Coffee Machine - YAY! I've blown my first capacitor (and a tip or two from a Newbie!)
  • Rhothgar
    • May 2015
    • 109
    • United Kingdom
    Following my fridge post yesterday, I thought I would try desoldering.
    I have a coffee machine which didn't switch on.
    I could see C5 cap was blown so got another faulty board and desoldered the capacitor from that. Took me a good 30 minutes or so to remove my first ever cap. If anyone hadn't done this before, watch a few videos on YouTube first.
    I doubt it is the best way to do it but I found lightly gripping the capacitor with a pair of pliers and loading the leads with fresh lead eventually worked.
    First off I tried desolder braid on each leg individually. Man! That wastes so much time and resulted in failure.
    When I finally removed cap, I checked it and it was within tolerance. Tools are important here ESPECIALLY if you are a newbie. I went out and bought solder braid and a no clean flux pen.
    I wiped over the legs (which still had solder residue on with the flux pen). One leg would not go through the one hole so I located it and went over both solder pads with the flux pen and the mask in between.
    I loaded up the iron and wipe back and forth across the holes whilst pressing the capacitor up towards the holes and seconds later pop, it seated and two defined pads of solder appeared! Brilliant! Well chuffed.
    Now this is where I need advice.
    I plugged the PCB back into coffee machine in workshop. Worked back to house and plugged in, reset and activate trip switch then reset again.
    Walked back out to workshop (15 seconds) and the replaced capacitor was smoking. Switched off quick before it blew.
    The coffee machine does not heat the thermoblock until you press a button so this circuit is live even though the machine appears not to be switched on. Not sure if that will give anyone any further clues.
    On closer inspection, the blue resistor doesn't look too good.
    Do any of the experts on here think that this could have caused the original failure and subsequent failure of the cap?
    Capacitor is rated at 400V 2.2uF. Polarity was respected when recapping. Remember! I'm a newbie at this sort of stuff.
    Can anyone tell me the rating of the blue resistor? I have used an app to try and identify it but I am not clear on which end to start from. I tried both but not convinced at result which states 47 Ohms 1% but one on new board, in-circuit measures 17.8 Ohms?
    • 31084
    Re: Coffee Machine - YAY! I've blown my first capacitor (and a tip or two from a Newb
    c5 is bad, the top is domed.
    the blue resistor should meter 4.7 ohms i think.
    you need to meter it for resistance - the peak esr meter can probably do it although it's not intended for that.
    • SteveNielsen
      Retired Tech
      • 2327
      I agree c5 should be replaced. I'd check c8 too.
      The resistor is 47 ohms, 5%. Check it out of circuit.
      • Rhothgar
        • May 2015
        • 109
        • United Kingdom
        C8 is fine in circuit. I need to trust the Peak. However, I checked the resistor on the new PCB and it measured 17.8 Ohms ESR in circuit but the marking appear to be 47 Ohms hence the confusion.
        The resistor on the broken board measures open with the Peak and as does C5.
        What I am looking for is a reason why C5 would go from fine to open circuit in 20 seconds! Would the resistor have caused that because I had not noticed the resistor missing some of its covering before powering the board back up after having replaced C5?
          • 31084
          no it's not, it has a final brown stripe = 1%
          the gold is a divisor.
            • 31084
            http://www.ankaudiokits.com/resistorcodes.html
            • SteveNielsen
              Retired Tech
              • 2327
              You're right, it's 1%, my mistake.
              • SteveNielsen
                Retired Tech
                • 2327
                Just to make sure it's understood, checking components in circuit is fine for quick trouble-shooting but readings are often altered by other connected components in circuit. To be sure the parts should be tested out of circuit.
                Without seeing a schematic my educated guess is yes the open resistor could have caused the cap to fail, however the cap may have been ready to fail anyway so it could have been a combination of factors.
                  • 31084
                  looking at the board,
                  i would start by checking all the diodes for shorts.
                  • Rhothgar
                    • May 2015
                    • 109
                    • United Kingdom
                    Understood.
                    Cap tested fine out of circuit and appeared to be within tolerance.
                    • Rhothgar
                      • May 2015
                      • 109
                      • United Kingdom
                      I'll check those too.
                      I've borrow a book of a friend entitled "How to fix everything electronic". It appears at first glance to be broken down into a nice understandable format for the likes of me.
                      • Rhothgar
                        • May 2015
                        • 109
                        • United Kingdom
                        I have found a diode which is showing .375 in circuit both ways.
                        All the others are showing 0.62 or thereabouts in circuit and OL in other direction.
