Cummins CM2150 ECU won’t communicate
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8883
    From a 2008 Ford medium duty F650 /F750 with a Cummins 6.7 Diesel.
    O.k, I know there are no terminating resistors at all on the J1939 CAN BUS hooked up. But still I Don’t think it should look like this. There is a definite difference between H and L in amplitude even so L is inverted from H.
    Maybe I should take a better picture, but one is more pronounced than the other and I got no clue why. Never seen this before. Even if I put two 120 ohm resistors in parallel, the waveform is squared up, but one side is still more pronounced than the other side. Doesn’t matter if I check on the connector pins or on the pins directly of the VP251 IC.
    YES, I checked the common mode choke, measured resistance to GND whatever I could find (resistors, caps, diodes) but don’t find the smoking gun. The only way I do see a difference is if I power it up and check the can bus with an oscilloscope.
    Since the board has 2 of them VP251 can bus transceiver IC’s, I can compare them no problem. I’ll post more pics later.
    Question is: Is the VP251 defective or not?
    Guess we find out later.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8883
    The first picture is the Can Bus not working. So I had the idea maybe there is nothing wrong with the Can Bus output. Rather a problem with the RX and TX between the MCU and the VP251 chip. Well didn’t I find the problem! Pin 4 is the RX nd at 0.4V it was stuck low. So I lifted pin 4 and I got the output of the Can Bus see second picture. Well that cleared it all up, even without the terminating resistors! Now with pin 4 lifted, I got a logic high on pin 4 (lifted) and a logic high (5V) on the pad! Not sure if the heat with the soldering Iron fixed temporary problem, even so I did heated the chip with the hot air. Ordered a few of these VP251 replacements and we see what happens after that!
      • 32065
      why is there high frequency noise superimposed?
      bad caps on the other side or do they just not give a shit as long as it works?
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8883
        Read it again. No terminating resistors. Medium duty have 2 external terminating resistors. Usually there is one 120ohm resistor inside the ECU. Not on this one.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8883
          So I swapped the VP251 for a new one, installed a 67ohm resistor across can high and low, turned it on and I got a beautiful Can bus signal see below.
          I got to figure out a better way on how to reseal those clamshell ECU’s. Why making such a crap design?
          Case closed. Next…
            • 32065
            which ecu's?
            the soldered ones or the RTV ones?
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8883
              which ecu's?
              The clamshell or Taco that you need to bend open, then take the middle casing part out and are glued together with RTV sealant of some sort.
                • 32065
                well you can get a chemical that desolves RTV, and you can get very strong RTV-like stuff such as "Tiger Seal" that is used to attach sill's and windshields.
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8883
                  It is not about the sealant as such. I use Permatex black RTV sealant oil resistant and sensor safe. The problem is rather the mess it makes resealing that bastard. I get RTV everywhere. Stupid design.
                  • zlr8r
                    Dell Latitude 9430 LA-L461P - identify 2 resistors near RAM chip
                    by zlr8r
                    hey guys , am working on this board (LA-L461p) and found 2 missing components (resistors) located around PC301 and PUA1, can someone with same board please measure the two resistors values and post here ? (the two resistors marked in red boxes in 2nd image below).
                    thanks in advance
                    09-07-2026, 07:49 AM
                  • TinkerTron
                    Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                    by TinkerTron
                    Hey everyone,
                    I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                    Instead, here's what's been bugging me so far:
                    The schematic...
                    03-06-2025, 02:03 PM
                  • agestec
                    Need Help! Gigabyte Aorus RX5P (GA-RX5PXE4 Rev 1.1) - Displaced Resistors Around BIOS Chip / No Trigger
                    by agestec
                    Please administrative staff, excuse me if I posted this thread in the wrong section.
                    I have a Gigabyte Aorus RX5P laptop with the motherboard code GA-RX5PXE4 Rev 1.1. Unfortunately, the serial number on the chassis is completely scratched off, so I cannot access it.
                    Recently, I had a mishap while trying to desolder the BIOS chip. As the chip came off, it slipped and accidentally displaced the surrounding SMD resistors/components. I managed to solder them back into place using hot air and a soldering iron based on my best guess, but I am absolutely...
                    07-09-2026, 12:41 AM
                  • brightest_z
                    Hot Air Blew Away Resistors Near Bios
                    by brightest_z
                    Hi All - I'm in the midst or reprogramming the bios on my gen1 Surface Laptop Studio and I accidentally blew away 2 resistors nearby the bios. I don't have another board to measure values of the missing resistors and schematics aren't available, bbut the bios is a 6x5mm Winbond WSON8, W25R256JWPQ model. The traces are conductive to Pins 3 and 7 (IO2 & IO3 respectively) so I have reason to believe they are 10k pull up resistors since IO2&3 pins are used for Quad SPI instructions.
                    Does anyone with more knowledge, and experience than I, know if this is the case?
                    12-11-2024, 08:34 PM
                  • conghuyms
                    HP Z440 Workstation – Missing resistors around the BIOS IC pins, boardview needed
                    by conghuyms
                    Hello everyone, I am currently experiencing an issue where the fan spins briefly and then shuts off repeatedly on an HP Z440 Workstation. Previously, the user removed the BIOS chip and reprogrammed it themselves, but accidentally caused the loss of several resistor components on pins 1, 2, 3, 5, and 6 of the BIOS chip. However, I do not have the schematic or boardview to determine the specifications of the missing resistors. If anyone has the boardview or knows the values of those resistors, please help me. Thank you very much.
                    12-27-2025, 09:15 AM
