Help with Motor Control Board - ProForm treadmill
  • Crrose
    • Dec 2013
    • 165
    • Usa
    #201
    Re: Help with Motor Control Board
    Hmmm, that is an awfully small chip to try to remove and resolder, not sure I am capable of that without damaging chip or board.
    • Crrose
      • Dec 2013
      • 165
      • Usa
      #202
      So if I remove TC1410 and power it up and the motor just runs at full speed still then that chip is bad? Or could it be the 3 legged mossfet on the heat sink. However I just tested that one at 200 ohm setting and I get 42.3 with black pin 1 and red pin 2, 42.3 black pin 1 red pin 3 and .6 black pin 2 red pin 3.
        You need to check the resistance between the Source pin and the Drain to see if it shows low Ohm reading, from your reading, it looks bad, and it can take out the IC also.
        • Crrose
          • Dec 2013
          • 165
          • Usa
          #204
          With meter set at 200 ohm I get a reading of .5 ohm, in diode mode I have continuity.
          • keeney123
            Lauren
            • Sep 2014
            • 2536
            BudM you said the diode went across Source to drain because the diode in the chip was not big enough. In your picture on post 128 the diode is going from the B+ to the Drain not the source to drain.
              Ah, you are correct, I look at the trace layout and see how it is connected, it is basically across the motor for the motor back E.M.F.
              • keeney123
                Lauren
                • Sep 2014
                • 2536
                I am kind of sure that the way the diode is drawn the positive is on the positive side of the cap and the negative is on the drain which when the source connects to the drain that connects it to the negative side of the cap so that that would short out the capacitor. Maybe the diode's positive side need to connect to the negative drain and the negative of the diode to the positive cap voltage so it will not short out the cap but when the motor EMF collapses it will forward bias shorting out the motor.
                  The Cathode has to be connected to the B+, the Anode is connected to Drain (basically across the motor, there is current sensing resistor in series with the motor) so when back EMF will be diverted to the Diode. The MOSFET is connected as sinking for the motor.
                  This is how it is connected, the MOSFET sinks the motor:
                  http://www.spaennare.se/pwmdig.html
                  • Crrose
                    • Dec 2013
                    • 165
                    • Usa
                    #209
                    Ok so do I replace tc1410 or the one on the heat sink or both.
                    • Crrose
                      • Dec 2013
                      • 165
                      • Usa
                      #210
                      Saw this somewhere when trying to research:
                      "What I think should be done is to solder a shorting wire across the motor control FET & see if the motor runs when power is applied. To find the right pins for this, simply look which two have the heaviest traces going to them. Looking up the datasheet for the FET itself is another way to determine the pins. You need the FET's number for this.
                      You can do this test without bolting everything back onto the heatsink, provided you don't let it run for more than one second. You only need enough time to see if the motor runs at all, as it will automatically run at full voltage with the FET shorted out.
                      This will confirm operation of everything except for the FET & it's driver circuit."
                      That makes it sound like that 3 prong mossfet is shorted.
                        • 30953
                        if the relay is for static braking you are going to cause a bang fucking around like that.
                        • Crrose
                          • Dec 2013
                          • 165
                          • Usa
                          #212
                          No I wasn't going to try to short it like whoever that was suggested to someone else, was wondering if mine is shorted since the motor runs at full speed. I disconnected the power to the motor so I could turn machine on, I tested the VDD and GND pins again and still getting 12v on both sides if that means anything. Just trying not having to desolder and resolder a new TC1410 chip if I didn't have to since my soldering skills aren't great.
                            The MOSFET is already shorted out when you were probing the driver IC, you also verified that it has low resistance reading on the MOSFET.
                            If you replace just the MOSEFT without repalcing the driver IC then you are taking a chance of damaging the new MOSFET if the driver IC is damaged.
                            We need to get the unit back to the same condition as before you were probing the IC and damage the MOSFET.