                        The diode D1 is copper coloured looking. Is this a Zener diode? It is tiny! How can I find out what specification it is please?
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          D1 looks to be a GS1M, which is a 1A rectifier diode.
                            • 31084
                            lift one end and test it again.
                            • Longbow
                              • Jun 2011
                              • 623
                              Oh, please. If we all had to remove the parts from every pc board we would never get anything fixed, let alone designed. It is actually faster to replace all the parts at once with no testing whatsoever. Pretty obvious what happened in this case, judging by the appearance of one capacitor and one resistor.
                              Is it plugged in?
                                The Blue rectangular X/Y cap, do each one of the legs connected to Line and Neutral? That cap looks to be connected in parallel with the MOV.
                                That big Metal Oxide resistor (Red, ?,?,? bands) looks to be for dropping resistor and looks like it got hot, D1 is the rectifier for generating DC for the running the circuit.
                                Is the Lytics brown cap (c?) next to C5 rated at 2.2uF 400VDC also?
                                  This is what I can tell based on the pictures.
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    budm have you got c5 and l1 mixed up? im new to all this was just looking and trying to learn the circuits im using the picture in post 1 im probaby completly wrong though.
                                      I drew the line wrong so I need to fix that, thanks for seeing that, I have been flipping the virtual PCBA back and forth many times now.
                                      It is fixed now.
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        im new to trying to read these sort of things so good practice for me too,a easy mistake to make when going through all the pictures.Its good to see how you can draw these circuits out, i can see Now why now you ask for good clear picures.
                                        • MeetingIncapable
                                          Blown capacitor repair on MSI Radeon RX 5700 XT MECH OC
                                          by MeetingIncapable
                                          I am new to repairing computer electronics, so excuse any mistakes I make.
                                          A friend of mine had a broken graphics card (MSI Radeon RX 5700 XT MECH OC) and gave it to me. It does not power on or show any signs of life.
                                          I identified what looks like the remains of a blown capacitor at the bottom of the board (see picture).
                                          I wanted to replace the capacitor, but I have two questions:
                                          • Does this repair have a chance of working? or is a blown capacitor a sign something else is wrong?
                                          • How do I determine the rating/value of this capacitor? or something
                                          05-04-2024, 09:56 AM
                                        • NuclearSpartan
                                          Samsung C32HG70 - Blown Ceramic Capacitor (CP813)
                                          by NuclearSpartan
                                          I'm new to this, so I apologize for not providing enough details. Is there anything else I need to mention? I'm trying to learn more about electronic/board repairs and hopefully fix my own.
                                          The only visible issue on my board is one capacitor, CP813, which appears to be labeled R 221k 2kV (possibly obsolete to B 221k 2kV now). My monitor hadn't shown any prior issues, although it is a few years old. Just before the capacitor popped, there was a high-pitched squeal for 2–3 seconds.
                                          I don't see any other visible damage anywhere else on the board....
                                          11-14-2024, 02:32 PM
                                        • mon2
                                          Saeco SG200E Coffee Machine
                                          by mon2
                                          Hello. Have a known good Saeco SG200E Coffee machine but the internal hose from the pump were disconnected. Would someone be kind enough to share a few clear pics of the inside of this machine so we can reconnect the hose plumbing again? Many thanks....
                                          04-25-2024, 10:24 AM
                                        • tranquility
                                          newbie needs capacitor sizes. HP Spectre X360. schematic maybe available
                                          by tranquility
                                          hello, i am very new to laptop repair and generell electronics
                                          i have a HP Spectre X360 Convertible 13 - ap0016ng
                                          motherboard number DA0X36MBAE0 REV E
                                          massive burned and shortet mosfets. after removing them still shortet in the i think "main power rail"
                                          found a shorted capacitor. removed it and the short is gone.
                                          i want to try a crazy repair which is hard because the mosfets are like welded on one side to the track. is there a method to get this loose ?
                                          in this area another capacitor was shortet.
                                          12-06-2024, 04:12 AM
                                        • Gaz54uk
                                          AEG coffee machine no steam
                                          by Gaz54uk
                                          Hi. I have a built in AEG model PE3810-M coffee machine after about 2 years from new it had a problem were no steam would come out of the wand so i paid £80 to have it repaired after 6 months the same faulty happened again but the repairers said they only give 3 months warranty so we just left it sat there but now i'm wanting to get some use out of it, i'm 80-90% its one of the solenoids as waters still come out by the wand and the bit where it makes coffee, I've made sure all the pipes are cleared and can hear the pumps going but just not sure and don't want to start wasting money on parts unless...
                                          01-13-2024, 05:00 AM
