Ps4 white light but no display
  • Jay12345
    • Dec 2025
    • St. Vincent & Grenadines
    Hey, can I get some suggestions on what I'm missing if anything?
    A customer sent me a PS4 slim (SAF 005)saying it needs the HDMI IC replaced. I measured in diode mode and readings around the IC were slightly lower than usual but not completely out of spec. In any case, when turned it on, it goes to a white light and the screen is black with some flashes at startup and then completely black again.
    Here's what I did:
    Replaced HDMI IC: now it's permanently black, no flashes. Also the measurements are nominal.
    Replaced port. Even tho it seemed good and all the pins were solid I replaced it to see if it symptoms would change. Nothing changed.
    All the diodes measure ok. All the voltages are present. 2.5v on the caps on the chip side. 3.3v on the small diodes and 5v on the other diode.
    The fuse that goes bad is fine as well.
    Chokes measure good as well.
    I'm looking forward to hearing what worked for everyone else.
    I'm posting here as a last resort before I ship it back as a no fix.
  • ruletero
    HP Omen only do not turn on, only flashes white light
    by ruletero
    Hi everyone
    Please help me with this laptop
    HP Omen 15-dc0003la , MB DAG3DBMB8D0 REV. D
    It doesn't turn on, when I connect the charger with battery orange light appears on power jack and without battery white light appear, it is fine I think
    But if I press power button, power led flashes white once, only that, not consumes anything power, not start, nothing more.
    Bios was programmed with a working version, no changes.
    Voltages
    +3vS5 = 3v when I connect charger, next goes to 0 (I think is fine)...
    06-07-2023, 10:11 AM
  • TopPop
    Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
    by TopPop
    Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
    I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
    12-14-2025, 09:40 PM
  • krsta
    PS4 WLOD (white light of death)
    by krsta
    Hello all.
    I got a PS4 slim, model: CUH-2016A(board SAD-001) with WLOD problem, it powers on normaly (white light steady) but no picture on the monitor.
    Before disassembly i tried entering the safe mode holding power button for two beeps but the same problem persists.
    After disassembling the PS4 i checked the HDMI port using the breakout board and all the pins have contact, the four small filters are OK(no data lines shorted to each other, they have normal continuity and not shorted to GND).
    I checked the smd capacitors arround the HDMI encoder ic(MN864729)...
    02-09-2026, 05:18 AM
  • esqmooo
    HP Elitebook 850 G8 CAPS lock flashes 7 times and charging light always on
    by esqmooo
    I'm facing this issue since this morning. When I try to power it on, the CAPS lock light flashes 7 times (or 6 if not counting the first one when the power button is pressed). The charging light is always on as if the laptop was connected to the charger. The issues started gradually where it would flash the light but after trying multiple time it would power on. I tried to open it and I noticed one coil "1R0 2127" gets hot when the charger is connected. Note: the charging light directly comes on when the battery is connected or the charger is connected.
    03-07-2025, 05:55 AM
  • Allgone
    Lenovo IdeaPad 320-15IKBA limited charging current, flashing white light
    by Allgone
    Hi everyone. I'm looking for some help on a Lenovo Ideapad 320 repair. The problem with the laptop is that the charging current is not right, battery is charging below 1 amp and I get a blinking white light instead of the orange one. Already tried to change BQ chip and battery but same problem, also tried different charging and with my power supply, any idea on what could cause this problem? The laptop works just fine with or without the batttery the only problem is that the charging is not right....
    07-07-2026, 05:31 AM
