Coffee Machine - YAY! I've blown my first capacitor (and a tip or two from a Newbie!)
    Re: Coffee Machine - YAY! I've blown my first capacitor (and a tip or two from a Newb
    Please see if it looks correct now, thanks.
    • Rhothgar
      • May 2015
      • 109
      Originally posted by budm
      This is what I can tell based on the pictures.
      I feel like a spare part here! No pun intended.
      Where you are marking true? on the virtual PCB (very impressive by the way), are you asking for me to check something?
      It will probably be the weekend before I can strip it out again.
      Did you use the photos that I had uploaded to Dropbox in the end?
      • Rhothgar
        • May 2015
        • 109
        Originally posted by Rhothgar
        I have found a diode which is showing .375 in circuit both ways.
        All the others are showing 0.62 or thereabouts in circuit and OL in other direction.
        The diode D1 is copper coloured looking. Is this a Zener diode? It is tiny! How can I find out what specification it is please?
        Sorry Guys. Just realised please totally ignore this comment about D1. It refers to the milk frother that comes with the coffee machine!!!!!
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          Yes i think budm needs you to double check if the points hes marked true? is where hes the circuit actually runs etc just to make sure his drawings are correct and match the board layout.
          • Rhothgar
            • May 2015
            • 109
            The Blue rectangular X/Y cap, do each one of the legs connected to Line and Neutral? That cap looks to be connected in parallel with the MOV.
            That big Metal Oxide resistor (Red, ?,?,? bands) looks to be for dropping resistor and looks like it got hot, D1 is the rectifier for generating DC for the running the circuit.
            Is the Lytics brown cap (c?) next to C5 rated at 2.2uF 400VDC also?
            Yes C5 and C8 are both 400V 2.2uF Manufacturer KT with a dot in between the letters. Other markings: RL13C PET
            Metal Oxide resistor? Is that the one with the grey base or blue base?
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              #26
              grey base one.
              • Rhothgar
                • May 2015
                • 109
                #27
                budm
                You know where you have questioned TRUE? between 47 Resistor and other resistor which is the grey metal oxide one (I assume), do you want me to check continuity here?
                Is that what you are asking? I am very new to all this so need to understand what is being asked of me.
                Also, what are you using to markup because I need to mark up your edited PCB photo. I am on a mac and I am not that familiar with the highlighter in preview - it is very slow and tedious to use!
                I can switch to a PC if necessary if there is a good markup programme?
                  budm
                  That is correct, just to verify that those connection are made based on what I can see from the pictures.
                  So is it working or it still has shorted rectifier D1?
                  The big gray resistor looks like it got hot and I cannot tell what the color bands are.
                  I use the pictures from post #1 and scale them so the top and bottom are the same size to make the virtual PCBA.
                  Double sided boards are hard to trace the connections using the pictures that is why I put 'TRUE?' there.
                  I use PAINT.net on my PC.
                  • Rhothgar
                    • May 2015
                    • 109
                    #29
                    Please refer back to my Post 23!
                      "It refers to the milk frother that comes with the coffee machine!!!!!" Sorry but I did not understand what the 'milk frother' is in relation to D1.
                      • Rhothgar
                        • May 2015
                        • 109
                        #31
                        It's another problem I have with the milk frother which is a separate piece of kit on the machine. It has a kettle type connector and I had accidentally commented about D1 on that PCB and then later realised that I have not done a post about that PCB.
                        So I didn't want to confuse but ended up doing so because you didn't have the full picture.
                        I'll check D1 on this board which someone rightly said is a GS1M and report back.
                        Just really busy at the moment so may take some time to update.
                        Thanks for everyone's help on this so far.
                        • MORETTIGIAN
                          by MORETTIGIAN
                          Title:
                          Description:
                          Procedure performed:
                          - Removed backplate
                          - Reapplied thermal compound
                          - Reassembled card
                          09-18-2025, 12:14 PM
                        • MeetingIncapable
                          Blown capacitor repair on MSI Radeon RX 5700 XT MECH OC
                          by MeetingIncapable
                          I am new to repairing computer electronics, so excuse any mistakes I make.
                          A friend of mine had a broken graphics card (MSI Radeon RX 5700 XT MECH OC) and gave it to me. It does not power on or show any signs of life.
                          I identified what looks like the remains of a blown capacitor at the bottom of the board (see picture).
                          I wanted to replace the capacitor, but I have two questions:
                          • Does this repair have a chance of working? or is a blown capacitor a sign something else is wrong?
                          • How do I determine the rating/value of this capacitor? or something
                          05-04-2024, 09:56 AM
                        • NuclearSpartan
                          Samsung C32HG70 - Blown Ceramic Capacitor (CP813)
                          by NuclearSpartan
                          I'm new to this, so I apologize for not providing enough details. Is there anything else I need to mention? I'm trying to learn more about electronic/board repairs and hopefully fix my own.
                          The only visible issue on my board is one capacitor, CP813, which appears to be labeled R 221k 2kV (possibly obsolete to B 221k 2kV now). My monitor hadn't shown any prior issues, although it is a few years old. Just before the capacitor popped, there was a high-pitched squeal for 2–3 seconds.
                          I don't see any other visible damage anywhere else on the board....
                          11-14-2024, 02:32 PM
                        • expertreader
                          Found a blown capacitor - is it necessary to replace?
                          by expertreader
                          Hi all, Acer Nitro 5 - GH51M LA-K862P Rev 1A motherboard. I went through all the troubleshooting steps but couldnt find a short on any coils. By chance, ended up finding a blown capacitor PCZ49 which is suppose to be 2.2uF. I can see plenty of 2.2uF in the same +5VALW line which will all parallel up anyway - do you guys think it is critical for this cap to be replaced or i can get away without one?...
                          10-15-2025, 04:54 AM
                        • mon2
                          Saeco SG200E Coffee Machine
                          by mon2
                          Hello. Have a known good Saeco SG200E Coffee machine but the internal hose from the pump were disconnected. Would someone be kind enough to share a few clear pics of the inside of this machine so we can reconnect the hose plumbing again? Many thanks....
                          04-25-2024, 10:24 AM