                            ""What I think should be done is to solder a shorting wire across the motor control FET & see if the motor runs when power is applied." It is already running at full speed due to the shorted out MOSFET.
                            post 197:
                            Originally posted by Crrose
                            Selldoor in post #145 said it was so that's what I got. However I have a new problem now. I was testing to make sure I still had the voltage from that small 8 pin mosfet and I must have shorted it or something because all of a sudden the treadmill motor just started at full speed. Now it won't shut off except by turning power off, even when pulling out the safety switch.
                            post 203:
                            Post 204:
                            • Crrose
                              • Dec 2013
                              • 165
                              • Usa
                              #214
                              I guess I'll go get the 2 parts and work on my soldering, may get 2 of the power mosfets and replace it and see what happens. If if shorts again the I will have a spare and I may not have to replace that tiny tiny tiny solder joints.
                              Let you know what happens when I find them.
                                Please note that the IC TC1410, I do not know for sure if it is TC1410 or TC1410N, they are not the same.
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 4939
                                  • New Zealand
                                  #216
                                  Have a look at some soldering tutorial videos on Youtube, especially SMD ones (I think your controller IC is a SMD part?)
                                  There's a good general soldering video from CuriousInventor and a channel called SolderingGeek does a lot of SMD stuff too.
                                  Get some scrap boards to practice on if you want, it's actually not that hard when you're used to it (And before I tried, I thought it looked impossible) but you may need a little practice if you've never done it before.
                                  -David VanHorn
                                  • keeney123
                                    Lauren
                                    • Sep 2014
                                    • 2536
                                    Just wanted to let you know that in you post 128 the Anode is connected to the B+ not the Cathode.
                                    • keeney123
                                      Lauren
                                      • Sep 2014
                                      • 2536
                                      I am sure it is TC1410N according to the pictures the device is TC1410, NCOA
                                      I attached the spec sheet. Look on page 13. C, starts with the temperature. They carry the N down to reduce the lettering on one line.
                                      If still in doubt call the manufacturer which is listing at the back of the attachment.
                                      • Crrose
                                        • Dec 2013
                                        • 165
                                        • Usa
                                        #219
                                        Thanks, looking at the spec sheet on page 13 if I read it right, it's a TC1410N with the C meaning 0-70 degree celsius and the OA meaning it's plastic SOIC 8-lead? I'll call to make sure before I purchase. I went to 3 places around here and they didn't carry either mosfet, said to order from digikey.
                                        Gives me time to do some practicing I guess.
                                          Thanks for catching that. I made an correction, hard to make 100% correct when I do not have the board in front of me.
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • Yanleb
                                            LG 60PK550 Logic Control Board EBR63450301
                                            by Yanleb
                                            Hi all, I just want to share the repair of my 60PK550-UA TV set.
                                            The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                                            But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                                            All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                                            C57: 3.30V
                                            C61:...
                                            07-20-2023, 12:38 AM
                                          • cyclones
                                            Motor control board repair
                                            by cyclones
                                            I have a motor control board I am trying to repair. I've been told the motor is fine, but the control board will only make the motor go one direction but not the other. Power comes in through a linear transformer and then a rectifier bridge and then filter caps. No schematics for the board. Relays on the board are 24V so I started by setting my bench PSU to 24V and injecting voltage. There are several LEDs. All but one LED lights up. There are test points labelled +15V, 0V and -15V. When checking voltage potential between +15V and 0V, I get a perfect 15V. For -15V to 0V, my meter shows approximately...
                                            10-30-2021, 10:39 PM
                                          • eagleeyez
                                            Treadmill Motor Control Board 032669-IF
                                            by eagleeyez
                                            I am looking for this Treadmill Motor Control Board 032669-IF schematic or how to fix it myself if someone can guide me and let me know what parts to change...
                                            I hope someone can help!
                                            Thanks.
                                            10-11-2020, 04:40 PM
