Asus Rog Ally z1 extreme
  • falkonON
    • Jun 2016
    • 8
    • Mexico
    "Hello Badcaps community, I have an Asus ROG Ally Z1 Extreme belonging to my son. From one day to the next, after leaving it plugged in, the symptom is that the charging LED stays on (either white or sometimes orange, indicating charging), but when I press the power button, the charging LED turns off, there is no display, and then the charging LED turns back on—all of this with the charger connected.
    I opened up the console and downloaded the boardview and schematic. I have the charger connected, and it is negotiating 20V, but it draws 21mA. When I press the power button, the current goes up to 78mA and drops abruptly, returning to draw around 22mA. I checked with a thermal camera and couldn't find any component getting hot.
    I started taking measurements following the schematic (page 51, Power Flow Chart):
    I have +PD_VBUS_CH_R
    I have AC_BAT_SYS
    I have +BAT
    I have +5VAO, +3VA, +3VA_EC, +5VSUS, +5VS, +5VS_PWR, +3VSUS, +3VS
    Where I find I don't have voltage ⚡ is at +VDDCR_VDD. Checking the schematic, this rail comes from a UP9505PQGW IC (PU8001). I checked its enables (CPU_VRON), and from those, two signals come out: APU_SVT and APU_SVD, which in turn feed the signal into the APU_SVC IC.
    The only signal missing voltage is APU_PWRGD, and consequently, the voltage to the APU does not turn on. This same controller manages the switching pulses for the MP86949GMW MOSFETs. There are also no shorts in the APU area.
    I'm not sure what else to check. Could you please help me figure out what else to measure, because I've hit a roadblock here?"
  • Agx03
    Please help me identify this chip. Asus ROG Ally Z1 Extreme
    by Agx03
    This is found between the usb-c port and processor of a Asus ROG Ally Z1 Extreme. I cannot find it anywhere on google. Please help me identify....
    06-15-2025, 11:27 AM
  • throwaway327
    by throwaway327
    Model No: RC72LA
    Serial No: SBNVKD001014459
    06-18-2025, 05:52 PM
  • fuzzyrunner
    ASUS ROG Ally: RC71L-ALLY.Z1X_512 Board# NR2301L_MB
    by fuzzyrunner
    My ROG is freezing on startup logo. Reading it could be a corrupted bios. I have pulled the bios and was hoping someone could check to see if it is corrupted or not.
    ASUS ROG ALLY
    Model#: RC71L-ALLY.Z1X_512
    S/N: R6NVKD01409525D
    Board#: NR2301L_MB R2.1
    Please let me know if I missing any information for you. Thanks!...
    01-16-2026, 08:42 PM
  • tehamaz
    ROG ALLY Z1 EXTREME LOSING 20V WHEN BATTERY PLUGGED IN..
    by tehamaz
    Good morning!
    i have a rog ally z1 extreme, and i cant figure out the issue... device is off and battery unplugged (light sensor covered) i get 20v 0.004A but as soon i add the battery(new or old same problem) to the equation i now get 16v at 0.4A device still lights up shows republic of gamers logo but wont post to bios then crash after 10 sec.. with no fan spin..
    after reseting EC buy holding power once it reset i get 20v 3.1 amps and nothing get hot either..(could be a usb-c meter problem...)
    after trying a lot of times i managed to get it working twice but since...
    03-17-2026, 05:57 PM
  • chudofermer
    Asus Ally rc71l bios
    by chudofermer
    Hello!
    Received Asus Ally rc71l with the wrong bios.
    Have the original package and all serial numbers.
    Can anyone help me understand what is wrong?
    Condition:
    Received with an original box with all serial numbers
    Due to the bios updating, something went wrong and I can not check in the bios. The recovery mode sometimes appears, usually was stopped on the logo.
    Got the flash dump, nothing found on DMI section
    No Windows key, just key ID on the box
    What is done:
    1. Flash the latest bios version with serial numbers...
    03-05-2025, 05:42 AM
