legs for positive and negative output, but these are so small I don't know how to measure them or replace them for that matter.Comment
Therefore, you measure a fuse using a multimeter set to the lowest resistance scale (typically 200 Ohms for manual-ranging MMs). You should get no more than 1-3 Ohms, or whatever is the lowest resistance your multimeter can show (some of the extremely cheap multimeters may have crappy probes and wires, so they may show as much as 3 Ohms even with the probes shorted to each other - i.e. the lowest resistance the multimeter can measure).
Also, very important when you measure fuses: make sure the power to the system is turned off and the power supply is disconnected from the wall.
Finally, if it comes to removing these SMD fuses, you can use a regular 60 Watt soldering iron with a chisel tip (if you can't get one with a chisel tip, then get one with a conical tip that is made of copper - that way you can sand it down to a chisel, bevel, or spoon-shape for SMD work.) And flux (rosin or RMA will do, doesn't matter if liquid or gel.)
Originally posted by birdboy385COK-002 is the board number I believe.Last edited by momaka; 12-12-2016, 08:03 PM.Comment
by crea2kHi I've got a ps5 in for repair. When it's plugged in it immediately beeps three times.
On the desktop power supply it pulls no current.
Under thermal camera nothing shows up.
All fuses test good
Voltages are :
F7002 - 5v
F7502 - 5.1v
F7003 - 5.1v
F5402 - 12v
F5401 - 0.18v
F3501 - 12v
F7001 - 5.1v
So presuming the issue is in the F5401 circuit.
I have probed it and see no shorts in the 5 components there. So not sure where to go from here as no idea what... -
by AimbitThe actual port is clean, and it is taking a consistent 930 mA, no dips.
Just did a battery replacement, the iPad did not work before either -- plugging in previously did a charging loop but went up to 930mA and down to 0, cycling, but it wasn't beeping at all. That battery is VERY dead, measured something like 24mV or something. So perhaps my replacement battery just has enough charge to make the beep, and the actual problem persists. Could this be a PMIC issue? It is not a Tristar on these but rather an Apple branded IC I believe.
Not that I suspect this matters, but... -
by ShinjuHey All!
Long time forum member here with a problematic laptop issue!
I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
The laptop would not power on with the new battery installed without the power supply being plugged in.
When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows... -
by ktmmotocrossHello.
Have this old hp compaq nc6320 that came with one long and one short beep + backlight on. bios battery have only 0.5V. I remove it, but now it start beep some weird way. I think it is bios /one long + two short beeps+ baklight on/, but when i flash new bios from hp, no beeps and no backlight.
i attach record of beeps...04-27-2025, 12:48 AM -
by KappaDevI have an HP Envy x360 15m-dr laptop which sometimes beeps 8 times on startup and sometimes gets no beeps at all (both with no picture).
Power button light comes on, fans spin and stop after a few seconds, then screen stays black with no picture. If the machine decides to beep 8 times, it shuts off immediately after. According to what I could find, 8 beeps was corrupted BIOS.
Made backup of original BIOS (attached). Attempted to flash BIOS with extracted bin file from HP BIOS update. Screen showed "Updating boot block", rebooted and immediately back to 8 beeps and... - Loading...
