PS5 - EDM-010 (CFI-1016A) stuck at black screen after logo (continuous BLOD)
  • Prott
    • May 2022
    • 158
    • Czechia
    I have a peculiar problem with my endless quest to fix a very temperamental PS5.
    I am now stuck in a continuous BLOD with a following behaviour:
    • Safe mode always works
    • Pairing of controller / turning on the console with it wirelessly works (BT fine?)
    • firmware update in safe mode works fine also using the ethernet connection
    • I can install the system in safe mode 100 % time without errors
    • The system displays the PS logo for few seconds, then fades out (smoothly) into black and gets stuck there (hdmi signal remains uninterrupted) with pulsing BLOD
    • Doesn't seem to be caused by liquid metal -> I don't know the service history, but vigorously moving the board while pouring IPA behind the APU didn't change the behavior in any way
    UART always shows these 3 codes in succession (all of them C0020303 - APU not responding):
    C00200303 0000BC36 150000E5 00010000 217B 0036 2CCF 0000:07
    C00200303 0000BC36 15000005 00010000 217B 0036 2CCE 0000:F1
    C00200303 0000BC35 15000005 00010000 217B 0036 2CCC 0000:EE
    All of them related to the wifi startup stage (217B).
    From what I figured out this error points to APU not responding to i2c calls from SB around this stage. However the smooth fadeout of the PS logo would make me believe the APU is not locked and is still processing, even after it stops responding to commands from SB.
    My suspicion is aimed at the wifi portion of the wifi/bt module, but it's hard to diagnose it further. I noticed it gets warm right after startup (picture in attachments).
    Is it normal behavior? It's pretty uniform, so it doesn't scream "faulty IC".
    Does anybody know what is the next course of action for diagnosing this?
    Thank you so much! This is a bit infuriating, cause the console “almost” works.
  • Prott
    • May 2022
    • 158
    • Czechia
    UPDATE: Those error codes are actually generated by me pulling the console out of the wall. During the operation (even when on a black screen) the error log is empty. This means the console hangs on the black screen even though UART shows no problems. Anybody has any ideas? :/
    • timorlank
      • Jul 2022
      • Algeria
      Inject low voltage 1V OR1.8V into the shorted rail to pinpoint the bad capacitor or if the Wi-Fi IC itself is dead check what component do this fault becacuse when ur ps5 run on safe mode this good sound ur apu and ssd and power ic those all good so ur problem clear on wifi parts
      • Prott
        • May 2022
        • 158
        • Czechia
        Thank you! I am not sure if I understand - which shorted rail? As far as I could see there are no shorted rails and all of the voltages are present.
        Also, from looking at the behavior of the startup I think a shorted rail and lack of i2c communication between WiFi and SB would halt the startup alltogether, not cause it to hang on the logo.
        I was suspecting a partially dead wifi module until I figured out those UART errors are probably generated by unplugging the console, not an actual error in the startup (my latest update). :/
        • odie34
          TCL 55S451 Stuck on Logo Screen But Working Otherwise
          by odie34
          I have a TCL 55S451 that's stuck on the logo screen. I've done all of the traditional troubleshooting steps (power cycling, holding the reset button, etc.), but nothing has worked. I thought the main board was dead, but then I realized that even though it was only showing the logo screen, it appeared to be responding to remote buttons.
          So I pressed the reset button again and used the remote to put the TV into screen reader mode. I was then able to navigate through the setup menus (including successfully connecting to the internet) in order to update the firmware. I thought that that...
          04-25-2026, 03:40 PM
        • Teban1306
          [REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
          by Teban1306
          Hello everyone!
          I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
          System Information:
          • Model: Lenovo ThinkPad T14 Gen 1
          • Machine Type: 20S1S4E600 (Intel i7 variant)
          • Current BIOS: N2XET42W (1.33) - Latest version
          • BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
          What I'm trying to achieve:
          Replace the default "LENOVO" boot logo with a custom image during POST.
          🔧 What I've tried:
          09-14-2025, 11:49 AM
        • mutleybird
          Becker Indianapolis Start-Up Logo - (car headunit)
          by mutleybird
          I have a Becker Indianapolis BE7921, which is supposed to start-up with the "Becker Indianapolis" logo, but is starting up with a BMW logo (its not the model of Indianapolis that's supposed to do this).
          Is there anyone on this forum that is able to do the common reprogram of the radio's EEPROM 24C64 to bring that back to the correct "Becker Indianapolis" start-up logo (such as with the program "Becker Logo Editor")? Or recommend a shop in the USA? (Becker Autosound, of course, doesn't know how to do it).
          This link...
          04-24-2026, 04:36 PM
        • Verlengsnoer
          Bios splash/logo change
          by Verlengsnoer
          at firs, i hope this is the right place to post my question.
          Im looking for a tool to change the bios logo.
          everyone knows when you turn on your laptop/pc you will see the manufacturer logo like lenovo, hp, dell...
          i know that HP has a build in option to change the splash logo.
          but i want to change the manufacturer logo to an own logo.
          I try'd Change Logo 5.0, but when i make a backup of an laptop and edit the logo and flash the editted version back on the laptop the logo diddnt change.
          10-28-2022, 09:52 AM
        • Weelcup
          Dell Precision 5570 logo restaring
          by Weelcup
          Hi
          I have a dell precision 5570 i7 12th gen
          Device turns on to dell logo stays for 10s then off then on to black screen for about 20s then dell logo comes for 10s then off then on to black screen 20s then logo 10s then off and continue!!
          I cleaned bios and same issue, I tried one of the forum bioses and is was the same initially then with the same bios next day without changing anything the advice turned on with no issues, I entered ST and factory reset the device and all was good, turned it on and off several times with no issues, I thought that is sorted out...
          10-26-2026, 02:49 AM
