Ps5 - edm - 041 - Can you help me to identify a missing component on a Wi-Fi card power supply circuit?
  • Rayanebalfabor
    • Mar 2022
    • France
    Hello, A capacitor has been torn off its spot on the Wi-Fi card's power supply circuit. Can you identify it—specifically its capacitance—and is it strictly necessary to have it there?
  • Rayanebalfabor
    Ps5 - edm - 041 - Can you identify a missing component on a Wi-Fi card power supply circuit?
    by Rayanebalfabor
    10-26-2026, 04:56 AM
  • Boardview and Schematic Bot
    Huawei P9 Plus Schematics & Boardview
    Huawei P9 Plus WCDMALTE 8 12 13 20 26 28 29 (MMMB) Front Modular Circuit block diagram.pdf
    Huawei P9 Plus WIFI Circuit block diagram.pdf
    Huawei P9 Plus CPU vcc U1101.U1301Circuit block diagram.pdf
    Huawei P9 Plus frame Circuit block diagram.pdf
    Huawei P9 Plus RF Front End Switch Main ANT Circuit block diagram.pdf
    Huawei P9 Plus U3902 LTE Diversity Circuit block diagram.pdf
    Huawei P9 Plus CDMA RFIC Circuit block diagram.pdf
    Huawei P9 Plus power supply U1001Circuit block diagram.pdf
    Huawei P9 Plus...
    10-20-2026, 02:50 PM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • edugimeno
    Help me identify the missing component... Sound to light circuit
    by edugimeno
    hI there!
    Im trying to help a friend repairing a large, real-sized short-circuit robot.
    This is remotely controlled and has a 2 way voice send/receive. Also while the hidden operator is talking, the red bulb inside the "mouth" should flash according to the sound
    Some other technician used to service it and he was fired leaving all the repairs unfinished and no documentation at all.
    What I found is a sound receiver, a speaker, and a wire directly to the mought bulb (a normal motorbike 5W 12V bulb).
    So I bought a simple 2X30W amplifier to feed the loudspeaker...
    02-14-2024, 10:23 AM
  • master_haze86
    macbook a1278 no wifi but bluetooth works
    by master_haze86
    Good day everyone,
    I got a macbook a1278 come in the other day with wifi issues. Owner says wifi just stopped working from one day to the next. As in, wifi was working previous evening, next day the laptop was turned on, wifi no longer worked.
    Just says "no hardware installed" under wifi while Bluetooth works without issues.
    First things first, I did the usual of removing certain settings files from the system configuration folder and let macOS rebuild them which did nothing to resolve the issue.
    Next I checked the motherboard's wifi connector...
    08-01-2026, 02:09 PM
