i am working on a ps5 edm-010 board with a blown fuse and UART code of 80810001. I cleared the code and power cycled the ps5 and same error code.
i have checked a lot of the capacitors on the board and i haven’t found one that is short to ground. The power supply also outputs 12V. The PS5 has a beep on beep off fault. Blue light for about 2 seconds. The person i got it from said that it was overheating a lot and then just randomly started shutting off with the beep on beep off. When i opened it, it has a horrible dry spot on the apu and heat sink.
what recommendations do you guys have? Replace the fuse and southbridge? Or probe around more to find a shorted cap? Is there another IC or chip that does power management that should be replaced instead? Any advice would be helpful
